Server Version#:1.42.0.9975
I added some educational videos from YouTube as a custom TV Series and downloaded posters from the web. I add the poster to the video and it works fine - for awhile. But eventually the poster disappears from the content and is not available to select under Poster. Any idea why this might be happening and a fix? Note that
Would you mind elaborating your use case a bit?
Specifically… what do you mean by
Are you adding the poster as local media asset alongside the video file, or are you adding it via the Plex user interface?
