Conversion failed. The transcoder exited due to an error
Hi all,
PMS Version 1.20.4.3517
OS: Linux raspberrypi 5.4.51-v7+
Brand new PMS install.
I’m getting “Conversion failed. The transcoder exited due to an error” on every
single file.
I’ve verified permissions for the ~/Library branch as well as for the transcoder.
What logs to y’all need, and where can I send them so I don’t have to post them publicly?
Thanks,
Max
Going to need logs which capture it happening.
Check your PM
For the benefit of the community, this turned out to be my fault.
The setup:
Since I’m running PMS on a raspberry pi, I have a very limited / partition.
To get around this, I remapped the ~Library to an external drive.
In the root partition:
/var/lib/plexmediaserver has a symbolic link to the Library:
lrwxrwxrwx 1 plex plex 16 Oct 22 13:43 Library → /mnt/usb/Library
This worked fine for some files, but not for others.
Thanks to @ChuckPa, we found the issue.
The telltale lines in the log look like this:
Nov 12, 2020 11:09:48.194 [0x76f8fb20] WARN - [FFMPEG] - Error loading external lib: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/02cff92-3522-linux-armv7hf_neon/liblibx264_encoder.so: failed to map segment from shared object
Nov 12, 2020 11:09:48.197 [0x76f8fb20] WARN - [FFMPEG] - Error loading external lib: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/02cff92-3522-linux-armv7hf_neon/libh264_decoder.so: failed to map segment from shared object
Nov 12, 2020 11:09:48.202 [0x76f8fb20] WARN - [FFMPEG] - Error loading external lib: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/02cff92-3522-linux-armv7hf_neon/libmpeg4_decoder.so: failed to map segment from shared object
Nov 12, 2020 11:09:48.205 [0x76f8fb20] WARN - [FFMPEG] - Error loading external lib: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/02cff92-3522-linux-armv7hf_neon/libaac_encoder.so: failed to map segment from shared object
Nov 12, 2020 11:09:48.208 [0x76f8fb20] WARN - [FFMPEG] - Error loading external lib: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/02cff92-3522-linux-armv7hf_neon/libmp3_decoder.so: failed to map segment from shared object
And yep, turns out I didn’t have the ‘exec’ flag in my /etc/fstab. Some filesystems default to allowing exec, some don’t. Adding the exec flag fixed the issue:
/etc/fstab (old):
UUID=blah /mnt/usb ext3 defaults,auto,users,rw,nofail 0 0
/etc/fstab (new):
UUID=blah /mnt/usb ext3 defaults,auto,users,rw,exec,nofail 0 0
Thanks, @ChuckPa!
Max
