I’m running version 0.5-dev-020615, and of what I can tell there should be an update for me. Right? Users seems to be running higher versions (like 0.5-dev-101215)
So, how do I update in the convenient way?
I hope theres a way without doing a clean new install with the new files?
I’m running with the trailers hijack and as you might guess by that, have not a jb ATV. (AVT3)
Thanks.
There are basically four options to update PlexConnect:
- If you own a Syno NAS, use the latest bwynants installer
- If you use OpenPlex, you can use it to update PlexConnect
- If initial installation was made with the git clone method you can use the git pull method to update
- Otherwise you can get a new zip from github, rename your PlexConnect folder, unzip the new version to folder PlexConnect, copy *.cfg *.cer *.key and *.pem files from PlexConnect backup to new PlexConnect folder
Thank you!
I had a run at option 4 and had a fresh updated version running in under 5 mins!
