Debugging setup failures
Aka how to generate a verbose Windows Installer log file
So you've tried to install Plex Media Server and Windows Installer popped up an apocryphal error message. It happens.
If you report the issue in here (and you should, because setup should be perfect), you may find us asking you for the Windows Installer log, otherwise known as the MSI log. Here's how to generate one, starting with the downloaded installer.
For 0.9.7.x and below:
1) Open a command prompt
2) cd to the directory where the installer is located: cd /d "%userprofile%\Downloads"
3) Extract files from the installer: Plex-Media-Server-v0.9.304-en-US.exe /c /t:"%userprofile%\Downloads\Temp"
4) Go to the destination directory: cd "%userprofile%\Downloads\Temp"
5) Run the installer with verbose logging: msiexec.exe /i pms.msi /l*v log.txt
6) Click through the installer and reproduce the failure.
Once setup completes, you have a Windows Installer log in log.txt.
For 0.9.8.x and above:
1) cd to the directory where the installer is located: cd /d "%userprofile%\Downloads"
2) Run the installer and generate a log file: Plex-Media-Server-0.9.803.96-eee3b6a-en-US.exe /log log.txt
If the log says something along the lines of "Error 0x80070643: Failed to install MSI package.", then you'll need to re-run pms.msi by hand.
First, find in the log the properties set by the package when installing. E.g.:
[CDD8:12078][2013-08-02T17:30:30]i301: Applying execute package: pms, action: Install, path: C:\ProgramData\Package Cache\{D9C4446C-89ED-440A-A228-AE76F73DA256}v0.9.803\pms.msi, arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7" INSTALLLOCATION="C:\Program Files (x86)\Plex\Plex Media Server"'
1) Download and install WiX 3.7: http://wix.codeplex.com/releases/view/99514. That should set the WIX environment variable. WIX=C:\Program Files (x86)\WiX Toolset v3.7\
2) In a command prompt, run "%WIX%bin\dark.exe" Plex-Media-Server-0.9.803.96-eee3b6a-en-US.exe -x PMS
3) In the command prompt, run msiexec.exe /i PMS\AttachedContainer\pms.msi /l*v msilog.txt ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7" INSTALLLOCATION="C:\Program Files (x86)\Plex\Plex Media Server" Needless to say, set the properties at the end of the cmd line from the log.txt entry you located above.
Once setup completes, you have a Windows Installer log in msilog.txt.
So once I have the log what to do?? I cant uninstall plex or update to newer version...
why no text agrement at pop up at install Plex-Media-Server-0.9.722.511-4b5280f-en-US_2.exe ,just sign " ? " ,than said file corup ,please help
This is happening to me.
Log was too big, so you can find it here: http://db.tt/HbX0HJGv
Hello,
I didn't get a set up failure, but that my PC would need to be rebooted because certain files were open. I did this, and all seemed fine once I restarted my PC-I didn't get any error messages, however when I try to open Plex Media Server, nothing happens. So I uninstalled it and reinstalled it. This time I didn't get any messages that files were open and it installed. But the same thing happens, I click to open the program and nothing happens. If I manually refresh my library on the web, I don't have an issue and can watch from my Roku. However, when I go to "My Media Servers" online it says that I don't have a server set up and to open the program and go back and refresh. Since I can't open the program I can't refresh...This is an issue since I want to share with my friends and it shows that I don't have a server.
What should I do???
Thanks!
~Vanessa
Was running plex fine until I tried to install the latest update. Update failed so I uninstalled plex and bonjour. Same error when tryng to install the lastest version of plex.
The Error: This installation package cannot be installed by the Windows Installer service.  You must install a Windows service pack that contains a newer version of the Windows Installer service.
Computer: XP SP3 32bit
=== Verbose logging started: 6/25/2013  22:32:05  Build type: SHIP UNICODE 3.01.4001.5512  Calling process: C:\WINDOWS\system32\msiexec.exe ===
MSI (c) (8C:DC) [22:32:05:687]: Resetting cached policy values
MSI (c) (8C:DC) [22:32:05:687]: Machine policy value 'Debug' is 0
MSI (c) (8C:DC) [22:32:05:687]: ******* RunEngine:
           ******* Product: pms.msi
           ******* Action:
           ******* CommandLine: **********
MSI (c) (8C:DC) [22:32:05:687]: Machine policy value 'DisableUserInstalls' is 0
MSI (c) (8C:DC) [22:32:10:734]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'G:\Temp\pms.msi' against software restriction policy
MSI (c) (8C:DC) [22:32:10:734]: SOFTWARE RESTRICTION POLICY: G:\Temp\pms.msi has a digital signature
MSI (c) (8C:DC) [22:32:12:781]: SOFTWARE RESTRICTION POLICY: G:\Temp\pms.msi is permitted to run at the 'unrestricted' authorization level.
MSI (c) (8C:DC) [22:32:13:000]: Cloaking enabled.
MSI (c) (8C:DC) [22:32:13:000]: Attempting to enable all disabled priveleges before calling Install on Server
MSI (c) (8C:DC) [22:32:13:015]: End dialog not enabled
MSI (c) (8C:DC) [22:32:13:015]: Original package ==> G:\Temp\pms.msi
MSI (c) (8C:DC) [22:32:13:015]: Package we're running from ==> C:\DOCUME~1\JSTAND~1\LOCALS~1\Temp\16fbe9.msi
G:\Temp\pms.msi
MSI (c) (8C:DC) [22:32:13:046]: Note: 1: 1708
MSI (c) (8C:DC) [22:32:13:046]: Note: 1: 2729
MSI (c) (8C:DC) [22:32:13:062]: Note: 1: 2729
MSI (c) (8C:DC) [22:32:13:062]: Product:  -- Installation failed.
MSI (c) (8C:DC) [22:32:13:078]: MainEngineThread is returning 1613
=== Verbose logging stopped: 6/25/2013  22:32:13 ===
I have the exact same situation as mudycj. Same set up and it's happening on two different boxes. I'd very much like to update my server but stuck on 0.9.7.22-stuff
Help please!
I got it working....
This is what I did
  1. Click Start, click Run, type cmd in the Open box, and then click OK.
  2. Type cd %windir%\system32, and then press Enter.
  3. Type attrib -r -s -h dllcache, and then press Enter.
  4. Type ren msi.dll msi.old, and then press Enter.
  5. Type ren msiexec.exe msiexec.old, and then press Enter.
  6. Type ren msihnd.dll msihnd.old, and then press Enter.
  7. Type exit, and then press Enter.
  8. At the command prompt, type exit, and then press Enter.
  9. Click Start, and then click Turn off computer or Shut Down.
  10. Select the Restart option, and then click OK, or click Restart.
  11. Log on to the computer.
  12. Download and install the latest version of the Windows Installer. http://www.microsoft.com/en-us/download/confirmation.aspx?id=8483
  13. Restart computer
  14. Install Plex Media Server http://www.plexapp.com/download/plex-media-center.php Install was succesful but I got errors on launch.
  15. So then I had to Install it from here http://www.plexapp.com/getplex/
  16. Finally back to working again.....
I have never had so much trouble installing and setting up a program such as this. I know it's free but damn. After working through a few bugs I got stuck trying to connect to the server. I tried one of the suggestion but when I went back to the set up screen it was gone. Now I can't even get to the screen again. I'm not new to computers by any means but this is the most confusing site I've ever been to. I've logged on to 3 different plex screens and none of them take me back to the set up screen. Any suggestions?
Installer packages built with the latest versions of WiX do require an updated version of Windows Installer. Unfortunately, Microsoft decided to not provide that to XP users as an automatic update. mudycj’s link above should work.
I apologize for the hassle on XP, but this is not our fault. It’s a 12-year old operating system and it’s falling out of mainstream support from it’s manufacturer.
Assuming you're on Windows, try deleting the following registry value, and then restarting PMS:
HKEY_CURRENT_USER\Software\Plex, Inc.\Plex Media Server -> FirstRun
Hello,
What should I do???
Thanks!
~Vanessa
When you launch the Media Server, is there a tray icon? If you navigate to http://localhost:32400/web/ you should be able to manage your server.
A problem has been detected with a core component of Plex. Please visit the forums and provide your logs, as described here. Not a good start after installPlex DLNA Server Neptune.log (477 KB)Plex DLNA Server.log (694 KB)Plex Media Server.log (178 KB)
This is the first time I've wanted a refund for a free product.  Initially, the download didn't go in, possibly because of my firewall?  All my icon did was to pull up a webpage, and I selected some channels, etc., from that because I didn't know it wasn't right.  But Hulu never would play, and that's the channel I want the most.  So I eventually, I realized the server wasn't connected.  So I redownloaded the Plex software.  At this point, when I click on the Plex icon, I get something that looks more like a program, but I still can't install the server.  Every time I try, the software gets stuck and the only thing I can do with it is to close it with the Task Manager.  Additionally, sometimes either the software or the the webpage recognizes my user name and password and sometimes it doesn't.  And, now appears that two videos from my Hulu queue were set to my Plex queue, but when I tried to play it on my Roku box, I got an error saying that the video was in an unrecognizable format.
