I have read about people having similar issues, but can’t find where there is a solution…
I setup a HDHomeRun Prime with my Comcast cable card and a Roku (so I can watch live tv).
When I watch live TV, after a short period, the screen goes blank with “Retrieving 33%” and after it times out I get an error “Playback was terminated by server. Conversion failed. The transcoder crashed or failed to start up.”
Also, I can’t get anything to record for more than a few minutes.
I have tried all the settings I can find, but no luck… the point of me doing this is to get rid of my dish.
Plex Pass Subscriber
Plex Server Version: Version 1.11.0.4666
Roku and HDHomeRun is up to date…
I have logs, but not sure which ones will be most useful…
The zip file of the server logs please collected via Settings / Server / Help / Download Logs
To be collected after the failure
Ensuring that debug logging was enabled beforehand (settings / server / general / show advanced)
Please indicate time of failure when posting the zipped logs
There was a timeout on the request to the DVR - could be network issue ? DVR issue?
an 06, 2018 08:18:02.493 [0x81082a000] ERROR - [Transcoder] http://192.168.249.1:5004/auto/v222: Operation timed out
Jan 06, 2018 08:18:02.503 [0x80a40fc00] DEBUG - Jobs: '/usr/local/share/plexmediaserver-plexpass/Plex Transcoder' exit code for process 73817 is 0
Jan 06, 2018 08:18:03.607 [0x80c093000] ERROR - [Transcoder] [h264 @ 0x8028a7700] error while decoding MB 2 35, bytestream -14
Jan 06, 2018 08:18:03.841 [0x80a40fc00] DEBUG - Streaming Resource: Terminated session 0x80c8206e0:70438021a8a9d37dbb894c56071e8373 with reason Conversion failed. The transcoder crashed or failed to start up
Basically the transcoder was getting the stream from the DVR for that channel through http://192.168.249.1:5004/auto/v222 and it timed out
I’m having pretty regular crashes when watching LiveTV through PLex. Mac Mini server running Sierra OS X 10.12.8 and using a HD Homerun with a digital antennae.
