Custom Comskip Questions
Server Version#: 1.32.8.7639
Player Version#: Apple TV
Tuner Make/Model: Hdhomerun HDHR5-4K
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
I’m looking into a custom comskip. But I can’t find where comskip.ini is stored and also can’t find any comskip logs.
Running Plex on Synology DSM7.
Looked at /volume1/PlexMediaServer/AppData/Plex Media Server and don’t see any comskip items
Not sure on Synology, it will be with the installed binaries: /usr/lib/plexmediaserver/Resources/comskip.ini
You will need to make a DVR directory in your “/volume1/PlexMediaServer/AppData/Plex Media Server” to place your custom comskip.ini file. Be warned, if you have it set to process all files, during the maintenance window it will process all files.
https://support.plex.tv/articles/115003944134-removing-commercials/
Thanks for replying.
Finally found Plex comskip.ini on Synology at /volume1/@appstore/PlexMediaServer/Resources
Do you happen to know where Plex comskip puts its’ logs ?
I’ve looked in various Plex Media Server logs and don’t see anything specific to comskip.
It really only logs the invocation to the ‘Plex Media Server.log’. You would have to pick a file and run it externally to pull any diagnostics.