Help?  I'm not computer-savvy in the first place, but I've never had this many problems with an app.  My OS is Windows 7 Premium.
I am running Windows 7. Got this error on installaation:
here is my Plex Media Server.log
Jul 22, 2013 12:59:07:896 [0696] INFO - LANGID = 0x409
Jul 22, 2013 12:59:07:896 [0696] DEBUG - LoadMUILibraryW(0) returned 0x66DA0002
Jul 22, 2013 12:59:07:897 [0696] INFO - Windows version 6.1 (Build 7601)
Jul 22, 2013 12:59:07:898 [0696] INFO - 4 2527 MHz processor(s): Architecture=0, Level=6, Revision=9477
Jul 22, 2013 12:59:07:898 [0696] INFO - PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 37 Stepping 5, GenuineIntel
Jul 22, 2013 12:59:07:900 [0696] INFO - Plex Media Server v0.9.7.28-f80a4a2
Jul 22, 2013 12:59:07:901 [0696] DEBUG - Opening 10 database sessions to library, SQLite 3.7.15.2, threadsafe=1
Jul 22, 2013 12:59:07:902 [0696] DEBUG - Installing Library Database from [C:\Program Files (x86)\Plex\Plex Media Server\Resources\com.plexapp.plugins.library.db] to [C:\Users\myusername\AppData\Local\Plex Media Server\Plug-in Support\Databases\com.plexapp.plugins.library.db]
Jul 22, 2013 12:59:07:952 [0696] DEBUG - Running migrations.
Jul 22, 2013 12:59:08:280 [0696] DEBUG - Listening on port 32400 with queue of 2147483647 connections.
Jul 22, 2013 12:59:08:777 [0696] WARN - WARNING: Couldn't create directory C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins/SiteConfigurations.bundle/Contents/Resources
Jul 22, 2013 12:59:08:778 [0696] DEBUG - Adding directory for site configurations: C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins/SiteConfigurations.bundle/Contents/Resources
Jul 22, 2013 12:59:08:778 [0696] DEBUG - The path changed: C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins/SiteConfigurations.bundle/Contents/Resources.
Jul 22, 2013 12:59:08:778 [0696] DEBUG - This corresponds to site configuration map: C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins/SiteConfigurations.bundle/Contents/Resources (directory: 1)
Jul 22, 2013 12:59:08:778 [0696] DEBUG - Adding directory for site configurations: C:\Users\myusername\AppData\Local\Plex Media Server\Site Configurations
Jul 22, 2013 12:59:08:778 [0696] DEBUG - The path changed: C:\Users\myusername\AppData\Local\Plex Media Server\Site Configurations.
Jul 22, 2013 12:59:08:778 [0696] DEBUG - This corresponds to site configuration map: C:\Users\myusername\AppData\Local\Plex Media Server\Site Configurations (directory: 1)
Jul 22, 2013 12:59:08:779 [0720] WARN - Warning: Couldn't check file: C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins/SiteConfigurations.bundle/Contents/Resources
Jul 22, 2013 12:59:08:779 [0720] DEBUG - File C:\Users\myusername\AppData\Local\Plex Media Server\Site Configurations changed: -1 => -1.
Jul 22, 2013 12:59:08:779 [0720] DEBUG - The path changed: C:\Users\myusername\AppData\Local\Plex Media Server\Site Configurations.
Jul 22, 2013 12:59:08:779 [0720] DEBUG - This corresponds to site configuration map: C:\Users\myusername\AppData\Local\Plex Media Server\Site Configurations (directory: 1)
Jul 22, 2013 12:59:09:780 [0720] WARN - Warning: Couldn't check file: C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins/SiteConfigurations.bundle/Contents/Resources
Jul 22, 2013 12:59:10:275 [4228] DEBUG - WebKit supports Flash content
Jul 22, 2013 12:59:10:275 [4228] DEBUG - WebKit supports Silverlight content
Jul 22, 2013 12:59:10:275 [4228] INFO - Successfully initialized WebKit
Jul 22, 2013 12:59:10:473 [0696] DEBUG - Setting up scheduled updates
Jul 22, 2013 12:59:10:474 [0696] INFO - LibraryUpdateManager path watching is disabled
Jul 22, 2013 12:59:10:474 [1720] DEBUG - Starting scheduled updates, every 3600 seconds
Jul 22, 2013 12:59:10:564 [0696] DEBUG - Installing plug-in: SiteConfigurations
Jul 22, 2013 12:59:10:997 [0696] DEBUG - Installing plug-in: Framework
Jul 22, 2013 12:59:11:780 [0720] DEBUG - File C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins/SiteConfigurations.bundle/Contents/Resources changed: 1374515948 => 0.
Jul 22, 2013 12:59:11:780 [0720] DEBUG - The path changed: C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins/SiteConfigurations.bundle/Contents/Resources.
Jul 22, 2013 12:59:11:780 [0720] DEBUG - This corresponds to site configuration map: C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins/SiteConfigurations.bundle/Contents/Resources (directory: 1)
Jul 22, 2013 12:59:13:505 [0696] DEBUG - Installing plug-in: System
Jul 22, 2013 12:59:13:838 [0696] DEBUG - Installing plug-in: Scanners
Jul 22, 2013 12:59:14:140 [0696] DEBUG - Installing plug-in: Services
Jul 22, 2013 12:59:18:491 [0696] DEBUG - Installing plug-in: Media-Flags
Jul 22, 2013 12:59:24:814 [0696] DEBUG - Installing plug-in: IMDB
Jul 22, 2013 12:59:25:069 [0696] DEBUG - Installing plug-in: MoviePosterDB
Jul 22, 2013 12:59:25:095 [0696] DEBUG - Installing plug-in: The-Movie-Database
Jul 22, 2013 12:59:25:193 [0696] DEBUG - Installing plug-in: Wikipedia
Jul 22, 2013 12:59:25:218 [0696] DEBUG - Installing plug-in: PlexThemeMusic
Jul 22, 2013 12:59:25:242 [0696] DEBUG - Installing plug-in: TheTVDB
Jul 22, 2013 12:59:25:270 [0696] DEBUG - Installing plug-in: LastFM
Jul 22, 2013 12:59:25:377 [0696] DEBUG - Installing plug-in: HTbackdrops
Jul 22, 2013 12:59:25:400 [0696] DEBUG - Installing plug-in: OpenSubtitles
Jul 22, 2013 12:59:25:528 [0696] DEBUG - Installing plug-in: PersonalMedia
Jul 22, 2013 12:59:25:546 [0696] DEBUG - Installing plug-in: LocalMedia
Jul 22, 2013 12:59:25:806 [0696] DEBUG - Installing plug-in: WebManager
Jul 22, 2013 12:59:26:413 [0696] DEBUG - Installing plug-in: WebClient
Jul 22, 2013 12:59:26:896 [0696] ERROR - Error cleaning up deactivated plug-ins.
Jul 22, 2013 12:59:26:897 [1232] DEBUG - File C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins changed: -1 => -1.
Jul 22, 2013 12:59:26:897 [1232] DEBUG - Scanning for plug-ins in C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins
Jul 22, 2013 12:59:26:898 [1232] DEBUG - Starting plug-in C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\System.bundle.
Jul 22, 2013 12:59:26:902 [1232] DEBUG - [com.plexapp.system] Setting plug-in to always running (daemon mode).
Jul 22, 2013 12:59:26:902 [1456] DEBUG - Loading CAs from 'C:\Program Files (x86)\Plex\Plex Media Server\Resources\cacert.pem'
Jul 22, 2013 12:59:26:905 [1232] DEBUG - Starting file watcher for com.plexapp.system
Jul 22, 2013 12:59:26:905 [1232] DEBUG - Plugin::createProcess: Creating plugin process: "C:\Program Files (x86)\Plex\Plex Media Server\PlexScriptHost.exe" "C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle\Contents\Resources\Versions\2\Python/bootstrap.py" "C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\System.bundle"
Jul 22, 2013 12:59:26:941 [1232] DEBUG - Spawned plug-in com.plexapp.system with PID 7088
Jul 22, 2013 12:59:26:941 [1232] DEBUG - [com.plexapp.system] Sent command: GET /:/prefixes
Jul 22, 2013 12:59:31:474 [1232] DEBUG - Reading 323 bytes in the body, code is 200
Jul 22, 2013 12:59:31:474 [1232] DEBUG - [com.plexapp.system] Plug-in running on port 53597.
Jul 22, 2013 12:59:31:474 [1232] DEBUG -  * Plug-in handles prefix: /system
Jul 22, 2013 12:59:31:474 [1232] DEBUG - Read configuration for [com.plexapp.system], had 1 prefixes
Jul 22, 2013 12:59:32:476 [1232] DEBUG - Updating [com.plexapp.system] in the database, it has changed.
Jul 22, 2013 12:59:32:552 [1232] DEBUG - Done with 1 synchronous plug-in starts, starting the rest in parallel.
