Server Version#: 1.19.3.2852
For the past 2 days the graph for bandwidth on the dashboard is not showing me all the data. It only reports at the 40 second mark.
This happens on both the local and hosted version of the web app.
My graph is still showing this way.
I noticed the same thing. This is due to the time difference between the system you are on and the Server’s local time. The PMS server is behind your local clock, hence the gap.
Sync your clocks and the graphs will line up again (until until time drifts apart again). Odd that only the bandwidth graph seems to experience this.
Recommend setting up all systems to sync time via pool.ntp.org
it’s built into most distros. Just need to enable it.
To augment: you can even add a country code to get only time servers which are geographically close to you, so that time sync is working faster and more reliable.
E.g. for Germany use de.pool.ntp.org
Thanks everyone. Setting up ca.pool.ntp.org fixed it.
