Hi Everyone…
Looking for help or inspiration for making a Custom Plex Channel Script for Novice/intermediate.
I have done basic java and wsrm script work before, and can read 70-90% of a script and understand what each line corresponds to or is being told to do…
But… im wanting to make a custom live tv channel plugin for plex.
If i go back to the beginning a little bit to explain better, this has come from installing the plex offerings and finding the 3rd party user plugins. There isnt anything that is ideal as a whole plugin though, and i find myself switching between different plugins all the time.
So the idea:
Simple plugin that has links or tabs for the usual UK channels (i.e. bbc1, bbc2, bbc3, itv1, itv2, itv3, itv+1, channel 4, e4, channel 5, basically the freeview channels) and then i can also addon extra ones like picking from selected sources from LihatTV app or TVLand or FilmOn etc.
IF… a live tv guide is possible as the main screen and the tabs to each channel are down the side (like on sky or virgin tivo) then this would be great but otherwise just a blank app plugin that allows me to input the “name”, “tab photo image” and html link for the stream.
Any help would be appreciated
thanks