Jul 22, 2013 12:59:32:555 [1232] DEBUG - Updating the list of agents known by the system.
Jul 22, 2013 12:59:32:555 [1232] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /system/agents
Jul 22, 2013 12:59:32:558 [1232] DEBUG - HTTP requesting to: http://127.0.0.1:53597/system/agents
Jul 22, 2013 12:59:32:560 [0696] DEBUG - Found iTunes library at C:\Users\myusername\Music\iTunes\iTunes Music Library.xml
Jul 22, 2013 12:59:32:560 [0696] DEBUG - Found 1 library files
Jul 22, 2013 12:59:32:561 [0696] DEBUG - Found genres file at C:\Program Files (x86)\iTunes\iTunes.Resources\genres.plist
Jul 22, 2013 12:59:32:610 [0696] DEBUG - Found 92 genre icons
Jul 22, 2013 12:59:32:610 [3020] DEBUG - File C:\Users\myusername\Music\iTunes\iTunes Music Library.xml changed: -1 => -1.
Jul 22, 2013 12:59:32:611 [3020] INFO - DatabaseLoader::handleChangedFile(0081C4B8)
Jul 22, 2013 12:59:32:611 [0696] DEBUG - Image transcode cache directory: C:\Users\myusername\AppData\Local\Plex Media Server\Cache\PhotoTranscoder
Jul 22, 2013 12:59:32:632 [3020] DEBUG - iTunes: Reading XML files...
Jul 22, 2013 12:59:32:905 [0696] DEBUG - Bonjour: DNSServiceBrowse succeeded
Jul 22, 2013 12:59:33:065 [0696] DEBUG - Bonjour: DNSServiceBrowse succeeded
Jul 22, 2013 12:59:33:065 [0696] INFO - Bonjour: registering PMS service
Jul 22, 2013 12:59:33:065 [0696] INFO - Bonjour: serviceType = _plexmediasvr._tcp, friendlyName = TireTread, domain = NULL, hostname = NULL, servicePort = 32400
Jul 22, 2013 12:59:33:065 [0696] INFO - Bonjour: machineIdentifier = e023f7052c9588f2a10b2781caea8b6f017b31cc, version = 0.9.7.28-f80a4a2, playersModified = 1374515973.0
Jul 22, 2013 12:59:33:067 [0696] DEBUG - Bonjour: DNSServiceRegister succeeded
Jul 22, 2013 12:59:33:068 [0696] DEBUG - Creating NetworkServices singleton.
Jul 22, 2013 12:59:33:068 [0696] DEBUG - NetworkServices: Initializing...
Jul 22, 2013 12:59:33:068 [0696] DEBUG - NetworkInterface: Notified of network changed (force=0)
Jul 22, 2013 12:59:33:106 [0696] DEBUG - Network interfaces:
Jul 22, 2013 12:59:33:106 [0696] DEBUG -  * 1 {846EE342-7039-11DE-9D20-806E6F6E6963} (127.0.0.1) (loopback: 1)
Jul 22, 2013 12:59:33:106 [0696] DEBUG -  * 11 {A16A1E0C-4162-49DC-A2D6-C73E065E46EF} (192.168.1.106) (loopback: 0)
Jul 22, 2013 12:59:33:106 [0696] DEBUG -  * 13 {D32133AE-FC6C-45E9-A408-E9D8BB852B65} (192.168.254.1) (loopback: 0)
Jul 22, 2013 12:59:33:106 [0696] DEBUG -  * 14 {60490966-B53D-437D-B560-777B0F6CD712} (192.168.255.1) (loopback: 0)
Jul 22, 2013 12:59:33:106 [0696] DEBUG -  * 18 {DE453963-1858-48B6-B8A6-1838B49049D2} (192.168.56.1) (loopback: 0)
Jul 22, 2013 12:59:33:107 [0696] DEBUG - 06371600: Creating new Network Service and registering for notifications.
Jul 22, 2013 12:59:33:107 [0696] DEBUG - 06371600: NetworkService got notification of changed network (first change: 1)
Jul 22, 2013 12:59:33:107 [0696] DEBUG - NetworkService: Quick dispatch of network change.
Jul 22, 2013 12:59:33:107 [0696] DEBUG - 06497A10: Creating new Network Service and registering for notifications.
Jul 22, 2013 12:59:33:107 [0696] DEBUG - 06497A10: NetworkService got notification of changed network (first change: 1)
Jul 22, 2013 12:59:33:107 [0696] DEBUG - 06499A50: Creating new Network Service and registering for notifications.
Jul 22, 2013 12:59:33:107 [0696] DEBUG - 06499A50: NetworkService got notification of changed network (first change: 1)
Jul 22, 2013 12:59:33:107 [0696] DEBUG - 0649BAE8: Creating new Network Service and registering for notifications.
Jul 22, 2013 12:59:33:107 [0696] DEBUG - 0649BAE8: NetworkService got notification of changed network (first change: 1)
Jul 22, 2013 12:59:33:108 [6256] DEBUG - Network change for advertiser.
Jul 22, 2013 12:59:33:108 [6256] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:32414 (outbound: 0)
Jul 22, 2013 12:59:33:108 [6340] DEBUG - DLNA server starting.
Jul 22, 2013 12:59:33:109 [6340] DEBUG - Job running: C:\Program Files (x86)\Plex\Plex Media Server\PlexDlnaServer.exe
Jul 22, 2013 12:59:33:109 [6256] DEBUG - Network change for advertiser.
Jul 22, 2013 12:59:33:109 [6256] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:32410 (outbound: 0)
Jul 22, 2013 12:59:33:109 [6256] DEBUG - Network change for browser (polled=0), closing 0 browse sockets.
Jul 22, 2013 12:59:33:109 [6256] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:32413 (outbound: 0)
Jul 22, 2013 12:59:33:109 [6256] DEBUG - NetworkService: Browsing on interface 127.0.0.1.
Jul 22, 2013 12:59:33:109 [6256] DEBUG - NetworkService: Setting up multicast listener on 127.0.0.1:0 (outbound: 1)
Jul 22, 2013 12:59:33:110 [6256] DEBUG - NetworkService: Browsing on interface 192.168.1.106.
Jul 22, 2013 12:59:33:110 [6256] DEBUG - NetworkService: Setting up multicast listener on 192.168.1.106:0 (outbound: 1)
Jul 22, 2013 12:59:33:110 [6256] DEBUG - NetworkService: Browsing on interface 192.168.254.1.
Jul 22, 2013 12:59:33:110 [6256] DEBUG - NetworkService: Setting up multicast listener on 192.168.254.1:0 (outbound: 1)
Jul 22, 2013 12:59:33:110 [6256] DEBUG - NetworkService: Browsing on interface 192.168.255.1.
Jul 22, 2013 12:59:33:110 [6256] DEBUG - NetworkService: Setting up multicast listener on 192.168.255.1:0 (outbound: 1)
Jul 22, 2013 12:59:33:110 [6256] DEBUG - NetworkService: Browsing on interface 192.168.56.1.
Jul 22, 2013 12:59:33:110 [6256] DEBUG - NetworkService: Setting up multicast listener on 192.168.56.1:0 (outbound: 1)
Jul 22, 2013 12:59:33:111 [6256] DEBUG - Network change for browser (polled=1), closing 0 browse sockets.
Jul 22, 2013 12:59:33:111 [6256] DEBUG - NetworkService: Browsing on interface 127.0.0.1.
Jul 22, 2013 12:59:33:111 [6256] DEBUG - NetworkService: Setting up multicast listener on 127.0.0.1:0 (outbound: 1)
Jul 22, 2013 12:59:33:111 [6256] DEBUG - NetworkService: Browsing on interface 192.168.1.106.
Jul 22, 2013 12:59:33:111 [6256] DEBUG - NetworkService: Setting up multicast listener on 192.168.1.106:0 (outbound: 1)
Jul 22, 2013 12:59:33:111 [6256] DEBUG - NetworkService: Browsing on interface 192.168.254.1.
Jul 22, 2013 12:59:33:111 [6256] DEBUG - NetworkService: Setting up multicast listener on 192.168.254.1:0 (outbound: 1)
Jul 22, 2013 12:59:33:112 [6256] DEBUG - NetworkService: Browsing on interface 192.168.255.1.
Jul 22, 2013 12:59:33:112 [6256] DEBUG - NetworkService: Setting up multicast listener on 192.168.255.1:0 (outbound: 1)
Jul 22, 2013 12:59:33:112 [6256] DEBUG - NetworkService: Browsing on interface 192.168.56.1.
