Server Version#: 1.31.1.6716
Player Version#: Web App 4.100.1
I have the Generate credits video markers set “as a scheduled task and when media is added.” However, it does not scan for credits during the scheduled task time (0:00 - 23:00), its only generating chapter thumbnails.
When manually analyzing the show or season, only the intros are being detected and not credits. How should I go on about this?
I would set to to the start in the nearest time in the future if you cannot wait. Like if the current time is 3:30 I would set to to 4:00, not change it to cover a time you are already in.
You can only manually analyze single episode or movie to kick off a manual credit detection.
I just tried doing single episode or movie, but I still see intro detection and no credit detection.
Can you grab the Plex Media info XML for one of them
25249.txt (18.5 KB)
I can’t send as .xml, so I copied and paste into txt.
it shows a credit marker here
<Marker final="1" id="118123" type="credits" startTimeOffset="2783734" endTimeOffset="2850816">
<Attributes id="118123" version="4"/>
</Marker>
startTimeOffset=“2783734” should be about the 46 minute mark
If i recall that show Invincible does not have regular intros and just a very short one randomly throughout depending on episode. To detect an intro it compares it to other episodes in a season to find it the common intro.
Intros also have some other cases where it will not detect them even if the same in every episode
https://support.plex.tv/articles/skip-content/
- Short intros of less than 20 seconds are ignored.
- Intros ending more than halfway into an episode will not be detected.
That one has an intro which should be a little bit more than a minute in.
<Marker id="118123" type="intro" startTimeOffset="62023" endTimeOffset="149764">
<Attributes id="118123"/>
</Marker>
but not a credits marker
That looks like Anime and I know nothing about that particular show but I believe I was told often anime can be difficult to detect credits due to them being often stylized quite a bit. Thought it is possible the credits detector just failed for that one for some other reason. I will pass that along to team to look into SPY x FAMILY
Okay, thank you very much!
