When playing trailers (before movie starts, or from the movie detail page), I get an error “Transcoding ended due to an error” most of the time. It seems the plex server is trying to transcode (even if I chose not to), and there is an error with that.
Out of 10 attempts to play the trailer: 1 attempt would play the complete trailer, 2 attempts would play 15 seconds into the trailer, 7 attempts are not starting at all.
It seems random to me.
On the same PC, Plex-Web is playing trailers without an issue.
This issue happens since several weeks, also updating to the recent versions did not solve the issue.
The same happens also on my second PC, also the same Windows 10 installation.
Server Version#: 1.19.1.2630
Player Version#: 2.54
Plex Media Player log:
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Set property: volume=55 -> 1
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Run command: stop, flags=0, args=
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Set property: video-sync=“audio” -> 1
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Set property: hwdec=“auto” -> 1
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Set property: videotoolbox-format=“nv12” -> -3
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Set property: deinterlace=“no” -> 1
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Set property: display-fps=75.000000 -> 1
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Set property: audio-delay=0.000000 -> 1
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Set property: cache=76800 -> 1
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Set property: video-unscaled=false -> 1
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Set property: video-aspect="-1" -> 1
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Set property: keepaspect=true -> 1
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Set property: panscan=0.000000 -> 1
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Run command: loadfile, flags=0, args=[https://10.0.0.1:32400/video/:/transcode/universal/start?hasMDE=1&path=%2Flibrary%2Fmetadata%2F269271&mediaIndex=0&partIndex=0&protocol=http&fastSeek=1&directPlay=0&directStream=0&subtitleSize=100&audioBoost=100&location=lan&session=kazm5j0eeqlqtay9witxu5wm&offset=0&subtitles=auto©ts=1&Accept-Language=de&X-Plex-Session-Identifier=n6fjagq75mt3bcs4ks42c5wm&X-Plex-Client-Profile-Extra=append-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhttp%26videoCodec%3D*%26audioCodec%3D*)&X-Plex-Chunked=1&X-Plex-Client-Identifier=dka1dczu9tf5zan4epyeng66r&X-Plex-Device-Screen-Resolution=1676x984%2C2560x1440&X-Plex-Version=4.29.2&X-Plex-Features=external-media&X-Plex-Client-Capabilities=protocols%3Dshoutcast%2Chttp-video%3BvideoDecoders%3Dh264{profile%3Ahigh%26resolution%3A2160%26level%3A52}%3BaudioDecoders%3Dmp3%2Caac%2Cdts{bitrate%3A800000%26channels%3A2}%2Cac3{bitrate%3A800000%26channels%3A2}&X-Plex-Product=Plex%20Media%20Player&X-Plex-Platform=Konvergo&X-Plex-Platform-Version=2.54.0.1067-1a7bc4f6&X-Plex-Device=Windows&X-Plex-Device-Name=NEWPC&X-Plex-Model=10&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx&X-Plex-Language=de&X-Plex-Client-Profile-Name=Konvergo, append-play, ad=,aid=no,pause=no,sid=no,stream-lavf-o=verifyhost=10-0-0-1.7e55d9e0151d41ef86649463cf571365.plex.direct,vd=]
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Setting option ‘ad’ = ‘’ (flags = 80)
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Setting option ‘aid’ = ‘no’ (flags = 80)
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Setting option ‘pause’ = ‘no’ (flags = 80)
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Setting option ‘sid’ = ‘no’ (flags = 80)
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Setting option ‘stream-lavf-o’ = ‘verifyhost=10-0-0-1.7e55d9e0151d41ef86649463cf571365.plex.direct’ (flags = 80)
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Setting option ‘vd’ = ‘’ (flags = 80)
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 366 - Video framerate: 0 fps
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 370 - Not switching refresh-rate (disabled by settings).