Jul 22, 2013 12:59:33:112 [6256] DEBUG - NetworkService: Setting up multicast listener on 192.168.56.1:0 (outbound: 1)
Jul 22, 2013 12:59:33:121 [6256] DEBUG - NetworkServiceBrowser: SERVER arrived: 192.168.56.1
Jul 22, 2013 12:59:33:121 [6256] DEBUG - Notifying the system bundle an update to server /system/notify/serverUpdated?host=192.168.56.1
Jul 22, 2013 12:59:33:121 [6256] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /system/notify/serverUpdated?host=192.168.56.1
Jul 22, 2013 12:59:33:121 [6256] DEBUG - HTTP requesting to: http://127.0.0.1:53597/system/notify/serverUpdated?host=192.168.56.1
Jul 22, 2013 12:59:33:152 [6060] DEBUG - Bonjour: DNSServiceBrowse_Callback: sdRef = 0x00D81118, flags = 2, interfaceIndex = 11, code = 0
Jul 22, 2013 12:59:33:152 [6060] DEBUG - Bonjour: DNSServiceBrowse_Callback: serviceName = LenovoWin, regtype = _plexmediasvr._tcp., replyDomain = local.
Jul 22, 2013 12:59:33:152 [6060] DEBUG - Bonjour: DNSServiceBrowse_Callback: calling DNSServiceResolve on LenovoWin
Jul 22, 2013 12:59:33:154 [6060] DEBUG - Bonjour: DNSServiceResolve succeeded, adding reference 0x0642AA20, new ResolveContext instance 0x23D58032
Jul 22, 2013 12:59:33:154 [6060] DEBUG - Bonjour: DNSServiceResolve_Callback: sdResolveRef = 0x00D8CB00, flags = 0, interfaceIndex = 11, code = 0
Jul 22, 2013 12:59:33:154 [6060] DEBUG - Bonjour: DNSServiceResolve_Callback: fullname = LenovoWin._plexmediasvr._tcp.local., hosttarget = myusername-z570.local., tcpport = 36990, txtLen = 113
Jul 22, 2013 12:59:33:154 [6060] DEBUG - Bonjour: DNSServiceResolve_Callback: resolved TXT record for LenovoWin._plexmediasvr._tcp.local.: host = myusername-z570.local., machineIdentifier = e814ceda1ca6609c95a5b7b5a6becacc8f356e04, version = 0.9.7.12-db37d6d
Jul 22, 2013 12:59:33:256 [6060] DEBUG - Bonjour: MonitorTxtRecord - DNSServiceConstructFullName succeeded: LenovoWin._plexmediasvr._tcp.local.
Jul 22, 2013 12:59:33:259 [6060] DEBUG - Bonjour: DNSServiceQueryRecord succeeded, QueryRecordContext = 0x008CB998
Jul 22, 2013 12:59:33:259 [6060] INFO - Bonjour: adding host - name = LenovoWin, hostname - myusername-z570.local., machineIdentifier = e814ceda1ca6609c95a5b7b5a6becacc8f356e04
Jul 22, 2013 12:59:33:259 [6060] DEBUG - Bonjour: DNSServiceResolve_Callback: removing reference 0x00D8CB00, deleting ResolveContext instance 0x0642AA20
Jul 22, 2013 12:59:33:260 [6060] DEBUG - Bonjour: DNSServiceQueryRecord_Callback succeeded, QueryRecordContext = 0x008CB998
Jul 22, 2013 12:59:33:260 [6060] INFO - Bonjour: TXT record added for LenovoWin._plexmediasvr._tcp.local.
Jul 22, 2013 12:59:33:260 [5880] DEBUG - Notifying the system bundle an update to server /system/notify/serverUpdated?host=myusername-z570.local.
Jul 22, 2013 12:59:33:260 [5880] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /system/notify/serverUpdated?host=myusername-z570.local.
Jul 22, 2013 12:59:33:261 [5880] DEBUG - HTTP requesting to: http://127.0.0.1:53597/system/notify/serverUpdated?host=myusername-z570.local.
Jul 22, 2013 12:59:33:773 [0696] DEBUG - Starting HTTP server.
Jul 22, 2013 12:59:33:773 [0696] DEBUG - Running server...
Jul 22, 2013 12:59:33:774 [0696] DEBUG - Waiting for server condition to be signaled.
Jul 22, 2013 12:59:33:777 [4556] DEBUG - Set up a thread pool for HTTP server with 2 threads.
Jul 22, 2013 12:59:33:777 [4556] DEBUG - Running database fix-ups.
Jul 22, 2013 12:59:33:778 [5204] DEBUG - Request: GET /:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_ [127.0.0.1:53593] (6 live)
Jul 22, 2013 12:59:33:779 [5204] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_
Jul 22, 2013 12:59:33:781 [0952] DEBUG - Request: GET / [127.0.0.1:53594] (6 live)
Jul 22, 2013 12:59:33:782 [0952] DEBUG - It took 0.000000 sec to serialize a list with 7 elements.
Jul 22, 2013 12:59:33:783 [7136] DEBUG - Request: GET / [127.0.0.1:53595] (6 live)
Jul 22, 2013 12:59:33:784 [7136] DEBUG - It took 0.000000 sec to serialize a list with 7 elements.
Jul 22, 2013 12:59:33:790 [6160] DEBUG - Request: GET /servers [127.0.0.1:53596] (6 live)
Jul 22, 2013 12:59:33:790 [6160] DEBUG - It took 0.000000 sec to serialize a list with 2 elements.
Jul 22, 2013 12:59:33:791 [6736] DEBUG - Request: GET /servers [127.0.0.1:53605] (6 live)
Jul 22, 2013 12:59:33:792 [6736] DEBUG - It took 0.000000 sec to serialize a list with 2 elements.
Jul 22, 2013 12:59:33:795 [1924] DEBUG - Request: GET /servers [127.0.0.1:53613] (6 live)
Jul 22, 2013 12:59:33:797 [1924] DEBUG - It took 0.000000 sec to serialize a list with 2 elements.
Jul 22, 2013 12:59:33:962 [0952] DEBUG - Request: GET /web/index.html [127.0.0.1:53615] (7 live)
Jul 22, 2013 12:59:33:963 [0952] DEBUG - Final path: C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\index.html
Jul 22, 2013 12:59:33:963 [0952] DEBUG - Content-Length of C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\index.html is 3258.
Jul 22, 2013 12:59:33:978 [0952] DEBUG - Request: GET / [127.0.0.1:53617] (7 live)
Jul 22, 2013 12:59:33:979 [0952] DEBUG - It took 0.001000 sec to serialize a list with 7 elements.
Jul 22, 2013 12:59:33:979 [6160] DEBUG - Request: GET /library/sections [192.168.56.1:53618] (7 live)
Jul 22, 2013 12:59:33:980 [6736] DEBUG - Request: GET /library/sections [192.168.56.1:53619] (7 live)
Jul 22, 2013 12:59:33:981 [6160] DEBUG - It took 0.000000 sec to serialize a list with 0 elements.
Jul 22, 2013 12:59:33:981 [6736] DEBUG - It took 0.000000 sec to serialize a list with 0 elements.
Jul 22, 2013 12:59:33:985 [6060] DEBUG - Bonjour: DNSServiceBrowse_Callback: sdRef = 0x00D81118, flags = 2, interfaceIndex = 11, code = 0
Jul 22, 2013 12:59:33:985 [6060] DEBUG - Bonjour: DNSServiceBrowse_Callback: serviceName = TireTread, regtype = _plexmediasvr._tcp., replyDomain = local.
Jul 22, 2013 12:59:33:986 [6060] DEBUG - Bonjour: DNSServiceBrowse_Callback: calling DNSServiceResolve on TireTread
Jul 22, 2013 12:59:33:988 [6060] DEBUG - Bonjour: DNSServiceResolve succeeded, adding reference 0x06469568, new ResolveContext instance 0x23D58032
Jul 22, 2013 12:59:33:989 [6060] DEBUG - Bonjour: DNSServiceBrowse_Callback: sdRef = 0x00D81118, flags = 3, interfaceIndex = 13, code = 0
Jul 22, 2013 12:59:33:989 [6060] DEBUG - Bonjour: DNSServiceBrowse_Callback: serviceName = TireTread, regtype = _plexmediasvr._tcp., replyDomain = local.
Jul 22, 2013 12:59:33:989 [6060] DEBUG - Bonjour: DNSServiceBrowse_Callback: calling DNSServiceResolve on TireTread
Jul 22, 2013 12:59:33:992 [6060] DEBUG - Bonjour: DNSServiceResolve succeeded, adding reference 0x064695C0, new ResolveContext instance 0x23D58032
Jul 22, 2013 12:59:33:992 [6060] DEBUG - Bonjour: DNSServiceBrowse_Callback: sdRef = 0x00D81118, flags = 3, interfaceIndex = 14, code = 0
Jul 22, 2013 12:59:33:992 [6060] DEBUG - Bonjour: DNSServiceBrowse_Callback: serviceName = TireTread, regtype = _plexmediasvr._tcp., replyDomain = local.
