Debian Bullseye 5.16.12 , with Intel Core i5-11600K 4k HDR -> h264 SDR HW Transcode
Server Version#: PMS 1.29.2.6364
Player Version#: Plex Web Version 4.95.2 + Others
Apologies I can’t see how to disable Verbose Logging
Can anyone confirm if 4k HDR → 1080p SDR Hardware transcoding is working? I’ve found lots of unRAID posts discussing this with 11th Gen GPU but no definitive answer?
If I force a 1080p Remux to Transcode, Plex and intel_gpu_top reports GPU usage.
If I force a H265 HDR Remux to transcode, only software transcoding.
This is a relatively clean install of OMV6, bare metal PMS install. I have previously had an older CPU and P400 Nvidia so new to the Intel iGPU game.
Any help would be greatly appreciated.
Plex Media Server Logs_2022-11-27_17-41-03.zip (4.8 MB)
  1. Logging
    Server logging is in Settings - Server - General - Show Advanced .
    – Transcoder logging is:
    curl -X PUT http://127.0.0.1:32400/:/prefs/set\?TranscoderLogLevel=debug\&X-Plex-Token=$Token
  2. PMS sees your QSV ASIC. All is good here.
linux-x86_64/libac3_decoder.so
Nov 27, 2022 17:36:40.192 [0x7f9143a5bb38] DEBUG - [GPU] Got device: , intel@builtin, default true, best true, ID /dev/dri/renderD128, DevID [8086:4c8a:1458:d000], flags 0x1ce
Nov 27, 2022 17:36:40.192 [0x7f9143a5bb38] INFO - Preemptively preparing driver icr for GPU
Nov 27, 2022 17:36:40.197 [0x7f9143a5bb38] DEBUG - Grabber: Cleaning up orphaned grabs.
Nov 27, 2022 17:36:40.198 [0x7f9143555b38] DEBUG - MyPlex: mapping state set to 'Unknown'.
Nov 27, 2022 17:36:40.198 [0x7f9149ead0d0] DEBUG - Media Provider: Registering provider com.plexapp.plugins.library
Nov 27, 2022 17:36:40.198 [0x7f9149ead0d0] DEBUG - Auth: Refreshing tokens inside the token-based authentication filter.
Nov 27, 2022 17:36:40.199 [0x7f9143555b38] DEBUG - Relay: read 79 cached entries from hosts file
Vaapi is running correctly for you.
I do question what’s going on with “Lightyear”. May I see the mediainfo?
@ChuckPa Thanks for the quick reply; and info regarding Logging Info.
Please see below output from mediainfo:
General
Unique ID                                : 301493431951066392869626621956791824300 (0xE2D185DA5A8DAA2117509926BC7D6FAC)
Complete name                            : /srv/mergerfs/Pool/Movies/Lightyear (2022).mkv
Format                                   : Matroska
Format version                           : Version 2
File size                                : 37.9 GiB
Duration                                 : 1 h 45 min
Overall bit rate mode                    : Variable
Overall bit rate                         : 51.7 Mb/s
Movie name                               : Lightyear (2022)
Encoded date                             : UTC 2022-09-04 17:34:18
Writing application                      : MakeMKV v1.17.1 linux(x64-release)
Writing library                          : libmakemkv v1.17.1 (1.3.10/1.5.2) x86_64-linux-gnu
Cover                                    : Yes
Attachments                              : cover.jpg
Video
ID in the original source medium         : 4113 (0x1011)
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L5.1@High
HDR format                               : SMPTE ST 2086, HDR10 compatible
Codec ID                                 : V_MPEGH/ISO/HEVC
Bit rate                                 : 44.4 Mb/s
Width                                    : 3 840 pixels
Height                                   : 2 160 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.223
Stream size                              : 32.6 GiB (86%)
Writing library                          : ATEME Titan File 3.9.6 (4.9.6.2)
Language                                 : English
Default                                  : No
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : BT.2020
Mastering display luminance              : min: 0.0050 cd/m2, max: 1000 cd/m2
Original source medium                   : Blu-ray
Audio #1
ID in the original source medium         : 4352 (0x1100)
Format                                   : MLP FBA 16-ch
Format/Info                              : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name                          : Dolby TrueHD with Dolby Atmos
Codec ID                                 : A_TRUEHD
Bit rate mode                            : Variable
Bit rate                                 : 3 648 kb/s
Maximum bit rate                         : 4 437 kb/s
Channel(s)                               : 8 channels
Channel layout                           : L R C LFE Ls Rs Lb Rb
Sampling rate                            : 48.0 kHz
Frame rate                               : 1 200.000 FPS (40 SPF)
Bit depth                                : 24 bits
Compression mode                         : Lossless
Stream size                              : 2.68 GiB (7%)
Title                                    : Surround 7.1
Language                                 : English
Default                                  : Yes
Forced                                   : No
Number of dynamic objects                : 13
Bed channel count                        : 1 channel
Bed channel configuration                : LFE
Audio #2
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Commercial name                          : Dolby Digital
Codec ID                                 : A_AC3
Bit rate mode                            : Constant
Bit rate                                 : 640 kb/s
