Debugging setup failures
tried attaching the log file and error msg -
Error You aren't permitted to upload this kind of file
May be too big or attaching Plex media server.log,1 rather than Plex media server.log (latest)
Copy logs folder out with sub folders and then zip the logs folders and attach the zip
hi,
I've been having other isses with my laptop and decided to restore it to its factory state.
I have now been able to install Plex with no issues!!! yay
thanks for your suggestion regarding my issues
cheers
Quirkyy
Hi. I installed Plex and received the "A problem has been detected with a core component of Plex Media Server." I have restarted and re-installed Plex.I also deleted the System and Framework bundles. I was able to run Plex once and linked it to my movies. However, I have since only received the error message and am unable to link to the TVShows file. Attached are my log files. Any suggestions?
Loads of errors on attempting requests to 127.0.0.1:32400
The error is always
URLError:
Could you look what firewall / security add-ons you have and make sure the firewall has inbound rule for tcp port 32400 for all network profiles
sa2000 - Thank you helping. I created a rule in the firewall allowing inbound and outbound communication for all network profiles. Unfortunately, that didn't work. Then I tried turning off my firewall and anti-virus software. No luck. I Googled the issue and found a suggestion to create a static IP and set up a port forwarding rule. That didn't work either. My final attempt was uninstall Plex, download a fresh file from the Plex website and do another install. No success. I've attached my latest logs after the re-install. Any suggestions?
still exactly the same. Loads of same error as before
2015-01-25 19:51:29,750 (1cb0) :  INFO (logkit:16) - Failed to fetch Plex Online data - the store probably won't work
2015-01-25 19:51:29,750 (1cb0) :  CRITICAL (core:577) - Error info (most recent call last):
  File "C:\Users\Mark and Becky\AppData\Local\Plex Media Server\Plug-ins\System.bundle\Contents\Code\storeservice.py", line 397, in update
    if Platform.MachineIdentifier == None:
  File "C:\Users\Mark and Becky\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\api\runtimekit.py", line 477, in MachineIdentifier
    return self._core.get_server_attribute('machineIdentifier')
  File "C:\Users\Mark and Becky\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\core.py", line 512, in get_server_attribute
    root_xml = self.data.xml.from_string(self.networking.http_request('http://127.0.0.1:32400'))
  File "C:\Users\Mark and Becky\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\components\data.py", line 150, in from_string
    ud = UnicodeDammit(str(string), isHTML=isHTML)
etworking.py", line 247, in __str__
    self.load()
etworking.py", line 187, in load
    f = self._opener.open(req, timeout=self._timeout)
  File "C:\Program Files (x86)\Plex\Plex Media Server\python27.zip\urllib2.py", line 404, in open
    response = self._open(req, data)
  File "C:\Program Files (x86)\Plex\Plex Media Server\python27.zip\urllib2.py", line 422, in _open
    '_open', req)
  File "C:\Program Files (x86)\Plex\Plex Media Server\python27.zip\urllib2.py", line 382, in _call_chain
    result = func(*args)
  File "C:\Program Files (x86)\Plex\Plex Media Server\python27.zip\urllib2.py", line 1214, in http_open
    return self.do_open(httplib.HTTPConnection, req)
  File "C:\Program Files (x86)\Plex\Plex Media Server\python27.zip\urllib2.py", line 1184, in do_open
    raise URLError(err)
URLError: <urlopen error [Errno 10061] No connection could be made because the target machine actively refused it
which firewall and which anti virus software?    Any anti malware security product? Any privacy product?
Check hosts file contents for any additions
c:\windows\system32\drivers\etc\hosts
check control panel / internet options / connect tab for any proxy settings that may have slipped in
Any vpn ?
something is blocking the requests
When you launch the Media Server, is there a tray icon? If you navigate to http://localhost:32400/web/ you should be able to manage your server.
when I use this link that you provided, I can see my server and all my media.