Jul 22, 2013 12:59:33:992 [6060] DEBUG - Bonjour: DNSServiceBrowse_Callback: calling DNSServiceResolve on TireTread
Jul 22, 2013 12:59:33:995 [6060] DEBUG - Bonjour: DNSServiceResolve succeeded, adding reference 0x06469618, new ResolveContext instance 0x23D58032
Jul 22, 2013 12:59:33:995 [6060] DEBUG - Bonjour: DNSServiceBrowse_Callback: sdRef = 0x00D81118, flags = 2, interfaceIndex = 18, code = 0
Jul 22, 2013 12:59:33:995 [6060] DEBUG - Bonjour: DNSServiceBrowse_Callback: serviceName = TireTread, regtype = _plexmediasvr._tcp., replyDomain = local.
Jul 22, 2013 12:59:33:995 [6060] DEBUG - Bonjour: DNSServiceBrowse_Callback: calling DNSServiceResolve on TireTread
Jul 22, 2013 12:59:33:996 [1924] DEBUG - Request: GET /web/css/plex.css?hash=59bbef8&version=1.1.3 [127.0.0.1:53616] (7 live)
Jul 22, 2013 12:59:33:996 [1924] DEBUG -  * hash => 59bbef8
Jul 22, 2013 12:59:33:996 [1924] DEBUG -  * version => 1.1.3
Jul 22, 2013 12:59:33:997 [1924] DEBUG - Final path: C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\css\plex.css
Jul 22, 2013 12:59:33:997 [1924] DEBUG - Content-Length of C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\css\plex.css is 248745.
Jul 22, 2013 12:59:33:998 [6160] DEBUG - Request: GET /web/js/plex.js?hash=59bbef8&version=1.1.3 [127.0.0.1:53624] (6 live)
Jul 22, 2013 12:59:33:998 [6160] DEBUG -  * hash => 59bbef8
Jul 22, 2013 12:59:33:998 [6160] DEBUG -  * version => 1.1.3
Jul 22, 2013 12:59:33:998 [6160] DEBUG - Final path: C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\js\plex.js
Jul 22, 2013 12:59:33:998 [6160] DEBUG - Content-Length of C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\js\plex.js is 1323291.
Jul 22, 2013 12:59:33:999 [6060] DEBUG - Bonjour: DNSServiceResolve succeeded, adding reference 0x06469670, new ResolveContext instance 0x23D58032
Jul 22, 2013 12:59:33:999 [6060] DEBUG - Bonjour: DNSServiceResolve_Callback: sdResolveRef = 0x00D8CB40, flags = 0, interfaceIndex = 11, code = 0
Jul 22, 2013 12:59:34:000 [6060] DEBUG - Bonjour: DNSServiceResolve_Callback: fullname = TireTread._plexmediasvr._tcp.local., hosttarget = TireTread.local., tcpport = 36990, txtLen = 113
Jul 22, 2013 12:59:34:000 [6060] DEBUG - Bonjour: DNSServiceResolve_Callback: resolved TXT record for TireTread._plexmediasvr._tcp.local.: host = TireTread.local., machineIdentifier = e023f7052c9588f2a10b2781caea8b6f017b31cc, version = 0.9.7.28-f80a4a2
Jul 22, 2013 12:59:34:037 [0952] DEBUG - Request: GET /channels/all [192.168.56.1:53629] (6 live)
Jul 22, 2013 12:59:34:038 [0952] DEBUG - It took 0.000000 sec to serialize a list with 0 elements.
Jul 22, 2013 12:59:34:044 [7136] DEBUG - Request: GET /channels/all [192.168.56.1:53632] (6 live)
Jul 22, 2013 12:59:34:044 [7136] DEBUG - It took 0.000000 sec to serialize a list with 0 elements.
Jul 22, 2013 12:59:34:064 [0952] DEBUG - Request: GET /web/img/background.png [127.0.0.1:53634] (6 live)
Jul 22, 2013 12:59:34:064 [0952] DEBUG - Final path: C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\img\background.png
Jul 22, 2013 12:59:34:064 [0952] DEBUG - Content-Length of C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\img\background.png is 12626.
Jul 22, 2013 12:59:34:069 [1924] DEBUG - Request: GET /web/img/myplex.png [127.0.0.1:53635] (6 live)
Jul 22, 2013 12:59:34:069 [1924] DEBUG - Final path: C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\img\myplex.png
Jul 22, 2013 12:59:34:070 [1924] DEBUG - Content-Length of C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\img\myplex.png is 92346.
Jul 22, 2013 12:59:34:086 [6256] DEBUG - [com.plexapp.system] HTTP reply status 200, with 0 bytes of content.
Jul 22, 2013 12:59:34:090 [5880] DEBUG - [com.plexapp.system] HTTP reply status 200, with 0 bytes of content.
Jul 22, 2013 12:59:34:635 [6736] DEBUG - Request: GET /:/plugins/com.plexapp.agents.htbackdrops [127.0.0.1:53638] (6 live)
Jul 22, 2013 12:59:34:635 [6736] WARN - Request for plug-in [com.plexapp.agents.htbackdrops] but it doesn't exist.
Jul 22, 2013 12:59:34:652 [0952] DEBUG - Request: GET /:/plugins/com.plexapp.agents.imdb [127.0.0.1:53639] (6 live)
Jul 22, 2013 12:59:34:652 [0952] WARN - Request for plug-in [com.plexapp.agents.imdb] but it doesn't exist.
Jul 22, 2013 12:59:34:673 [7136] DEBUG - Request: GET /:/plugins/com.plexapp.agents.lastfm [127.0.0.1:53640] (6 live)
Jul 22, 2013 12:59:34:673 [7136] WARN - Request for plug-in [com.plexapp.agents.lastfm] but it doesn't exist.
Jul 22, 2013 12:59:34:696 [6160] DEBUG - Request: GET /:/plugins/com.plexapp.agents.localmedia [127.0.0.1:53641] (6 live)
Jul 22, 2013 12:59:34:696 [6160] WARN - Request for plug-in [com.plexapp.agents.localmedia] but it doesn't exist.
Jul 22, 2013 12:59:34:764 [3020] DEBUG - iTunes: Loading tracks...
Jul 22, 2013 12:59:35:092 [3020] DEBUG - iTunes: Completed reading 1044 tracks in 0.3 seconds.
Jul 22, 2013 12:59:35:097 [3020] DEBUG - Skipping iTunes playlist: Library (0, -1)
Jul 22, 2013 12:59:35:102 [3020] DEBUG - Skipping iTunes playlist: Music (1, 4)
Jul 22, 2013 12:59:35:104 [3020] DEBUG - Skipping iTunes playlist: Movies (1, 2)
Jul 22, 2013 12:59:35:104 [3020] DEBUG - Skipping iTunes playlist: TV Shows (1, 3)
Jul 22, 2013 12:59:35:104 [3020] DEBUG - Skipping iTunes playlist: Books (1, 5)
Jul 22, 2013 12:59:35:105 [3020] DEBUG - Skipping iTunes playlist: Purchased (1, 19)
Jul 22, 2013 12:59:35:105 [3020] DEBUG - Skipping iTunes playlist: Genius (1, 26)
Jul 22, 2013 12:59:35:105 [3020] DEBUG - Skipping iTunes playlist: iTunes DJ (1, 22)
Jul 22, 2013 12:59:35:105 [3020] DEBUG - Skipping iTunes playlist: 90’s Music (1, 200)
Jul 22, 2013 12:59:35:106 [3020] DEBUG - Skipping iTunes playlist: Music Videos (1, 205)
Jul 22, 2013 12:59:35:106 [3020] DEBUG - Skipping iTunes playlist: My Top Rated (1, 201)
Jul 22, 2013 12:59:35:106 [3020] DEBUG - Skipping iTunes playlist: Recently Added (1, 204)
Jul 22, 2013 12:59:35:106 [3020] DEBUG - Skipping iTunes playlist: Recently Played (1, 203)
Jul 22, 2013 12:59:35:106 [3020] DEBUG - Skipping iTunes playlist: Top 25 Most Played (1, 202)
Jul 22, 2013 12:59:35:107 [3020] DEBUG - Skipping iTunes playlist: Voice Memos (1, 17)
Jul 22, 2013 12:59:35:224 [0952] DEBUG - Request: GET /web/swf/soundmanager/soundmanager2_flash9.swf [127.0.0.1:53644] (6 live)
Jul 22, 2013 12:59:35:224 [7136] DEBUG - Request: GET /web/localizations/en.json [127.0.0.1:53643] (6 live)
Jul 22, 2013 12:59:35:224 [6736] DEBUG - Request: GET /web/font/DejaVuSansCondensed.woff [127.0.0.1:53645] (6 live)
Jul 22, 2013 12:59:35:224 [0952] DEBUG - Final path: C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\swf\soundmanager\soundmanager2_flash9.swf
Jul 22, 2013 12:59:35:224 [7136] DEBUG - Final path: C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\localizations\en.json
Jul 22, 2013 12:59:35:224 [6736] DEBUG - Final path: C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\font\DejaVuSansCondensed.woff
Jul 22, 2013 12:59:35:224 [0952] DEBUG - Content-Length of C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\swf\soundmanager\soundmanager2_flash9.swf is 8683.
Jul 22, 2013 12:59:35:224 [7136] DEBUG - Content-Length of C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\localizations\en.json is 45915.
