"Conversion failed. The transcoder exited due to an error." when trying to play trailer
Hello,
originally I was able to play trailers on the system while in trial. Recently I purchased a plexpass and discovered that trailers cannot be played due to error.
I’ve attached my log files.
Can anyone help me? I really would like trailers to work.
it is already set to maximum. Are there anything else I can try?
Looked all settings and only thing that had 2mbs limit was - Internet Streaming, Video quality. I changed it to maximum. Restarted pms, but still no luck. Same error comes when I try to play trailers
maybe updated logs can help. Trumpy81 - thanks for trying to help me, I really appreciate it.
I also see another problem… TLS connection error.
Apr 15, 2018 17:13:51.355 [0xeabffb70] DEBUG - Found session GUID of 25t58gdalnqeurbepjtwbcjr in session start.
Apr 15, 2018 17:13:51.355 [0xeabffb70] DEBUG - TranscodeUniversalRequest: using profile Web
Apr 15, 2018 17:13:51.356 [0xeabffb70] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/30067?includeBandwidths=1&offset=-1&X-Plex-Session-Identifier=b116vzbsjg5q6bxecl7w2dai
Apr 15, 2018 17:13:51.356 [0xeabffb70] DEBUG - Auth: authenticated user 1 as lex787
Apr 15, 2018 17:13:51.359 [0xeabffb70] DEBUG - We're going to try to auto-select an audio stream for account 1.
Apr 15, 2018 17:13:51.359 [0xeabffb70] DEBUG - Selecting best audio stream for part ID 241970 (autoselect: 0 language: ru)
Apr 15, 2018 17:13:51.359 [0xeabffb70] DEBUG - Audio Stream: 447682, Subtitle Stream: -1
Apr 15, 2018 17:13:51.359 [0xeabffb70] DEBUG - Selecting best audio stream for part ID 241971 (autoselect: 0 language: ru)
Apr 15, 2018 17:13:51.359 [0xeabffb70] DEBUG - Audio Stream: 447684, Subtitle Stream: -1
Apr 15, 2018 17:13:51.360 [0xeabffb70] DEBUG - We're going to try to auto-select an audio stream for account 1.
Apr 15, 2018 17:13:51.360 [0xeabffb70] DEBUG - Selecting best audio stream for part ID 241972 (autoselect: 0 language: ru)
Apr 15, 2018 17:13:51.360 [0xeabffb70] DEBUG - Audio Stream: 447686, Subtitle Stream: -1
Apr 15, 2018 17:13:51.360 [0xeabffb70] DEBUG - MDE: Selected protocol dash; container: mp4
Apr 15, 2018 17:13:51.360 [0xeabffb70] DEBUG - MDE: analyzing media item 241881
Apr 15, 2018 17:13:51.360 [0xeabffb70] DEBUG - MDE: Batman v Superman: Dawn of Justice (Clean Trailer): Direct Play is disabled
Apr 15, 2018 17:13:51.360 [0xeabffb70] DEBUG - MDE: Batman v Superman: Dawn of Justice (Clean Trailer): media must be transcoded in order to use the dash protocol
Apr 15, 2018 17:13:51.360 [0xeabffb70] DEBUG - MDE: Batman v Superman: Dawn of Justice (Clean Trailer): no direct play video profile exists for http/mp4/h264
Apr 15, 2018 17:13:51.360 [0xeabffb70] DEBUG - MDE: Batman v Superman: Dawn of Justice (Clean Trailer): no direct play video profile exists for http/mp4/h264/aac
Apr 15, 2018 17:13:51.360 [0xeabffb70] DEBUG - MDE: Batman v Superman: Dawn of Justice (Clean Trailer): selected media 0 / 241881
Apr 15, 2018 17:13:51.360 [0xeabffb70] DEBUG - Streaming Resource: Reached Decision id=30067 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=241881 part=(id=241970 decision=transcode container=mp4 protocol=dash streams=(Video=(id=447681 decision=copy width=1920 height=1080) Audio=(id=447682 decision=copy channels=2 rate=0))))
Apr 15, 2018 17:13:51.361 [0xf17ffb70] DEBUG - Completed: [192.168.1.21:49913] 200 GET /video/:/transcode/universal/decision?hasMDE=1&path=%2Flibrary%2Fmetadata%2F30067&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&mediaBufferSize=102400&session=25t58gdalnqeurbepjtwbcjr&subtitles=burn&Accept-Language=en (13 live) TLS GZIP 6ms 1213 bytes (pipelined: 11)
Apr 15, 2018 17:13:51.438 [0xf1511b70] DEBUG - Auth: authenticated user 1 as lex787
Apr 15, 2018 17:13:51.438 [0xea335b70] DEBUG - Request: [192.168.1.21:49913 (Subnet)] GET /video/:/transcode/universal/start.mpd?hasMDE=1&path=%2Flibrary%2Fmetadata%2F30067&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&mediaBufferSize=102400&session=25t58gdalnqeurbepjtwbcjr&subtitles=burn&Accept-Language=en (13 live) TLS GZIP Signed-in Token (lex787)
Apr 15, 2018 17:13:51.438 [0xea335b70] DEBUG - Found session GUID of 25t58gdalnqeurbepjtwbcjr in session start.
Apr 15, 2018 17:13:51.438 [0xea335b70] DEBUG - TranscodeUniversalRequest: using profile Web
Apr 15, 2018 17:13:51.438 [0xea335b70] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/30067?checkFiles=1&includeBandwidths=1&offset=-1&X-Plex-Session-Identifier=b116vzbsjg5q6bxecl7w2dai
Apr 15, 2018 17:13:51.439 [0xea335b70] DEBUG - Auth: authenticated user 1 as lex787
Apr 15, 2018 17:13:51.443 [0xea335b70] DEBUG - We're going to try to auto-select an audio stream for account 1.