However, I have no server Icon in any tray and when I sign into plex (both the website and the app for chrome) it says I have no servers and asks me to begin download. What is the fix for this please. I really really want to believe in Plex..... I just can't get it to work.
Running windows 7 64 bit
Need to dissect what you are saying to understand exactly what it is
So when you open a browser and put url:
localhost:32400/web
it opens up Plex/Web App screen and does show your server name on the left column and lists your library sections and you can click on the library section and see the media you have added ?  is this right ?
Are you running Plex Media Server as a Service ?
When you load Windows Task Manager and select Processes tab, do you see process named 'Plex Media Server.exe *32' running ?
If not, when you click 'Show Processes from All Users' button, does a Plex Media Server.exe *32 show up now ?
Could you find this file and upload it using 'More Reply Options' and Attach File
C:\Users\XXXXX\AppData\Local\Plex Media Server\Logs\Plex Media Server.log
where XXXXXX is the windows user name you launched Plex Media Server.exe in
when I sign into plex (both the website and the app for chrome) it says I have no servers and asks me to begin download. .
So you are saying here - if you go to localhost:32400/web in a browser you see your server but if you go to plex.tv/web you do not see the server?
I do not understand what you mean by the app for chrome - please expand.
Could you do the following
Go to this url
localhost:32400/web
Click on Settings
Do you see Web Server Users Devices buttons?
Click on Server
Click on Connect in left column
Click on Show Advanced
Sign in to your plex.tv account within this Settings / Connect page
(Related Support pages are:  Connect   Connecting a Server   Troubleshooting)
Could you now load plex.tv/web and sign in with the same account you used to sign the server through on the connect page
do you see the server now?
Upload another copy of
Hi, today after a version update Plex is not starting, also I can not repair or install again.
This is inside the log file:
[0A68:13C4][2015-02-20T19:06:35]i001: Burn v3.8.1128.0, Windows v6.1 (Build 7601: Service Pack 1), path: C:\Users\Juan\Downloads\Plex-Media-Server-0.9.1112.869-ab1cd47-en-US.exe, cmdline: '-burn.unelevated BurnPipe.{C1DBCD65-BDAE-4D54-93CB-217A41BB4CAA} {12866BE1-9716-46B1-9075-05701088A115} 4296'
[0A68:13C4][2015-02-20T19:06:35]i000: Initializing string variable 'InstallFolder' to value '[ProgramFilesFolder]Plex\Plex Media Server'
[0A68:13C4][2015-02-20T19:06:35]i000: Initializing string variable 'LaunchTarget' to value '[InstallFolder]\Plex Media Server.exe'
[0A68:13C4][2015-02-20T19:06:36]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\Juan\AppData\Local\Temp\Plex Media Server_20150220190636.log'
[0A68:13C4][2015-02-20T19:06:36]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\Juan\Downloads\Plex-Media-Server-0.9.1112.869-ab1cd47-en-US.exe'
[0A68:13C4][2015-02-20T19:06:36]i052: Condition '(VersionNT >= v6.0)' evaluates to true.
[0A68:13C4][2015-02-20T19:06:36]i100: Detect begin, 1 packages
[0A68:13C4][2015-02-20T19:06:36]i101: Detected package: pms, state: Present, cached: Complete
[0A68:13C4][2015-02-20T19:06:36]i199: Detect complete, result: 0x0
[0A68:13C4][2015-02-20T19:06:37]i200: Plan begin, 1 packages, action: Repair
[0A68:13C4][2015-02-20T19:06:37]i000: Setting string variable 'WixBundleLog_pms' to value 'C:\Users\Juan\AppData\Local\Temp\Plex Media Server_20150220190636_0_pms.log'
[0A68:13C4][2015-02-20T19:06:37]i201: Planned package: pms, state: Present, default requested: Repair, ba requested: Repair, execute: Repair, rollback: None, cache: No, uncache: No, dependency: Register
[0A68:13C4][2015-02-20T19:06:37]i299: Plan complete, result: 0x0
[0A68:13C4][2015-02-20T19:06:37]i300: Apply begin
[10C8:1254][2015-02-20T19:06:37]i360: Creating a system restore point.
