Okay I’m having a problem with getting cover art for tv shows. For some reason when I get news shows it won’t show the cover art for these new shows. It will show them for shows I all ready have. At this point I’m going to have to manually add them. I have tried updating the software, reinstalling it, logging out and back in and nothing is working and I’m getting super frustrated. Does any one know how to fix this.
update it won’t even let me add the cover arts in manually. Why does this have to be so bloody complicated.
See these posts:
forums.plex.tv/discussion/322382/tvdb-down-again-no-metadata-for-tv-shows-since-yesterday-morning/p2
forums.plex.tv/discussion/322382/tvdb-down-again-no-metadata-for-tv-shows-since-yesterday-morning#latest
It was an API problem with TVDB which resulted in Plex needing to update its meta data scraper. A fix should be out shortly.
btw im using Version 1.13.0.5023
The fix is out. Go update from Plex.tv/downloads then up. It should be build 5142 or there about
@ChuckPA is this fix in the pipeline for the official docker image also?
Thank you!
I would assume so but Docker is not my area. It’s best to ask in that forum. Presuming Docker is updated when this is released to public, I’d say you’ll probably see it then (again, i’m not familiar with docker)