Jul 22, 2013 12:59:35:225 [6736] DEBUG - Content-Length of C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\font\DejaVuSansCondensed.woff is 21452.
Jul 22, 2013 12:59:35:225 [6160] DEBUG - Request: GET / [127.0.0.1:53642] (6 live)
Jul 22, 2013 12:59:35:225 [6160] DEBUG - It took 0.000000 sec to serialize a list with 7 elements.
Jul 22, 2013 12:59:35:509 [6160] DEBUG - Request: GET /:/plugins/com.plexapp.agents.movieposterdb [127.0.0.1:53651] (6 live)
Jul 22, 2013 12:59:35:509 [6160] WARN - Request for plug-in [com.plexapp.agents.movieposterdb] but it doesn't exist.
Jul 22, 2013 12:59:35:524 [7136] DEBUG - Request: GET /:/plugins/com.plexapp.agents.opensubtitles [127.0.0.1:53652] (6 live)
Jul 22, 2013 12:59:35:524 [7136] WARN - Request for plug-in [com.plexapp.agents.opensubtitles] but it doesn't exist.
Jul 22, 2013 12:59:35:543 [6736] DEBUG - Request: GET /:/plugins/com.plexapp.agents.none [127.0.0.1:53653] (6 live)
Jul 22, 2013 12:59:35:543 [6736] WARN - Request for plug-in [com.plexapp.agents.none] but it doesn't exist.
Jul 22, 2013 12:59:35:557 [6736] DEBUG - Request: GET /:/plugins/com.plexapp.agents.plexthememusic [127.0.0.1:53654] (6 live)
Jul 22, 2013 12:59:35:557 [6736] WARN - Request for plug-in [com.plexapp.agents.plexthememusic] but it doesn't exist.
Jul 22, 2013 12:59:35:854 [3020] DEBUG - Loading com.plexapp.plugins.itunes is complete (success=1)
Jul 22, 2013 12:59:35:879 [6736] DEBUG - Request: GET /web/font/glyphicons-regular.woff [127.0.0.1:53655] (6 live)
Jul 22, 2013 12:59:35:880 [6736] DEBUG - Final path: C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\font\glyphicons-regular.woff
Jul 22, 2013 12:59:35:880 [6736] DEBUG - Content-Length of C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\font\glyphicons-regular.woff is 90916.
Jul 22, 2013 12:59:35:880 [7136] DEBUG - Request: GET /web/img/navbar/divider.png [127.0.0.1:53656] (6 live)
Jul 22, 2013 12:59:35:880 [7136] DEBUG - Final path: C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\img avbar\divider.png
Jul 22, 2013 12:59:35:881 [7136] DEBUG - Content-Length of C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\img avbar\divider.png is 582.
Jul 22, 2013 12:59:35:884 [3020] DEBUG - iTunes: There are 935 audio tracks and 109 video tracks.
Jul 22, 2013 12:59:35:953 [6160] DEBUG - Request: GET /servers [127.0.0.1:53658] (6 live)
Jul 22, 2013 12:59:35:954 [6160] DEBUG - It took 0.000000 sec to serialize a list with 2 elements.
Jul 22, 2013 12:59:35:973 [6736] DEBUG - Request: GET / [127.0.0.1:53660] (6 live)
Jul 22, 2013 12:59:35:974 [6736] DEBUG - It took 0.000000 sec to serialize a list with 9 elements.
Jul 22, 2013 12:59:35:975 [6736] DEBUG - Request: GET /:/prefs [127.0.0.1:53661] (6 live)
Jul 22, 2013 12:59:35:978 [0952] DEBUG - Request: GET /system/appstore/history [127.0.0.1:53662] (6 live)
Jul 22, 2013 12:59:35:978 [0952] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /system/appstore/history
Jul 22, 2013 12:59:35:979 [0952] DEBUG - HTTP requesting to: http://127.0.0.1:53597/system/appstore/history
Jul 22, 2013 12:59:35:987 [6160] DEBUG - Request: GET /library/sections [127.0.0.1:53664] (6 live)
Jul 22, 2013 12:59:35:988 [6160] DEBUG - It took 0.000000 sec to serialize a list with 0 elements.
Jul 22, 2013 12:59:35:993 [1924] DEBUG - Request: GET /system/appstore/featured [127.0.0.1:53665] (6 live)
Jul 22, 2013 12:59:35:993 [1924] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /system/appstore/featured
Jul 22, 2013 12:59:35:994 [1924] DEBUG - HTTP requesting to: http://127.0.0.1:53597/system/appstore/featured
Jul 22, 2013 12:59:35:997 [6160] DEBUG - Request: GET /myplex/account [127.0.0.1:53667] (6 live)
Jul 22, 2013 12:59:36:001 [6160] DEBUG - Request: GET /system/agents [127.0.0.1:53668] (6 live)
Jul 22, 2013 12:59:36:002 [6160] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /system/agents
Jul 22, 2013 12:59:36:002 [6160] DEBUG - HTTP requesting to: http://127.0.0.1:53597/system/agents
Jul 22, 2013 12:59:36:012 [0952] DEBUG - [com.plexapp.system] HTTP reply status 200, with 321 bytes of content.
Jul 22, 2013 12:59:36:032 [7136] DEBUG - Request: GET /web/favicon.ico [127.0.0.1:53672] (7 live)
Jul 22, 2013 12:59:36:032 [6736] DEBUG - Request: GET /web/font/DejaVuSansCondensedBold.woff [127.0.0.1:53671] (7 live)
Jul 22, 2013 12:59:36:033 [6736] DEBUG - Final path: C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\font\DejaVuSansCondensedBold.woff
Jul 22, 2013 12:59:36:033 [7136] DEBUG - Final path: C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\favicon.ico
Jul 22, 2013 12:59:36:033 [6736] DEBUG - Content-Length of C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\font\DejaVuSansCondensedBold.woff is 21336.
Jul 22, 2013 12:59:36:033 [7136] DEBUG - Content-Length of C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\favicon.ico is 2334.
Jul 22, 2013 12:59:36:161 [0952] DEBUG - Request: GET /:/websockets/notifications [127.0.0.1:53670] (6 live)
Jul 22, 2013 12:59:36:162 [0952] DEBUG - Creating a WebSocket for notification stream
Jul 22, 2013 12:59:36:162 [0952] DEBUG - WebSocket: Performing handshake from origin http://127.0.0.1:32400
Jul 22, 2013 12:59:36:162 [0952] DEBUG - Beginning read from WebSocket
Jul 22, 2013 12:59:36:662 [6060] DEBUG - Bonjour: MonitorTxtRecord - DNSServiceConstructFullName succeeded: TireTread._plexmediasvr._tcp.local.
Jul 22, 2013 12:59:36:664 [6060] DEBUG - Bonjour: DNSServiceQueryRecord succeeded, QueryRecordContext = 0x008CCD30
Jul 22, 2013 12:59:36:664 [6060] INFO - Bonjour: adding host - name = TireTread, hostname - TireTread.local., machineIdentifier = e023f7052c9588f2a10b2781caea8b6f017b31cc
Jul 22, 2013 12:59:36:664 [6060] DEBUG - Bonjour: DNSServiceResolve_Callback: removing reference 0x00D8CB40, deleting ResolveContext instance 0x06469568
Jul 22, 2013 12:59:36:664 [6060] DEBUG - Bonjour: DNSServiceResolve_Callback: sdResolveRef = 0x00D8CB80, flags = 0, interfaceIndex = 13, code = 0
Jul 22, 2013 12:59:36:664 [6060] DEBUG - Bonjour: DNSServiceResolve_Callback: fullname = TireTread._plexmediasvr._tcp.local., hosttarget = TireTread.local., tcpport = 36990, txtLen = 113
Jul 22, 2013 12:59:36:664 [6060] DEBUG - Bonjour: DNSServiceResolve_Callback: resolved TXT record for TireTread._plexmediasvr._tcp.local.: host = TireTread.local., machineIdentifier = e023f7052c9588f2a10b2781caea8b6f017b31cc, version = 0.9.7.28-f80a4a2
Jul 22, 2013 12:59:36:777 [6468] DEBUG - Device: Microsoft PC
Jul 22, 2013 12:59:36:778 [6468] DEBUG - HTTP requesting to: http://www.google-analytics.com/collect
Jul 22, 2013 12:59:36:815 [0952] DEBUG - Request: GET /:/plugins/com.plexapp.agents.themoviedb [127.0.0.1:53690] (7 live)
Jul 22, 2013 12:59:36:816 [0952] WARN - Request for plug-in [com.plexapp.agents.themoviedb] but it doesn't exist.
Jul 22, 2013 12:59:36:834 [7136] DEBUG - Request: GET /:/plugins/com.plexapp.agents.thetvdb [127.0.0.1:53691] (7 live)
Jul 22, 2013 12:59:36:834 [7136] WARN - Request for plug-in [com.plexapp.agents.thetvdb] but it doesn't exist.