Apr 15, 2018 17:13:51.443 [0xea335b70] DEBUG - Selecting best audio stream for part ID 241970 (autoselect: 0 language: ru)
Apr 15, 2018 17:13:51.443 [0xea335b70] DEBUG - Audio Stream: 447682, Subtitle Stream: -1
Apr 15, 2018 17:13:51.443 [0xea335b70] DEBUG - Selecting best audio stream for part ID 241971 (autoselect: 0 language: ru)
Apr 15, 2018 17:13:51.443 [0xea335b70] DEBUG - Audio Stream: 447684, Subtitle Stream: -1
Apr 15, 2018 17:13:51.443 [0xea335b70] DEBUG - Selecting best audio stream for part ID 241972 (autoselect: 0 language: ru)
Apr 15, 2018 17:13:51.443 [0xea335b70] DEBUG - Audio Stream: 447686, Subtitle Stream: -1
Apr 15, 2018 17:13:51.443 [0xea335b70] DEBUG - Found session GUID of 25t58gdalnqeurbepjtwbcjr in session start.
Apr 15, 2018 17:13:51.443 [0xea335b70] DEBUG - Cleaning directory for session 25t58gdalnqeurbepjtwbcjr ()
Apr 15, 2018 17:13:51.444 [0xea335b70] DEBUG - Starting a transcode session 25t58gdalnqeurbepjtwbcjr at offset -1.0 (state=3)
Apr 15, 2018 17:13:51.445 [0xe8b35b70] INFO - Library section 1 (Movies) will be updated because of a change in /volume2/Video/plex temp
Apr 15, 2018 17:13:51.445 [0xe8b35b70] INFO - Library section 4 (TV Shows) will be updated because of a change in /volume2/Video/plex temp
Apr 15, 2018 17:13:51.446 [0xea335b70] DEBUG - Job running: EAE_ROOT='/volume1/Plex/tmp_transcoding/pms-dd8bca5d-543f-442e-a7a9-3c056cc7cf95/EasyAudioEncoder' FFMPEG_EXTERNAL_LIBS='/volume1/Plex/Library/Application\ Support/Plex\ Media\ Server/Codecs/7814ac9-1285-linux-synology-i686/' XDG_CACHE_HOME='/volume1/Plex/Library/Application Support/Plex Media Server/Cache/' XDG_DATA_HOME='/volume1/@appstore/Plex Media Server/Resources/' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/volume1/@appstore/Plex Media Server/Plex Transcoder' '-codec:0' 'h264' '-ss' '0' '-noaccurate_seek' '-i' 'http://127.0.0.1:32400/services/iva/assets/783103/video.mp4?bitrate=2500&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx' '-map' '0:0' '-codec:0' 'copy' '-map' '0:1' '-metadata:s:1' 'language=eng' '-codec:1' 'copy' '-copypriorss:1' '0' '-f' 'dash' '-min_seg_duration' '5000000' '-skip_to_segment' '1' '-time_delta' '0.0625' '-manifest_name' 'http://127.0.0.1:32400/video/:/transcode/session/25t58gdalnqeurbepjtwbcjr/28e018e5-b4d6-4cd5-99a9-64c59eee38ae/manifest' '-avoid_negative_ts' 'disabled' '-map_metadata' '-1' '-map_chapters' '-1' 'dash' '-start_at_zero' '-copyts' '-vsync' 'cfr' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/25t58gdalnqeurbepjtwbcjr/28e018e5-b4d6-4cd5-99a9-64c59eee38ae/progress'
Apr 15, 2018 17:13:51.447 [0xea335b70] DEBUG - Jobs: Starting child process with pid 5683
Apr 15, 2018 17:13:51.449 [0xe8b35b70] DEBUG - [Notify] New directory: "/volume2/Video/plex temp/Transcode/Sessions/plex-transcode-25t58gdalnqeurbepjtwbcjr-28e018e5-b4d6-4cd5-99a9-64c59eee38ae", adding recursively.
Apr 15, 2018 17:13:51.449 [0xe8b35b70] DEBUG - [Notify] Now watching /volume2/Video/plex temp/Transcode/Sessions/plex-transcode-25t58gdalnqeurbepjtwbcjr-28e018e5-b4d6-4cd5-99a9-64c59eee38ae
Apr 15, 2018 17:13:51.475 [0xf1511b70] DEBUG - Auth: authenticated user 1 as lex787
Apr 15, 2018 17:13:51.475 [0xea911b70] DEBUG - Request: [127.0.0.1:38644 (Loopback)] GET /services/iva/assets/783103/video.mp4?bitrate=2500 (14 live) Signed-in Token (lex787)
Apr 15, 2018 17:13:51.476 [0xf1511b70] DEBUG - Completed: [127.0.0.1:38644] 302 GET /services/iva/assets/783103/video.mp4?bitrate=2500 (14 live) 0ms 328 bytes -> https://video.internetvideoarchive.net/video.mp4?cmd=6&publishedid=783103&customerid=112548&fmt=4&videokbrate=2500&e=1523826831&h=5ee7858a0b007444c41180c4e2b75e95
Apr 15, 2018 17:13:51.718 [0xea623b70] ERROR - [Transcoder] [tls @ 0x8d63ac0] The TLS connection was non-properly terminated.
Apr 15, 2018 17:13:51.720 [0xea047b70] ERROR - [Transcoder] http://127.0.0.1:32400/services/iva/assets/783103/video.mp4?bitrate=2500&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx: Input/output error
It can’t send out over TLS. A problem with the player in this case. Something is prohibiting a secure connection
are there a particular place i should check?
