Customizable Sweet Fade dB Level
I work for a radio station and love PlexAmp. I can create my own radio station in a pocket with Sweet Fades. When I have Loudness Leveling on, and the pre-amp up to +4, I can create great segues (Sweet Fades)… however… the quality of audio is degraded due to compression.
I’d love it if we could set a default dB intro and outro level - and even better - to do this for each individual track. If you set an outro level of -25dB, when the song begins to fade out, the next song begins when the volume drops below -25dB. This would allow custom sweet fades.
Thanks!
Set the preamp to 0dB and the limiter to off.
That way the only compression you’ll hear is the one that is already in the files.
Thanks for the reply! I’ve done that but the songs aren’t tight when transitioning. If we could set the dB level of the transition, when I’m playing Hey Jude, for example, it would segue much sooner. This is the only player that does segues and not crazy cross fades, so I’m very pleased, just looking to make it customizable.