Jul 22, 2013 12:59:36:876 [6468] DEBUG - Sent analytics request: 200
Jul 22, 2013 12:59:37:827 [0952] DEBUG - Request: GET /:/plugins/com.plexapp.agents.wikipedia [127.0.0.1:53694] (7 live)
Jul 22, 2013 12:59:37:827 [0952] WARN - Request for plug-in [com.plexapp.agents.wikipedia] but it doesn't exist.
Jul 22, 2013 12:59:37:860 [1232] DEBUG - [com.plexapp.system] HTTP reply status 200, with 130 bytes of content.
Jul 22, 2013 12:59:37:860 [1232] DEBUG - The system knows about 0 agents.
Jul 22, 2013 12:59:37:861 [1232] DEBUG - Waiting for all 18 plug-ins to finish starting.
Jul 22, 2013 12:59:37:861 [1176] DEBUG - Starting plug-in C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle.
Jul 22, 2013 12:59:37:861 [3148] DEBUG - Starting plug-in C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\HTbackdrops.bundle.
Jul 22, 2013 12:59:37:862 [1176] DEBUG - Starting plug-in C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\IMDB.bundle.
Jul 22, 2013 12:59:37:863 [3148] DEBUG - [com.plexapp.agents.htbackdrops] Agent not known by system, so we're starting for sure.
Jul 22, 2013 12:59:37:863 [3148] DEBUG - Starting file watcher for com.plexapp.agents.htbackdrops
Jul 22, 2013 12:59:37:863 [3148] DEBUG - Plugin::createProcess: Creating plugin process: "C:\Program Files (x86)\Plex\Plex Media Server\PlexScriptHost.exe" "C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle\Contents\Resources\Versions\2\Python/bootstrap.py" "C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\HTbackdrops.bundle"
Jul 22, 2013 12:59:37:864 [3148] DEBUG - Spawned plug-in com.plexapp.agents.htbackdrops with PID 1328
Jul 22, 2013 12:59:37:864 [3148] DEBUG - [com.plexapp.agents.htbackdrops] Sent command: GET /:/prefixes
Jul 22, 2013 12:59:37:865 [4408] DEBUG - Starting plug-in C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\LastFM.bundle.
Jul 22, 2013 12:59:37:865 [6160] DEBUG - [com.plexapp.system] HTTP reply status 200, with 130 bytes of content.
Jul 22, 2013 12:59:37:867 [1176] DEBUG - [com.plexapp.agents.imdb] Agent not known by system, so we're starting for sure.
Jul 22, 2013 12:59:37:867 [1176] DEBUG - Starting file watcher for com.plexapp.agents.imdb
Jul 22, 2013 12:59:37:867 [1176] DEBUG - Plugin::createProcess: Creating plugin process: "C:\Program Files (x86)\Plex\Plex Media Server\PlexScriptHost.exe" "C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle\Contents\Resources\Versions\2\Python/bootstrap.py" "C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\IMDB.bundle"
Jul 22, 2013 12:59:37:869 [1176] DEBUG - Spawned plug-in com.plexapp.agents.imdb with PID 5036
Jul 22, 2013 12:59:37:869 [1176] DEBUG - [com.plexapp.agents.imdb] Sent command: GET /:/prefixes
Jul 22, 2013 12:59:37:871 [4408] DEBUG - [com.plexapp.agents.lastfm] Agent not known by system, so we're starting for sure.
Jul 22, 2013 12:59:37:871 [4408] DEBUG - Starting file watcher for com.plexapp.agents.lastfm
Jul 22, 2013 12:59:37:872 [0952] DEBUG - Request: GET /web/img/sad.png [127.0.0.1:53695] (7 live)
Jul 22, 2013 12:59:37:873 [0952] DEBUG - Final path: C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\img\sad.png
Jul 22, 2013 12:59:37:873 [0952] DEBUG - Content-Length of C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\img\sad.png is 3080.
Jul 22, 2013 12:59:37:881 [4408] DEBUG - Plugin::createProcess: Creating plugin process: "C:\Program Files (x86)\Plex\Plex Media Server\PlexScriptHost.exe" "C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle\Contents\Resources\Versions\2\Python/bootstrap.py" "C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\LastFM.bundle"
Jul 22, 2013 12:59:37:884 [4408] DEBUG - Spawned plug-in com.plexapp.agents.lastfm with PID 6552
Jul 22, 2013 12:59:37:884 [4408] DEBUG - [com.plexapp.agents.lastfm] Sent command: GET /:/prefixes
Jul 22, 2013 12:59:37:939 [5204] DEBUG - [com.plexapp.system] HTTP reply status 200, with 90212 bytes of content.
Jul 22, 2013 12:59:38:660 [1924] DEBUG - [com.plexapp.system] HTTP reply status 200, with 7541 bytes of content.
Jul 22, 2013 12:59:38:711 [1924] DEBUG - Request: GET /photo/:/transcode?url=http%3A%2F%2Fresources-cdn.plexapp.com%2Fimage%2Fsource%2Fcom.plexapp.plugins.amt.jpg&width=128&height=128 [127.0.0.1:53699] (10 live)
Jul 22, 2013 12:59:38:711 [1924] DEBUG -  * url => http://resources-cdn.plexapp.com/image/source/com.plexapp.plugins.amt.jpg
Jul 22, 2013 12:59:38:711 [5204] DEBUG - Request: GET /web/img/posters/poster_square.png [127.0.0.1:53698] (10 live)
Jul 22, 2013 12:59:38:711 [1924] DEBUG -  * width => 128
Jul 22, 2013 12:59:38:711 [1924] DEBUG -  * height => 128
Jul 22, 2013 12:59:38:711 [6160] DEBUG - Request: GET /photo/:/transcode?url=http%3A%2F%2Fresources-cdn.plexapp.com%2Fimage%2Fsource%2Fcom.plexapp.plugins.thecolbertreport.jpg&width=128&height=128 [127.0.0.1:53700] (10 live)
Jul 22, 2013 12:59:38:712 [5204] DEBUG - Final path: C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\img\posters\poster_square.png
Jul 22, 2013 12:59:38:712 [7136] DEBUG - Request: GET /photo/:/transcode?url=http%3A%2F%2Fresources-cdn.plexapp.com%2Fimage%2Fsource%2Fcom.plexapp.plugins.thedailyshow.jpg&width=128&height=128 [127.0.0.1:53701] (9 live)
Jul 22, 2013 12:59:38:712 [5204] DEBUG - Content-Length of C:\Users\myusername\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle\Contents\Resources\img\posters\poster_square.png is 44423.