[10C8:1254][2015-02-20T19:06:37]w363: Could not create system restore point, error: 0x80070422. Continuing...
[10C8:07D8][2015-02-20T19:06:38]i304: Verified existing payload: pms at path: C:\ProgramData\Package Cache\{89ED61CD-241D-4281-AD16-FCD6A9B13653}v0.9.1112\pms.msi.
[10C8:1254][2015-02-20T19:06:38]i323: Registering package dependency provider: {89ED61CD-241D-4281-AD16-FCD6A9B13653}, version: 0.9.1112, package: pms
[10C8:1254][2015-02-20T19:06:38]i301: Applying execute package: pms, action: Repair, path: C:\ProgramData\Package Cache\{89ED61CD-241D-4281-AD16-FCD6A9B13653}v0.9.1112\pms.msi, arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7" INSTALLLOCATION="C:\Program Files\Plex\Plex Media Server"'
[10C8:1254][2015-02-20T19:06:38]e000: Error 0x80070654: Failed to run maintanance mode for MSI package.
[10C8:1254][2015-02-20T19:06:38]e000: Error 0x80070654: Failed to execute MSI package.
[0A68:13C4][2015-02-20T19:06:38]e000: Error 0x80070654: Failed to configure per-machine MSI package.
[0A68:13C4][2015-02-20T19:06:38]i319: Applied execute package: pms, result: 0x80070654, restart: None
[0A68:13C4][2015-02-20T19:06:38]e000: Error 0x80070654: Failed to execute MSI package.
[0A68:13C4][2015-02-20T19:06:38]i399: Apply complete, result: 0x80070654, restart: None, ba requested restart:  No
Is Windows User Account 'Juan' an administrator account ie in the Administrators group?
What anti malware ? Anti virus ? security software do you run?
There are two log files created during the install. one is the above and a more detailed one
This is normally too big for the forum and need to be zipped and uploaded to service like Dropbox and link added here
Yes , user Juan is admin
I ise sophos antivirus, but I tried also disconecting the antivirus
Tonight I will upload the other log file
Ought to also double check the download file - unlikely it is the cause of an issue with such an error code - but no harm
So right click on
and select Properties and we need to see a 'Digital Signatures' tab present and for it to have a Plex Inc entry
If not, ,means incomplete download
So suggest repeating the install with Sophos Anti Virus disabled.
If it fails, capture both of the new log files. They would be named
C:\Users\Juan\AppData\Local\Temp\Plex Media Server_yyyymmddhhmmss_0_pms.log'
C:\Users\Juan\AppData\Local\Temp\Plex Media Server_yyyymmddhhmmss.log'
This is Plex Media Server_20150221234329_0_pms
=== Verbose logging started: 21/02/2015  23:43:31  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\ProgramData\Package Cache\{83d0d77a-f612-45cd-b2dc-f8c8548447a0}\pms.exe ===
MSI (c) (40:80) [23:43:31:667]: Resetting cached policy values
MSI (c) (40:80) [23:43:31:667]: Machine policy value 'Debug' is 0
MSI (c) (40:80) [23:43:31:667]: ******* RunEngine:
           ******* Product: {89ED61CD-241D-4281-AD16-FCD6A9B13653}
           ******* Action:
           ******* CommandLine: **********
MSI (c) (40:80) [23:43:31:667]: Client-side and UI is none or basic: Running entire install on the server.
MSI (c) (40:80) [23:43:31:667]: Grabbed execution mutex.
MSI (c) (40:80) [23:43:31:698]: Cloaking enabled.