2020-04-13 15:45:40 [ INFO ] PlayerComponent.cpp @ 616 - checking codecs
2020-04-13 15:45:40 [ INFO ] CodecsComponent.cpp @ 1262 - Using system audio decoders: true
2020-04-13 15:45:40 [ INFO ] CodecsComponent.cpp @ 1263 - Using system video decoders: false
2020-04-13 15:45:40 [ INFO ] PlayerComponent.cpp @ 618 - resuming loading
2020-04-13 15:45:40 [ INFO ] PlayerComponent.cpp @ 596 - cplayer: Playing: https://10.0.0.1:32400/video/:/transcode/universal/start?hasMDE=1&path=%2Flibrary%2Fmetadata%2F269271&mediaIndex=0&partIndex=0&protocol=http&fastSeek=1&directPlay=0&directStream=0&subtitleSize=100&audioBoost=100&location=lan&session=kazm5j0eeqlqtay9witxu5wm&offset=0&subtitles=auto©ts=1&Accept-Language=de&X-Plex-Session-Identifier=n6fjagq75mt3bcs4ks42c5wm&X-Plex-Client-Profile-Extra=append-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhttp%26videoCodec%3D*%26audioCodec%3D*)&X-Plex-Chunked=1&X-Plex-Client-Identifier=dka1dczu9tf5zan4epyeng66r&X-Plex-Device-Screen-Resolution=1676x984%2C2560x1440&X-Plex-Version=4.29.2&X-Plex-Features=external-media&X-Plex-Client-Capabilities=protocols%3Dshoutcast%2Chttp-video%3BvideoDecoders%3Dh264{profile%3Ahigh%26resolution%3A2160%26level%3A52}%3BaudioDecoders%3Dmp3%2Caac%2Cdts{bitrate%3A800000%26channels%3A2}%2Cac3{bitrate%3A800000%26channels%3A2}&X-Plex-Product=Plex%20Media%20Player&X-Plex-Platform=Konvergo&X-Plex-Platform-Version=2.54.0.1067-1a7bc4f6&X-Plex-Device=Windows&X-Plex-Device-Name=NEWPC&X-Plex-Model=10&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx&X-Plex-Language=de&X-Plex-Client-Profile-Name=Konvergo
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Running hook: main/on_load
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Set property: ad="" -> 1
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Set property: vd="" -> 1
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Run command: hook-ack, flags=0, args=[on_load]
2020-04-13 15:45:40 [ INFO ] PlayerComponent.cpp @ 466 - Entering state: buffering
2020-04-13 15:45:40 [ DEBUG ] PlayerComponent.cpp @ 594 - ffmpeg: Opening https://10.0.0.1:32400/video/:/transcode/universal/start?hasMDE=1&path=%2Flibrary%2Fmetadata%2F269271&mediaIndex=0&partIndex=0&protocol=http&fastSeek=1&directPlay=0&directStream=0&subtitleSize=100&audioBoost=100&location=lan&session=kazm5j0eeqlqtay9witxu5wm&offset=0&subtitles=auto©ts=1&Accept-Language=de&X-Plex-Session-Identifier=n6fjagq75mt3bcs4ks42c5wm&X-Plex-Client-Profile-Extra=append-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhttp%26videoCodec%3D*%26audioCodec%3D*)&X-Plex-Chunked=1&X-Plex-Client-Identifier=dka1dczu9tf5zan4epyeng66r&X-Plex-Device-Screen-Resolution=1676x984%2C2560x1440&X-Plex-Version=4.29.2&X-Plex-Features=external-media&X-Plex-Client-Capabilities=protocols%3Dshoutcast%2Chttp-video%3BvideoDecoders%3Dh264{profile%3Ahigh%26resolution%3A2160%26level%3A52}%3BaudioDecoders%3Dmp3%2Caac%2Cdts{bitrate%3A800000%26channels%3A2}%2Cac3{bitrate%3A800000%26channels%3A2}&X-Plex-Product=Plex%20Media%20Player&X-Plex-Platform=Konvergo&X-Plex-Platform-Version=2.54.0.1067-1a7bc4f6&X-Plex-Device=Windows&X-Plex-Device-Name=NEWPC&X-Plex-Model=10&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx&X-Plex-Language=de&X-Plex-Client-Profile-Name=Konvergo
2020-04-13 15:45:40 [ INFO ] JS: [Player] Buffering detected by PMP
2020-04-13 15:45:42 [ DEBUG ] PlayerComponent.cpp @ 594 - ffmpeg: Mime-type: ‘video/x-matroska’
2020-04-13 15:45:42 [ DEBUG ] PlayerComponent.cpp @ 594 - ffmpeg: Stream opened successfully.
