So far so good on this DEV build - no crashes thus far.
is the build still working for you @Tophicles
Yup! So far no crashes at all.
I have been getting crashes daily when running the latest version Version 1.15.8.1198.
Is it possible for me to try the dev build? I can supply logs of crashes as well if thatās any help.
I cannot see any uploaded crash reports linked to your account for a 1.15.x server. I see that you are currently on 1.14.1.5488. It appears to be docker install.
Even if I found crash reports for your server, it would not be straightforward for me to offer and you to install a development build for the docker environment
Iād have to say I agree - Iām running pure Debian and Iām not sure what would happen with an experimental build in another, containerized environment. Also, I would assume the dev build was given to me to test and not distribute.
Thanks for the reply.
Yes the account made with this forum user isnāt the one I was referring to. I have my server running under a different email although it hasnāt crashed in ~24 hours, will see how long it holds out for.
The username for the account that crashes is ebahaf (just added that username). Or maybe you can see which one via
MachineIdentifier=ā936cee00-2262-4079-aea3-0fa266687ce5ā
you are giving me a puzzle !
A MachineIdentifier for server gets converted to ProcessedMachineIdentifier before use
with regards to plex.tv account ebahaf there are no crash reports linked to the email account that I can see currently for this plex.tv account
In any case, the servers that are linked to this account appear to be running docker - it would not be straightforward to offer you a development build for docker. Sorry
Okay docker does complicate things a little bit, thanks for the information and hopefully the dev build will do the trick.
The fix is out already. I will post below
Plex Media Server Beta 1.16.0.1220-147963d87 has just been released with the crashes fix
See release note Plex Media Server
- (Playback) The server could crash when a transcode session finished. These manifested as heap corruptions or double-frees (#9801 #9883 #9938 #9940 #9950)
Well I was hoping the 1.16 update would fix my crashes. Sadly it hasnt