MSI (c) (40:80) [23:43:31:698]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (40:80) [23:43:31:714]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (6C:CC) [23:43:31:714]: Running installation inside multi-package transaction {89ED61CD-241D-4281-AD16-FCD6A9B13653}
MSI (s) (6C:CC) [23:43:31:714]: Grabbed execution mutex.
MSI (s) (6C:54) [23:43:31:714]: Resetting cached policy values
MSI (s) (6C:54) [23:43:31:714]: Machine policy value 'Debug' is 0
MSI (s) (6C:54) [23:43:31:714]: ******* RunEngine:
           ******* Action:
MSI (s) (6C:54) [23:43:31:714]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (6C:54) [23:43:31:729]: Note: 1: 2262 2: _StringPool 3: -2147287038
MSI (s) (6C:54) [23:43:31:729]: Note: 1: 2219 2:  3:  4:
MSI (s) (6C:54) [23:43:31:729]: End dialog not enabled
MSI (s) (6C:54) [23:43:31:729]: Original package ==> C:\Windows\Installer\1d14c.msi
MSI (s) (6C:54) [23:43:31:729]: Package we're running from ==> C:\Windows\Installer\1d14c.msi
DEBUG: Error 2219:  Database: . Invalid Installer database format
1: 2219 2:  3:  4:
MSI (s) (6C:54) [23:43:31:729]: Note: 1: 1708
MSI (s) (6C:54) [23:43:31:729]: Producto:  -- Error en la instalación.
MSI (s) (6C:54) [23:43:31:729]: Windows Installer instaló el producto. Nombre del producto: . Versión del producto: . Idioma del producto: . Fabricante: . Resultado de la instalación: 1620.
MSI (s) (6C:54) [23:43:31:729]: MainEngineThread is returning 1620
No se puede abrir este paquete de instalación. Póngase en contacto con el fabricante de la aplicación para comprobar que es un paquete de Windows Installer válido.
MSI (s) (6C:CC) [23:43:31:729]: User policy value 'DisableRollback' is 0
MSI (s) (6C:CC) [23:43:31:729]: Machine policy value 'DisableRollback' is 0
MSI (s) (6C:CC) [23:43:31:729]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (6C:CC) [23:43:31:729]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (6C:CC) [23:43:31:729]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\InProgress 3: 2
MSI (s) (6C:CC) [23:43:31:729]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
MSI (s) (6C:CC) [23:43:31:729]: Restoring environment variables
MSI (c) (40:80) [23:43:31:729]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
MSI (c) (40:80) [23:43:31:729]: MainEngineThread is returning 1620
=== Verbose logging stopped: 21/02/2015  23:43:31 ===
And this Plex Media Server_20150221234329
[1328:1144][2015-02-21T23:43:29]i001: Burn v3.8.1128.0, Windows v6.1 (Build 7601: Service Pack 1), path: C:\ProgramData\Package Cache\{83d0d77a-f612-45cd-b2dc-f8c8548447a0}\pms.exe, cmdline: '/uninstall -burn.unelevated BurnPipe.{A4BAB280-A132-434C-94A9-450794251DD5} {E51894CC-25B8-4311-864D-B0E2F29A89CD} 2112'
[1328:1144][2015-02-21T23:43:29]i000: Initializing string variable 'InstallFolder' to value '[ProgramFilesFolder]Plex\Plex Media Server'
[1328:1144][2015-02-21T23:43:29]i000: Initializing string variable 'LaunchTarget' to value '[InstallFolder]\Plex Media Server.exe'
[1328:1144][2015-02-21T23:43:29]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\Juan\AppData\Local\Temp\Plex Media Server_20150221234329.log'
[1328:1144][2015-02-21T23:43:29]i052: Condition '(VersionNT >= v6.0)' evaluates to true.