2020-04-13 15:45:42 [ DEBUG ] PlayerComponent.cpp @ 594 - cache: Cache size set to 151800 KiB (75000 KiB backbuffer)
2020-04-13 15:45:42 [ DEBUG ] PlayerComponent.cpp @ 594 - demux: Trying demuxers for level=normal.
2020-04-13 15:45:42 [ DEBUG ] PlayerComponent.cpp @ 594 - ffmpeg: tls: Server closed the connection
2020-04-13 15:45:42 [ DEBUG ] PlayerComponent.cpp @ 594 - cache: EOF reached.
2020-04-13 15:45:42 [ DEBUG ] PlayerComponent.cpp @ 594 - lavf: No format found, try lowering probescore or forcing the format.
2020-04-13 15:45:42 [ DEBUG ] PlayerComponent.cpp @ 594 - demux: Trying demuxers for level=unsafe.
2020-04-13 15:45:42 [ DEBUG ] PlayerComponent.cpp @ 594 - cache: Terminating cache…
2020-04-13 15:45:42 [ DEBUG ] PlayerComponent.cpp @ 594 - cache: Cache exiting…
2020-04-13 15:45:42 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: Opening failed or was aborted: https://10.0.0.1:32400/video/:/transcode/universal/start?hasMDE=1&path=%2Flibrary%2Fmetadata%2F269271&mediaIndex=0&partIndex=0&protocol=http&fastSeek=1&directPlay=0&directStream=0&subtitleSize=100&audioBoost=100&location=lan&session=kazm5j0eeqlqtay9witxu5wm&offset=0&subtitles=auto©ts=1&Accept-Language=de&X-Plex-Session-Identifier=n6fjagq75mt3bcs4ks42c5wm&X-Plex-Client-Profile-Extra=append-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhttp%26videoCodec%3D*%26audioCodec%3D*)&X-Plex-Chunked=1&X-Plex-Client-Identifier=dka1dczu9tf5zan4epyeng66r&X-Plex-Device-Screen-Resolution=1676x984%2C2560x1440&X-Plex-Version=4.29.2&X-Plex-Features=external-media&X-Plex-Client-Capabilities=protocols%3Dshoutcast%2Chttp-video%3BvideoDecoders%3Dh264{profile%3Ahigh%26resolution%3A2160%26level%3A52}%3BaudioDecoders%3Dmp3%2Caac%2Cdts{bitrate%3A800000%26channels%3A2}%2Cac3{bitrate%3A800000%26channels%3A2}&X-Plex-Product=Plex%20Media%20Player&X-Plex-Platform=Konvergo&X-Plex-Platform-Version=2.54.0.1067-1a7bc4f6&X-Plex-Device=Windows&X-Plex-Device-Name=NEWPC&X-Plex-Model=10&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx&X-Plex-Language=de&X-Plex-Client-Profile-Name=Konvergo
2020-04-13 15:45:42 [ DEBUG ] PlayerComponent.cpp @ 594 - cplayer: finished playback, unrecognized file format (reason 4)
2020-04-13 15:45:42 [ ERROR ] PlayerComponent.cpp @ 600 - cplayer: Failed to recognize file format.
2020-04-13 15:45:42 [ INFO ] PlayerComponent.cpp @ 596 - cplayer:
2020-04-13 15:45:42 [ INFO ] PlayerComponent.cpp @ 480 - “Entering state: error (unrecognized file format)”
2020-04-13 15:45:42 [ INFO ] DisplayManager.cpp @ 20 - “DisplayManager found 1 Display(s).”
2020-04-13 15:45:42 [ INFO ] DisplayManager.cpp @ 26 - “Available modes for Display #0 (Radeon RX 580 Series)”
Server log (the only line referencing to the error):
Apr 13, 2020 15:45:34.495 [1820] ERROR - [TranscodeOutputStream] Streaming Session 0x2ecf7d8 appears to have died from under us