Channel(s)                               : 6 channels
Frame rate                               : 31.250 FPS (1536 SPF)
Compression mode                         : Lossy
Stream size                              : 481 MiB (1%)
Title                                    : Surround 5.1
Language                                 : English
Service kind                             : Complete Main
Default                                  : No
Forced                                   : No
Audio #3
Format                                   : E-AC-3
Format/Info                              : Enhanced AC-3
Commercial name                          : Dolby Digital Plus
Format profile                           : Blu-ray Disc
Codec ID                                 : A_EAC3
Bit rate                                 : 1 024 kb/s
Stream size                              : 770 MiB (2%)
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #4
ID in the original source medium         : 4353 (0x1101)
Format                                   : AC-3
Codec ID                                 : A_AC3
Bit rate                                 : 576 kb/s
Stream size                              : 433 MiB (1%)
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #5
ID in the original source medium         : 4354 (0x1102)
Format                                   : AC-3
Codec ID                                 : A_AC3
Bit rate                                 : 640 kb/s
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #6
ID in the original source medium         : 4355 (0x1103)
Format                                   : AC-3
Codec ID                                 : A_AC3
Bit rate                                 : 320 kb/s
Channel(s)                               : 2 channels
Stream size                              : 241 MiB (1%)
Title                                    : Stereo
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #7
ID in the original source medium         : 4356 (0x1104)
Format                                   : AC-3
Codec ID                                 : A_AC3
Bit rate                                 : 320 kb/s
Title                                    : Stereo
Language                                 : English
Default                                  : No
Forced                                   : No
Text
ID in the original source medium         : 4768 (0x12A0)
Format                                   : PGS
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : Picture based subtitle format used on BDs/HD-DVDs
Duration                                 : 1 h 44 min
Bit rate                                 : 51.3 kb/s
Count of elements                        : 4152
Stream size                              : 38.4 MiB (0%)
Language                                 : English
Default                                  : No
Forced                                   : No
Menu
00:00:00.000                             : en:Chapter 01
00:04:43.616                             : en:Chapter 02
00:06:47.949                             : en:Chapter 03
00:08:12.825                             : en:Chapter 04
00:09:33.739                             : en:Chapter 05
00:11:58.384                             : en:Chapter 06
00:15:27.176                             : en:Chapter 07
00:18:05.042                             : en:Chapter 08
00:20:40.697                             : en:Chapter 09
00:22:34.269                             : en:Chapter 10
00:24:37.017                             : en:Chapter 11
00:25:41.581                             : en:Chapter 12
00:27:01.202                             : en:Chapter 13
00:30:53.268                             : en:Chapter 14
00:32:02.503                             : en:Chapter 15
00:33:32.927                             : en:Chapter 16
00:34:23.311                             : en:Chapter 17
00:36:56.797                             : en:Chapter 18
00:39:14.185                             : en:Chapter 19
00:41:55.596                             : en:Chapter 20
00:45:29.226                             : en:Chapter 21
00:50:28.692                             : en:Chapter 22
00:51:37.928                             : en:Chapter 23
00:54:22.842                             : en:Chapter 24
00:57:55.346                             : en:Chapter 25
01:02:11.269                             : en:Chapter 26
01:04:26.320                             : en:Chapter 27
01:07:35.843                             : en:Chapter 28
01:09:15.609                             : en:Chapter 29
01:10:32.770                             : en:Chapter 30
01:11:25.572                             : en:Chapter 31
01:15:37.824                             : en:Chapter 32
01:16:45.392                             : en:Chapter 33
01:17:44.076                             : en:Chapter 34
01:25:18.822                             : en:Chapter 35
01:27:10.683                             : en:Chapter 36
01:29:00.960                             : en:Chapter 37
01:30:42.186                             : en:Chapter 38
01:33:45.411                             : en:Chapter 39
01:36:02.381                             : en:Chapter 40
01:43:35.500                             : en:Chapter 41
Your HW transcoding is suppressed because the subtitles are present in the file AND the player did not expressly exclude them.
