Conversion failed. A required codec could not be found or failed to install. - A bad update??
Hi guys,
Plex was working fine until this week. I get an error for many files on the server that it cannot find the codec. I feel it was perhaps the latest update? How can I delete the update to roll back to a previous version?
This is the error message:
“Conversion failed. A required codec could not be found or failed to install.”
Unraid Version: 6.2.0-rc2
Plex Version 1.2.7.2987
Cheers, Josh
Log files please? Another user has reported a similar error which I’m tracking. I’d like to know which codec / codec server might have a problem
Hi ChuckPa, I’m only getting a 500 internal server error when clicking download logs under the help tab unfortunately
Cheers
a 500 error is not good. That’s the same ‘500’ we get from web sites… It is the same “He’s dead, Jim” error.
not knowing unraid, I can only suggest the default 1) restart 2) reinstall software if it doesn’t wipe your Library 3) if not cleared by this point, you will have to wipe and restart. Something corrupted it, or as I have seen with another user… he hasn’t updated in months and when he did, it was too much to change. All the codecs were out of date as well as the Database schema. It ended up corrupting itself in the schema upgrade (sqlite can do that if severe)
Things got even worse!
Tried restarting both unraid and plex, no change.
Deleted and reinstalled plex - all library data was still there no change, same error.
Then deleted plex and deleted the appdata/PlexMediaServer folder. Now it doesn’t launch!
****** PLEX MEDIA SERVER CRASHED, CRASH REPORT WRITTEN: /config/Library/Application Support/Plex Media Server/Crash Reports/1.2.7.2987-1bef33a/PLEX MEDIA SERVER/63703dcd-cdbb-f951-71425c2b-0dfa98ad.dmp
Segmentation fault
chown: changing ownership of ‘/config/tmp’: Operation not permitted
chown: changing ownership of ‘/config/Library’: Operation not permitted
chown: changing ownership of ‘/config/Library/Application Support’: Operation not permitted
Error in command line:the argument for option ‘–serverUuid’ should follow immediately after the equal sign
did you delete the /config directory? As I read the docs, if that doesn’t exist and isn’t writeable by Plex, it won’t be able to initialize and start at all.
Also, when chown cannot change ownership of a directory, that means it doesn’t own it to begin with OR it’s not root. There is your first clue as to what’s happening. Ownership & user it’s being invoked as don’t match up… hence the other permission issues
I’m getting the same problem with playing content (Conversation failed…). I am able to access the log files which I can post here if you can direct me to which one.
FreeNas9.10
plex 1.2.7
Same problemfor me. Also with the 1.3.0.3059 MAC OS Sierra.
The info of the file says MPEG4 and AVI container
I’m getting the same codec errors on the most recent update, files I know that were working prior to the update now no longer play under the new update Version 1.2.7.2987.
Here is a file that was working prior to the update:
Media
Video Resolution 1080p
Duration 1:59:44
Bitrate 10081 kbps
Width 1920
Height 1080
Aspect Ratio 1.78
Container MP4
Video Frame Rate 24p
Web Optimized No
Audio Profile lc
Has 64bit Offsets 1
Video Profile simple
Part
Duration 1:59:44
File Independence Day - Resurgence.mp4
Size 8.43 GB
Audio Profile lc
Container MP4
Has 64bit Offsets 1
Has Chapter Text Stream 1
Has Thumbnail 1
Web Optimized No
Codec MPEG4
Bitrate 9915 kbps
Language English
Bit Depth 8
Bvop 0
Chroma Subsampling 4:2:0
Duration 1:59:43
Frame Rate 23.976 fps
Frame Rate Mode cfr
Gmc 0
Height 1080
Pixel Format yuv420p
Profile simple
Qpel 0
Ref Frames 1
Scan Type progressive
Stream Identifier 1
Width 1920
Codec AAC
Channels Stereo
Bitrate 152 kbps
Audio Channel Layout stereo
Bitrate Mode VBR
Duration 1:59:44
Profile lc
Sampling Rate 44100 Hz
Stream Identifier 2
So the update was giving me codec rendering errors earlier, but I’ve since refreshed the database again and some of the files that were giving me errors are now working. I will stay on top of it. Here is another file that was giving me hiccups.
Media
Duration 3:02:33
Bitrate 10383 kbps
Width 1920
Height 1080
Aspect Ratio 1.78
Container MP4
Web Optimized No
Has 64bit Offsets 1
Part
Duration 3:02:33
File Batman vs Superman - Dawn of Justice - New.mp4
Size 13.24 GB
Container MP4
Has 64bit Offsets 1
Has Thumbnail 1
Web Optimized No
Codec MPEG4
Bitrate 9923 kbps
Language English
Bit Depth 8
Bvop 0
Duration 3:02:33
Frame Rate Mode cfr
Gmc 0
Height 1080
Profile simple
Qpel 0
Ref Frames 1
Stream Identifier 1
Width 1920
Codec AC3
Channels 5.1
Bitrate 448 kbps
Audio Channel Layout 5.1(side)
Bit Depth 16
Bitrate Mode CBR
Dialog Norm -27 dB
Duration 3:02:33
Sampling Rate 48000 Hz
Stream Identifier 2
To be certain all your codecs are up to date (this is something I’m noticing but do not have anything definitive enough to take to the devs), perform a multi-select of your movies/videos (enable multi-select, click the first, shift-click the last), then perform Analyze on them (left margin popup box). It will reanalyze the media and download updated codecs as needed.
ChuckPa,
I’m unsure why the update would have broken the codecs that were working before though, or are you just suggesting this for others to try?
Maybe that was a bug in the latest update…The DB and files need to be re-analyzed to fix any codecs it dropped during the update?
Getting Conversion failed. A required codec could not be found or failed to install. Openmediavault Plex install
What happened, which will be in your log files, is the codec download failure.
PMS 1.3.3 received a ‘codec revision bump’ to address issues. Those effected codecs (new minimum versions required) are called out directly by the Codec Manager and the Transcoder.
while starting a mkv file i get “not enough disk space to convert”
This is on a Raspberry PI 3 with a 500 gb usb drive
That helps me a great deal more than your log file.
Take the size of the movie (file size), roughly multiply by 2.5, this is the space PMS needs ‘just in case’ . It does this because it won’t know until it starts transcoding whether it actually has enough space or not. Plus, if you want to rewind, play again, and then skip forward, why waste that, so it saves it to disk until done.
Wherever you have enough space for that, Set the transcoder temporary directory there (Settings - Server - Transcoder). Make certain plex:plex has ownership and 755 permission to the directory.
Same problem anyone have a fix for this???
Experienced the problem recently, turns out it’s caused by plex.tv application having 500 error.
Not being able to log in into plex.tv will cause local video playback to fail.
Please remove that dependency please.
The otherwise normally reliable Plex.tv server did go down last night. From what I know at this point, the central Amazon servers (AWS), where the portion of Plex.tv you see lives, stopped working. I have not yet heard why this occurred. It could have been the app or it could have been Amazon and server issues on their end. That information hasn’t been reported yet.
I can concerned, and do wish to investigate further, how PMS could fail playback when it has previously downloaded the codec for that specific file during the matching and analysis stages when the file was first added to the library.