[1328:1144][2015-02-21T23:43:29]i100: Detect begin, 1 packages
[1328:1144][2015-02-21T23:43:29]i101: Detected package: pms, state: Present, cached: Complete
[1328:1144][2015-02-21T23:43:29]i199: Detect complete, result: 0x0
[1328:1144][2015-02-21T23:43:31]i200: Plan begin, 1 packages, action: Uninstall
[1328:1144][2015-02-21T23:43:31]i000: Setting string variable 'WixBundleRollbackLog_pms' to value 'C:\Users\Juan\AppData\Local\Temp\Plex Media Server_20150221234329_0_pms_rollback.log'
[1328:1144][2015-02-21T23:43:31]i000: Setting string variable 'WixBundleLog_pms' to value 'C:\Users\Juan\AppData\Local\Temp\Plex Media Server_20150221234329_0_pms.log'
[1328:1144][2015-02-21T23:43:31]i201: Planned package: pms, state: Present, default requested: Absent, ba requested: Absent, execute: Uninstall, rollback: Install, cache: No, uncache: Yes, dependency: Unregister
[1328:1144][2015-02-21T23:43:31]i299: Plan complete, result: 0x0
[1328:1144][2015-02-21T23:43:31]i300: Apply begin
[0840:15DC][2015-02-21T23:43:31]i360: Creating a system restore point.
[0840:15DC][2015-02-21T23:43:31]w363: Could not create system restore point, error: 0x80070422. Continuing...
[0840:15DC][2015-02-21T23:43:31]i326: Removed dependency: {83d0d77a-f612-45cd-b2dc-f8c8548447a0} on package provider: {89ED61CD-241D-4281-AD16-FCD6A9B13653}, package pms
[0840:15DC][2015-02-21T23:43:31]i329: Removed package dependency provider: {89ED61CD-241D-4281-AD16-FCD6A9B13653}, package: pms
[0840:15DC][2015-02-21T23:43:31]i301: Applying execute package: pms, action: Uninstall, path: C:\ProgramData\Package Cache\{89ED61CD-241D-4281-AD16-FCD6A9B13653}v0.9.1112\pms.msi, arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7" INSTALLLOCATION="C:\Program Files\Plex\Plex Media Server"'
[0840:15DC][2015-02-21T23:43:31]e000: Error 0x80070654: Failed to uninstall MSI package.
[0840:15DC][2015-02-21T23:43:31]e000: Error 0x80070654: Failed to execute MSI package.
[1328:1144][2015-02-21T23:43:31]e000: Error 0x80070654: Failed to configure per-machine MSI package.
[1328:1144][2015-02-21T23:43:31]i319: Applied execute package: pms, result: 0x80070654, restart: None
[1328:1144][2015-02-21T23:43:31]e000: Error 0x80070654: Failed to execute MSI package.
[0840:15DC][2015-02-21T23:43:31]i318: Skipped rollback of package: pms, action: Install, already: Present
[1328:1144][2015-02-21T23:43:31]i319: Applied rollback package: pms, result: 0x0, restart: None
[0840:15DC][2015-02-21T23:43:31]i323: Registering package dependency provider: {89ED61CD-241D-4281-AD16-FCD6A9B13653}, version: 0.9.1112, package: pms
[0840:15DC][2015-02-21T23:43:31]i325: Registering dependency: {83d0d77a-f612-45cd-b2dc-f8c8548447a0} on package provider: {89ED61CD-241D-4281-AD16-FCD6A9B13653}, package: pms
[1328:1144][2015-02-21T23:43:31]i399: Apply complete, result: 0x80070654, restart: None, ba requested restart:  No
[1328:1144][2015-02-21T23:43:33]i500: Shutting down, exit code: 0x654
[1328:1144][2015-02-21T23:43:33]i410: Variable: InstallFolder = C:\Program Files\Plex\Plex Media Server
[1328:1144][2015-02-21T23:43:33]i410: Variable: LaunchTarget = C:\Program Files\Plex\Plex Media Server\Plex Media Server.exe
[1328:1144][2015-02-21T23:43:33]i410: Variable: ProgramFilesFolder = C:\Program Files\
[1328:1144][2015-02-21T23:43:33]i410: Variable: VersionNT = 6.1.0.0
[1328:1144][2015-02-21T23:43:33]i410: Variable: WixBundleAction = 3
[1328:1144][2015-02-21T23:43:33]i410: Variable: WixBundleElevated = 1
[1328:1144][2015-02-21T23:43:33]i410: Variable: WixBundleInstalled = 1
[1328:1144][2015-02-21T23:43:33]i410: Variable: WixBundleLog = C:\Users\Juan\AppData\Local\Temp\Plex Media Server_20150221234329.log
[1328:1144][2015-02-21T23:43:33]i410: Variable: WixBundleLog_pms = C:\Users\Juan\AppData\Local\Temp\Plex Media Server_20150221234329_0_pms.log
[1328:1144][2015-02-21T23:43:33]i410: Variable: WixBundleManufacturer = Plex, Inc.
