Server Version#: 1.25.5.5492 (for both Synology and Docker)
BLUF: I copied the content and settings of one Plex server to another, and trying to run both at the same time results in original server only showing up in Plex account.
I’m in the process of creating a new Plex server and copied the content and settings of my original Plex server which is running on a Synology NAS to an Unraid server, using a Plex docker, following the original support article as well as this reddit post:
Everything copied ok, and the new docker based Plex server runs well, however I want to run them both at the same time, until I’m ready to turn off the Synology based Plex server.
When I first installed the docker based Plex server, but before I copied the content and settings, my account showed both servers just fine (lets call them Synology and Docker) side by side. I shut down bother servers, copied the contents and settings, and made the necessary changes per the above article/post and when I brought up the Docker Plex Server, everything worked well, including showing the name correctly.
And then I turned on the Synology Plex server.
When both the Synology Plex server and the Docker Plex server are running, only the Synology Plex server shows in my account. If I shutdown the Synology Plex server and the Docker Plex server continues to run, then the Docker Plex server shows up.
I’m not sure how Plex identifies servers, but given I copied the contents and settings from Synology Plex server to Docker Plex server, this makes sense.
Really, I’m only interested in maintaining the following settings:
Custom movie collections and art work
Custom connections between movies and tv shows
User watch status for movies and tv shows
Everything else, I really don’t care about. I can reconnect users to the new Docker Plex server, if needed.
Does anyone know how to fix this problem?
I still have the original settings from the Docker Plex server (I renamed the original Docker Plex server “Library” folder, and copied over the Synology Plex server “Library” folder).
I guess, the real question is, are there changes I can make to the files I copied from the Synology Plex server, or should I go back to the original Docker Plex server files, and only copy certain aspects (i.e. folders and files) of the Synology Plex server files to the original Docker Plex server files?
Lastly, I made sure the servers are named differently in Account > Settings > General > Friendly name and set different ports in Account > Settings > Remote Access > Manual specify public port (and opened corresponding firewall ports).
Clear as mud? ![]()
Thanks in advance for any guidance!