Software merging of the images (subtitle and video) is needed.
The HW decode is there but encode is suppressed from displaying.
You’re seeing the impact of merging the two video planes in software.
If you set to “automatic”, which is best, you’ll get this behavior.
The challenge to you comes in how you curate the media. Do you need the PGS subtitles ? If you don’t, I recommend you remove them.
Thanks for the quick reply again.
When you say Automatic do you mean Video Quality or Settings → Language → Automatically Select… ?
Is the Subtitle issue a H265 → H264 issue or a Intel QSV issue? Reason I ask is I have a H264 1080p Bluray Remux with PGS subtitles that will hw transcode perfectly; and when I had a Nvidia P400 the CPU was not powerful enough to direct play H265 / HDR content and therefor must have been able to hw transcode H265 + PGS subtitles as I never noticed any issues?
This maybe related but this morning while away from home on 4G Cellular (i.e. must have been transcoding!) Plex would play 1080p H264 + PGS ( No subtitles selected) but Transcoder failed on both a H265 ( Lightyear again) and a Dolby Vision ( Profile 7 with HDR) (Bullet Train). Logs attached ( now set to debug :slight_smile: ) and media info attached. Player: Plex for iOS V8.11.1
Bullet Train - HEVC
General
Unique ID                                : 148383431332496215445727736171436181141 (0x6FA19BFF5F3E56C8A90709A5B5DC0695)
Complete name                            : /srv/mergerfs/Pool/Movies/Bullet Train (2022).mkv
Format                                   : Matroska
File size                                : 69.0 GiB
Duration                                 : 2 h 6 min
Overall bit rate                         : 78.1 Mb/s
Movie name                               : Bullet Train
Encoded date                             : UTC 2022-11-01 09:58:20
Cover                                    : Yes
Video
Format                                   : HEVC
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 68.9 Mb/s
Color space                              : YUV
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.346
Stream size                              : 60.9 GiB (88%)
Language                                 : English
Default                                  : No
Forced                                   : No
Mastering display color primaries        : Display P3
Mastering display luminance              : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 1038 cd/m2
Maximum Frame-Average Light Level        : 395 cd/m2
Audio #1
Codec ID                                 : A_TRUEHD
Bit rate                                 : 3 843 kb/s
Maximum bit rate                         : 6 990 kb/s
Bit depth                                : 24 bits
Stream size                              : 3.40 GiB (5%)
Language                                 : English
Default                                  : Yes
Forced                                   : No
Number of dynamic objects                : 11
Audio #2
Format                                   : AC-3
Codec ID                                 : A_AC3
Bit rate                                 : 640 kb/s
Stream size                              : 579 MiB (1%)
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #3
Format                                   : DTS XLL
Format/Info                              : Digital Theater Systems
Commercial name                          : DTS-HD Master Audio
Codec ID                                 : A_DTS
Bit rate                                 : 2 234 kb/s
Channel layout                           : C L R Ls Rs LFE
Frame rate                               : 93.750 FPS (512 SPF)
Bit depth                                : 16 bits
Stream size                              : 1.97 GiB (3%)
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #4
Format                                   : DTS
Codec ID                                 : A_DTS
Bit rate                                 : 1 509 kb/s
Bit depth                                : 16 bits
Stream size                              : 1.33 GiB (2%)
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #5
Format                                   : AC-3
Codec ID                                 : A_AC3
Bit rate                                 : 640 kb/s
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #6
ID in the original source medium         : 4359 (0x1107)
Format                                   : AC-3
Codec ID                                 : A_AC3
Bit rate                                 : 192 kb/s
Stream size                              : 174 MiB (0%)
Title                                    : Stereo
Language                                 : English
Default                                  : No
Forced                                   : No
Text #1
Format                                   : PGS
Duration                                 : 1 h 58 min
Bit rate                                 : 36.7 kb/s
Count of elements                        : 3174
Stream size                              : 31.1 MiB (0%)
Language                                 : English
Default                                  : No
Forced                                   : No
Text #2
Format                                   : PGS
Duration                                 : 1 h 54 min
Bit rate                                 : 1 359 b/s
Count of elements                        : 154
Stream size                              : 1.11 MiB (0%)
Language                                 : English
Default                                  : Yes
Forced                                   : Yes
