Data columns removed from episode list view
Server Version#: 1.18.0.1846
Player Version#: 1.3.1.916-1cb2c34d
When I go to my TV Shows library that the DVR feeds into, I like to show the latest added episodes and list their duration. This way I can check for failing recordings like the 9 minute episode of Bewitched you can see below. This was possible in the Plex Media Player and is still possible in the web app, but it is not possible (that I can see) in the new app. The options for what columns to show (and therefore what to sort by) have been severely reduced.
Old columns list:
New columns list:
Is there a reason for removing these options? Is there a way to get it back?
Thanks for any help!
Does nobody else use these columns? Can anyone confirm whether this change is intentional?
This is a screenshot from my DVR library, using version 1.4 of Plex for Windows
Thanks for the info. That means there’s hope the options aren’t going away altogether.
So are you saying when 1.4 is released it will be fixed? Or do you think something is wrong on my end and it should be working correctly on 1.3 as well?
I have plexpass downloads turned on and the current download for Plex for Windows says 1.3 still when I log in.
Plex for Windows v1.4 is being tested internally currently.
Same issue on Mac Player: 1.3.1.916-1cb2c34d
Server: 1.18.0.1913
Web player still has the columns.
You can try the Preview release:
