hello,
i’m trying to name/match DC SHOWCASE: Jonah Hex
i can’t use the year (2010) because it’s the same year as the movie Jonah Hex
starring Josh Brolin
i tried using TMDB, but i don’t see an ID number
any suggestions?
hello,
any suggestions?
Try: dc.showcase.jonah.hex.(2010)
You can also try: DC Showcase Jonah Hex {tmdb-41988}
That second line uses a trick to force a match - details here: Naming and organizing your Movie files | Plex Support
You can also do a “fix match” to pick the right Jonah Hex movie.
thanks for the reply
how did you find the TMDB ID#?
i didn’t it listed on TMDB
It appears in the URL of this movie’s page. The same as with IMDb IDs. DC Showcase: Jonah Hex (2010) — The Movie Database (TMDB)
thank you