Text #3
ID in the original source medium         : 4769 (0x12A1)
Format                                   : PGS
Duration                                 : 2 h 2 min
Bit rate                                 : 41.0 kb/s
Count of elements                        : 3720
Stream size                              : 35.9 MiB (0%)
Language                                 : English
Default                                  : No
Forced                                   : No
Text #4
ID in the original source medium         : 4783 (0x12AF)
Format                                   : PGS
Bit rate                                 : 64.4 kb/s
Count of elements                        : 4684
Stream size                              : 58.3 MiB (0%)
Language                                 : English
Default                                  : No
Forced                                   : No
Menu
00:07:30.366                             : en:Chapter 02
00:14:58.439                             : en:Chapter 03
00:21:59.860                             : en:Chapter 04
00:30:31.162                             : en:Chapter 05
00:38:59.003                             : en:Chapter 06
00:47:24.258                             : en:Chapter 07
00:54:30.600                             : en:Chapter 08
01:01:24.263                             : en:Chapter 09
01:09:27.830                             : en:Chapter 10
01:15:58.387                             : en:Chapter 11
01:22:23.563                             : en:Chapter 12
01:29:35.078                             : en:Chapter 13
01:36:52.014                             : en:Chapter 14
01:43:45.093                             : en:Chapter 15
01:53:58.164                             : en:Chapter 16
root@colossus:~# mediainfo /srv/mergerfs/Pool/Movies/Bullet\ Train\ \(2022\).mkv
General
Format                                   : Matroska
Cover                                    : Yes
Video
Format                                   : HEVC
Color space                              : YUV
Bit depth                                : 10 bits
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #1
Codec ID                                 : A_TRUEHD
Bit depth                                : 24 bits
Language                                 : English
Default                                  : Yes
Forced                                   : No
Audio #2
Format                                   : AC-3
Codec ID                                 : A_AC3
Bit rate                                 : 640 kb/s
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #3
Format                                   : DTS XLL
Codec ID                                 : A_DTS
Bit depth                                : 16 bits
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #4
Format                                   : DTS
Codec ID                                 : A_DTS
Bit depth                                : 16 bits
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #5
Format                                   : AC-3
Codec ID                                 : A_AC3
Bit rate                                 : 640 kb/s
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #6
Format                                   : AC-3
Codec ID                                 : A_AC3
Bit rate                                 : 192 kb/s
Title                                    : Stereo
Language                                 : English
Default                                  : No
Forced                                   : No
Text #1
Format                                   : PGS
Language                                 : English
Default                                  : No
Forced                                   : No
Text #2
Format                                   : PGS
Language                                 : English
Default                                  : Yes
Forced                                   : Yes
Text #3
Format                                   : PGS
Language                                 : English
Default                                  : No
Forced                                   : No
Text #4
Format                                   : PGS
Language                                 : English
Default                                  : No
Forced                                   : No
Menu
Mitchells vs the Machines
General
Unique ID                                : 39882926626594884547728943862682801363 (0x1E012C199FD236D97506B93E8994D4D3)
Complete name                            : /srv/mergerfs/Pool/Movies/Mitchells vs the Machines (2021).mkv
Format                                   : Matroska
File size                                : 20.0 GiB
Duration                                 : 1 h 49 min
Overall bit rate                         : 26.1 Mb/s
Movie name                               : Mitchells vs the Machines (2021).mkv
Encoded date                             : UTC 2022-11-16 09:51:06
Cover                                    : Yes
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings                          : CABAC / 2 Ref Frames
Format settings, CABAC                   : Yes
Format settings, Reference frames        : 2 frames
Format settings, GOP                     : M=1, N=10
Codec ID                                 : V_MPEG4/ISO/AVC
Bit rate                                 : 21.8 Mb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Color space                              : YUV
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.438
Stream size                              : 16.7 GiB (84%)
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #1
Format                                   : DTS XLL
Codec ID                                 : A_DTS
Bit rate                                 : 2 207 kb/s
Bit depth                                : 16 bits
Stream size                              : 1.69 GiB (8%)
Language                                 : English
Default                                  : Yes
Forced                                   : No
Audio #2
Format                                   : DTS
Codec ID                                 : A_DTS
Bit depth                                : 16 bits
Stream size                              : 1.16 GiB (6%)
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #3
Format                                   : AC-3
Codec ID                                 : A_AC3
Bit rate                                 : 192 kb/s
Stream size                              : 151 MiB (1%)
Title                                    : Stereo
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #4
ID in the original source medium         : 4357 (0x1105)
Format                                   : AC-3
Codec ID                                 : A_AC3
Bit rate                                 : 192 kb/s
Title                                    : Stereo
Language                                 : English
Default                                  : No
Forced                                   : No
Text #1
ID in the original source medium         : 4608 (0x1200)
Format                                   : PGS
Duration                                 : 1 h 48 min
Bit rate                                 : 38.2 kb/s
Count of elements                        : 2961
Stream size                              : 29.7 MiB (0%)
Language                                 : English
Default                                  : No
Forced                                   : No
Text #2
ID in the original source medium         : 4609 (0x1201)
Format                                   : PGS
Bit rate                                 : 44.4 kb/s
Count of elements                        : 3384
Stream size                              : 34.6 MiB (0%)
Language                                 : English
Default                                  : No
Forced                                   : No
Text #3
ID in the original source medium         : 4625 (0x1211)
Format                                   : PGS
Bit rate                                 : 76.9 kb/s
Count of elements                        : 4204
Stream size                              : 60.1 MiB (0%)
Language                                 : English
Default                                  : No
Forced                                   : No
Menu
00:06:15.708                             : en:Chapter 02
00:14:18.482                             : en:Chapter 03
00:18:56.260                             : en:Chapter 04
00:24:53.575                             : en:Chapter 05
00:31:55.663                             : en:Chapter 06
00:36:30.271                             : en:Chapter 07
00:45:44.742                             : en:Chapter 08
00:49:55.117                             : en:Chapter 09
00:54:17.003                             : en:Chapter 10
01:02:29.829                             : en:Chapter 11
01:08:49.333                             : en:Chapter 12
01:15:51.505                             : en:Chapter 13
01:25:21.032                             : en:Chapter 14
01:30:31.676                             : en:Chapter 15
01:38:45.294                             : en:Chapter 16
Plex Media Server Logs_2022-11-28_07-51-48.zip (1.7 MB)
Subtitle handling: Automatic, Burn Always, Burn image formats.
You want automatic. If you have either of the other two, the burn is forced.
Subtitles are subtitles; independent of source / target.
" The CPU was not powerful enough to Direct Play H265 / HDR … "
Can you please clarify / add detail to this?
  1. An ARMv7 CPU can DirectPlay HEVC HDR with PGS subtitles
  2. DirectPlay = Read the file off the disk – Send exactly as it is without any processing.
See why your statement & question is unclear to me?
Of course I can; apologies!
So I only use Subtitles when “Forced” is selected ( i.e Foreign Audio in parts). In both Plex Web and iOS Subtitles are selected to “Automatic”.
As you rightly state, any of my devices will Direct Play; however with my previous build of Intel Atom D525 + Nvidia P400 if I selected / needed to Transcode a H265/HEVC video it would use HW for this. ( To be explicit no subtitles selected - but PGS within the source file). The CPU was not capable of Transcoding H265 / HEVC.
Now on my new build; direct play works across all devices, but when I attempt to Transcode a H265 / HEVC ( no subtitles selected, PGS stream in source) it falls back to software. This is compared to Transcoding a H264 file ( no subtitles selected, PGS present in source) which successfully transcodes in HW.
Have I made that more, or less clear? :slight_smile:
UPDATE:
I updated my Kernel to Proxmox Linux 5.19.17-1-pve and installed the package discussed in another post / forum here.
I can now use HW transcoding from HEVC to H264. Screenshot attached.
@ChuckPa Let me know if logs would be helpful / needed. I’m presuming changes in this beta release will be detailed in the upstream Release Note when merged?
@alxscott
If you’re running – all good then. I won’t need anything else.
Engineering always publishes the release notes (even with Beta) in the PMS Announcements section of the forum.
@ChuckPa :+1:t3:
Thanks for taking the time to assist!