[1328:1144][2015-02-21T23:43:33]i410: Variable: WixBundleName = Plex Media Server
[1328:1144][2015-02-21T23:43:33]i410: Variable: WixBundleOriginalSource = C:\Users\Juan\Downloads\Plex-Media-Server-0.9.1112.869-ab1cd47-en-US.exe
[1328:1144][2015-02-21T23:43:33]i410: Variable: WixBundleProviderKey = {83d0d77a-f612-45cd-b2dc-f8c8548447a0}
[1328:1144][2015-02-21T23:43:33]i410: Variable: WixBundleRollbackLog_pms = C:\Users\Juan\AppData\Local\Temp\Plex Media Server_20150221234329_0_pms_rollback.log
[1328:1144][2015-02-21T23:43:33]i410: Variable: WixBundleTag =
[1328:1144][2015-02-21T23:43:33]i410: Variable: WixBundleVersion = 0.9.1112.0
[1328:1144][2015-02-21T23:43:33]i007: Exit code: 0x654, restarting: No
Thanks for the logs. The underlying error is this one:
I have not seen this error before and I am not sure why it is being given.
Hits from Google search did not help - may be you have better luck than me.
Only things I can think of to try:
- Check the download file as I outlined before : Digital Signatures tab/Plex Inc entry
- Check that the system is up to date with Windows Updates and Service Packs
- Reboot
- Run the microsoft Windows FixIt : Fix problems that Programs that cannot be installed or uninstalled
HELP! PMS will not start on a brand-new Windows 7 Professional 64-bit PC after installation. This means PMS does not even show as a process/service under task manager after I try to start the application. There are no error messages during installation or when I try to start the server. I have uninstalled and re-installed PMS several times with no success. I use MSE as anti-virus and it was off during two of the attempts.  I use an admin account and the PMS version I have is  Plex-Media-Server-0.9.1107.803-87d0708-en-US. Partial log is below and I did notice the following line multiple times:
MSI (s) (CC:98) [08:56:16:125]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Plex\Plex Media Server\avcodec-55.dll' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (CC:98) [08:56:16:125]: Executing op: ComponentRegister(ComponentId={21E8B957-71E4-57CE-B0FA-966F43997867},KeyPath=C:\Program Files (x86)\Plex\Plex Media Server\avformat-55.dll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (CC:98) [08:56:16:126]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Plex\Plex Media Server\avformat-55.dll' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (CC:98) [08:56:16:126]: Executing op: ComponentRegister(ComponentId={DF4EC366-1208-5E3E-9417-14BBE2CCE1C7},KeyPath=C:\Program Files (x86)\Plex\Plex Media Server\avutil-52.dll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (CC:98) [08:56:16:127]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Plex\Plex Media Server\avutil-52.dll' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
This went on for several lines. Not sure if this has anything to do with the error but it is the only line that jumped at me. The end of the log is:
=== Logging stopped: 2/22/2015  8:56:54 ===
MSI (s) (CC:98) [08:56:54:257]: Note: 1: 1707
MSI (s) (CC:98) [08:56:54:257]: Product: Plex Media Server -- Installation completed successfully.
