Covers for multidisc audio not shown
Server Version#: 1.18.2.2058
I have a 225 Mozart Cd set with this structure:
Wolfgang Amadeus Mozart
-AlbumName
–Disc 1
----track number 1.mp3
I do not see any picture while I was sure that I will see all including picture per disc.
I have Local assets enabled and first in the list.
Please advise
Let’s continue.
This issue occurs on Plex Media Files agent with Local Assets on top so I was under impression it should just work.
Issue still exists.
If you put all of those discs into the same album, then all will have the same cover.
Plex takes the name “Album Art” literally. There is only one cover per album.
I was sure it was working before migration to the Plex Music.
Another 2c, music should be similar to TV Show and every TV season can have its own cover/poster, right?
Anyway I have a cover.jpeg file as well inside whole Album directory and it is not shown.
There is a preference named “Album Art” in the properties of the music library (on the ‘Advanced’ tab).
If you are using subfolders for each disc, the folder.jpg/cover.jpg inside of Disc 1 is used.
In my case it is using cover from Disc 117 without any logic behind.
Why I cannot see my root art inside Album Art preference? Only discs are avaialable.
@OttoKerner can you create at least backlog item for that?