MSI (s) (CC:98) [08:56:54:257]: Windows Installer installed the product. Product Name: Plex Media Server. Product Version: 0.9.1107. Product Language: 1033. Manufacturer: Plex, Inc.. Installation success or error status: 0.
MSI (s) (CC:98) [08:56:54:716]: Deferring clean up of packages/files, if any exist
MSI (s) (CC:98) [08:56:54:717]: MainEngineThread is returning 0
MSI (s) (CC:50) [08:56:54:720]: RESTART MANAGER: Session closed.
MSI (s) (CC:50) [08:56:54:720]: No System Restore sequence number for this installation.
MSI (s) (CC:50) [08:56:54:732]: User policy value 'DisableRollback' is 0
MSI (s) (CC:50) [08:56:54:732]: Machine policy value 'DisableRollback' is 0
MSI (s) (CC:50) [08:56:54:732]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (CC:50) [08:56:54:732]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (CC:50) [08:56:54:733]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (CC:50) [08:56:54:734]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
MSI (s) (CC:50) [08:56:54:734]: Restoring environment variables
MSI (s) (CC:50) [08:56:54:735]: Destroying RemoteAPI object.
MSI (s) (CC:00) [08:56:54:735]: Custom Action Manager thread ending.
MSI (c) (D4:6C) [08:56:54:736]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
MSI (c) (D4:6C) [08:56:54:737]: MainEngineThread is returning 0
=== Verbose logging stopped: 2/22/2015  8:56:54 ===
These errors are ok. They are present in all installation logs for Plex Media Server
So we had an install reported a successful.
but when you launch Plex Media Server.exe it exits immediately
Please can you see if there are any files in this folder:
C:\Users\xxxxx\AppData\Local\Plex Media Server\Logs
If there are, zip them and attach the zip
xxxxx is the windows user account that you tried to launch Plex Media Server in
Please can you export the registry keys in here to a text file and attach
You can edit your email address and online token before uploading the txt file
RegEdit
and select
Computer\HKEY_CURRENT_USER\Software\Plex, Inc.\Plex Media Server
And FIle / Export / Save As : text file (.txt)
And open Windows Task Manager
Click on Processes tab
Click on Show Processes for all user accounts
Click on Image heading to sort the names alphabetically
Look for any process with name starting with Plex
and see if any are present
I am a plex pass member and on installation of my plex media player I received the following message:
"A problem has been detected with a core component of Plex Media Server"
Log attached. Please help me get this sorted, I want to get it going on my playstation!
Cheers,
Rory
Cheers,
Rory
What anti virus / security software do you have running?
This error is covered by this support page and most such problems are resolved by resetting the system and framework bundles
In cases where this does not work, it is often proxy software or some third party security software
The log showed these errors
Feb 22, 2015 13:10:45:167 [7412] DEBUG - Starting plug-in C:\Users\Rory\AppData\Local\Plex Media Server\Plug-ins\System.bundle.
Feb 22, 2015 13:10:45:228 [7412] ERROR - Error parsing content from file 'C:\Users\Rory\AppData\Local\Plex Media Server\Plug-ins\System.bundle/Contents/Info.plist'
Feb 22, 2015 13:10:45:229 [7412] ERROR - Caught exception starting plugin C:\Users\Rory\AppData\Local\Plex Media Server\Plug-ins\System.bundle (Error parsing file)
Feb 22, 2015 13:10:45:250 [11608] DEBUG - Starting plug-in C:\Users\Rory\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle.
Feb 22, 2015 13:10:45:265 [11608] ERROR - Error parsing content from file ‘C:\Users\Rory\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle/Contents/Info.plist’
Feb 22, 2015 13:10:45:265 [11608] ERROR - Caught exception starting plugin C:\Users\Rory\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle (Error parsing file)
- Reboot
Well,I have restore my computer to a previous safe point and now all is ok