Jul 22, 2013 12:59:38:712 [7136] DEBUG -  * width => 128
Jul 22, 2013 12:59:38:712 [7136] DEBUG -  * height => 128
Jul 22, 2013 12:59:38:712 [6160] DEBUG -  * width => 128
Jul 22, 2013 12:59:38:712 [6160] DEBUG -  * height => 128
Jul 22, 2013 12:59:38:713 [0952] DEBUG - Request: GET /photo/:/transcode?url=http%3A%2F%2Fnine.plugins.plexapp.com%2Fsystem%2Fbundles%2F3733%2Foriginal%2FFunny-or-Die.bundle%2FContents%2FResources%2Ficon-default.png&width=128&height=128 [127.0.0.1:53702] (8 live)
Jul 22, 2013 12:59:38:713 [0952] DEBUG -  * width => 128
Jul 22, 2013 12:59:38:713 [0952] DEBUG -  * height => 128
Jul 22, 2013 12:59:38:716 [4252] DEBUG - Request: GET /photo/:/transcode?url=http%3A%2F%2Fnine.plugins.plexapp.com%2Fsystem%2Fbundles%2F3426%2Foriginal%2FLive-Music-Archive.bundle%2FContents%2FResources%2Ficon-default.png&width=128&height=128 [127.0.0.1:53703] (9 live)
Jul 22, 2013 12:59:38:716 [4252] DEBUG -  * width => 128
Jul 22, 2013 12:59:38:716 [4252] DEBUG -  * height => 128
Jul 22, 2013 12:59:38:719 [5424] DEBUG - Request: GET /photo/:/transcode?url=http%3A%2F%2Fnine.plugins.plexapp.com%2Fsystem%2Fbundles%2F3790%2Foriginal%2FPBS.bundle%2FContents%2FResources%2Ficon-default.png&width=128&height=128 [127.0.0.1:53704] (9 live)
Jul 22, 2013 12:59:38:720 [5424] DEBUG -  * width => 128
Jul 22, 2013 12:59:38:720 [5424] DEBUG -  * height => 128
Jul 22, 2013 12:59:38:731 [4252] DEBUG - Photo transcoder: Request for url [http://nine.plugins.plexapp.com/system/bundles/3426/original/Live-Music-Archive.bundle/Contents/Resources/icon-default.png] (is local: 0 upscaled: 0)
Jul 22, 2013 12:59:38:733 [0952] DEBUG - Photo transcoder: Request for url [http://nine.plugins.plexapp.com/system/bundles/3733/original/Funny-or-Die.bundle/Contents/Resources/icon-default.png] (is local: 0 upscaled: 0)
Jul 22, 2013 12:59:38:735 [5424] DEBUG - Photo transcoder: Request for url [http://nine.plugins.plexapp.com/system/bundles/3790/original/PBS.bundle/Contents/Resources/icon-default.png] (is local: 0 upscaled: 0)
Jul 22, 2013 12:59:38:772 [7136] DEBUG - Photo transcoder: Request for url [http://resources-cdn.plexapp.com/image/source/com.plexapp.plugins.thedailyshow.jpg] (is local: 0 upscaled: 0)
Jul 22, 2013 12:59:38:772 [1924] DEBUG - Photo transcoder: Request for url [http://resources-cdn.plexapp.com/image/source/com.plexapp.plugins.amt.jpg] (is local: 0 upscaled: 0)
Jul 22, 2013 12:59:38:790 [5424] DEBUG - Photo cache obtained 8390 bytes from http://nine.plugins.plexapp.com/system/bundles/3790/original/PBS.bundle/Contents/Resources/icon-default.png
Jul 22, 2013 12:59:38:791 [5424] DEBUG - Saving original media file to C:\Users\myusername\AppData\Local\Plex Media Server\Cache\PhotoTranscoder\8b\8b3cf6af64fcbdd77900e10450114396457d08c0.jpg
Jul 22, 2013 12:59:38:791 [6160] DEBUG - Photo transcoder: Request for url [http://resources-cdn.plexapp.com/image/source/com.plexapp.plugins.thecolbertreport.jpg] (is local: 0 upscaled: 0)
Jul 22, 2013 12:59:38:806 [6160] DEBUG - HTTP requesting to: http://resources-cdn.plexapp.com/image/source/com.plexapp.plugins.thecolbertreport.jpg
Jul 22, 2013 12:59:38:807 [5424] DEBUG - Created thumbnail of size 128x128, has pixels: 1
Jul 22, 2013 12:59:38:807 [1924] DEBUG - HTTP requesting to: http://resources-cdn.plexapp.com/image/source/com.plexapp.plugins.amt.jpg
Jul 22, 2013 12:59:38:811 [7136] DEBUG - HTTP requesting to: http://resources-cdn.plexapp.com/image/source/com.plexapp.plugins.thedailyshow.jpg
Jul 22, 2013 12:59:38:817 [6736] DEBUG - Request: GET /photo/:/transcode?url=http%3A%2F%2Fnine.plugins.plexapp.com%2Fsystem%2Fbundles%2F3683%2Foriginal%2FPitchfork-TV.bundle%2FContents%2FResources%2Ficon-default.png&width=128&height=128 [127.0.0.1:53708] (9 live)
Jul 22, 2013 12:59:38:817 [6736] DEBUG -  * width => 128
Jul 22, 2013 12:59:38:817 [6736] DEBUG -  * height => 128
Jul 22, 2013 12:59:38:833 [6736] DEBUG - Photo transcoder: Request for url [http://nine.plugins.plexapp.com/system/bundles/3683/original/Pitchfork-TV.bundle/Contents/Resources/icon-default.png] (is local: 0 upscaled: 0)
Jul 22, 2013 12:59:38:896 [0952] DEBUG - Photo cache obtained 63430 bytes from http://nine.plugins.plexapp.com/system/bundles/3733/original/Funny-or-Die.bundle/Contents/Resources/icon-default.png
Jul 22, 2013 12:59:38:896 [0952] DEBUG - Saving original media file to C:\Users\myusername\AppData\Local\Plex Media Server\Cache\PhotoTranscoder\c4\c4f0d2a99f43fbb3d45657d5c9e32b3241b78a3c.jpg
Jul 22, 2013 12:59:38:932 [0952] DEBUG - Created thumbnail of size 128x128, has pixels: 1
Jul 22, 2013 12:59:38:933 [6060] DEBUG - Bonjour: MonitorTxtRecord - DNSServiceConstructFullName succeeded: TireTread._plexmediasvr._tcp.local.
Jul 22, 2013 12:59:38:944 [6060] DEBUG - Bonjour: DNSServiceQueryRecord succeeded, QueryRecordContext = 0x008CCC98
Jul 22, 2013 12:59:38:944 [6060] WARN - Bonjour: updating duplicate host entry - name = TireTread, hostname - TireTread.local., machineIdentifier = e023f7052c9588f2a10b2781caea8b6f017b31cc
Jul 22, 2013 12:59:38:945 [6060] DEBUG - Bonjour: DNSServiceResolve_Callback: removing reference 0x00D8CB80, deleting ResolveContext instance 0x064695C0
Jul 22, 2013 12:59:38:945 [6060] DEBUG - Bonjour: DNSServiceResolve_Callback: sdResolveRef = 0x00D8CBC0, flags = 0, interfaceIndex = 14, code = 0
Jul 22, 2013 12:59:38:945 [6060] DEBUG - Bonjour: DNSServiceResolve_Callback: fullname = TireTread._plexmediasvr._tcp.local., hosttarget = TireTread.local., tcpport = 36990, txtLen = 113
Jul 22, 2013 12:59:38:945 [6060] DEBUG - Bonjour: DNSServiceResolve_Callback: resolved TXT record for TireTread._plexmediasvr._tcp.local.: host = TireTread.local., machineIdentifier = e023f7052c9588f2a10b2781caea8b6f017b31cc, version = 0.9.7.28-f80a4a2
Jul 22, 2013 12:59:38:947 [4944] DEBUG - Notifying the system bundle an update to server /system/notify/serverUpdated?host=TireTread.local.
Jul 22, 2013 12:59:38:947 [4944] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /system/notify/serverUpdated?host=TireTread.local.
Jul 22, 2013 12:59:38:947 [4944] DEBUG - HTTP requesting to: http://127.0.0.1:53597/system/notify/serverUpdated?host=TireTread.local.
Jul 22, 2013 12:59:38:973 [4252] DEBUG - Saving original media file to C:\Users\myusername\AppData\Local\Plex Media Server\Cache\PhotoTranscoder\21\21a69be3e615b2f75504feda6a6fb91797fef874.jpg
Jul 22, 2013 12:59:39:019 [4252] DEBUG - Created thumbnail of size 128x128, has pixels: 1
Jul 22, 2013 12:59:39:056 [7136] DEBUG - Photo cache obtained 57606 bytes from http://resources-cdn.plexapp.com/image/source/com.plexapp.plugins.thedailyshow.jpg
Jul 22, 2013 12:59:39:056 [7136] DEBUG - Saving original media file to C:\Users\myusername\AppData\Local\Plex Media Server\Cache\PhotoTranscoder\13\13712cc58f7d758793439f23b1fd38ec1f163380.jpg
Jul 22, 2013 12:59:39:070 [4252] DEBUG - Request: GET /photo/:/transcode?url=http%3A%2F%2Fnine.plugins.plexapp.com%2Fsystem%2Fbundles%2F3884%2Foriginal%2FPlex-Podcast.bundle%2FContents%2FResources%2Ficon-default.png&width=128&height=128 [127.0.0.1:53717] (11 live)
Jul 22, 2013 12:59:39:070 [4252] DEBUG -  * width => 128
Jul 22, 2013 12:59:39:070 [4252] DEBUG -  * height => 128
Jul 22, 2013 12:59:39:070 [6160] DEBUG - Photo cache obtained 65033 bytes from http://resources-cdn.plexapp.com/image/source/com.plexapp.plugins.thecolbertreport.jpg
Jul 22, 2013 12:59:39:070 [6160] DEBUG - Saving original media file to C:\Users\myusername\AppData\Local\Plex Media Server\Cache\PhotoTranscoder\4b\4b35ba5bab7c56eb38f41fc932244a21c6bcc09b.jpg
Jul 22, 2013 12:59:39:070 [0952] DEBUG - Request: GET /photo/:/transcode?url=http%3A%2F%2Fnine.plugins.plexapp.com%2Fsystem%2Fbundles%2F3837%2Foriginal%2FRevision3.bundle%2FContents%2FResources%2Ficon-default.png&width=128&height=128 [127.0.0.1:53718] (10 live)
Jul 22, 2013 12:59:39:071 [0952] DEBUG -  * width => 128
Jul 22, 2013 12:59:39:071 [0952] DEBUG -  * height => 128
Jul 22, 2013 12:59:39:085 [5204] DEBUG - Request: GET /servers [127.0.0.1:53719] (10 live)
Jul 22, 2013 12:59:39:085 [5204] DEBUG - It took 0.000000 sec to serialize a list with 3 elements.
Jul 22, 2013 12:59:39:098 [7136] DEBUG - Created thumbnail of size 128x128, has pixels: 1
Jul 22, 2013 12:59:39:114 [6736] DEBUG - Photo cache obtained 177602 bytes from http://nine.plugins.plexapp.com/system/bundles/3683/original/Pitchfork-TV.bundle/Contents/Resources/icon-default.png
Jul 22, 2013 12:59:39:114 [6736] DEBUG - Saving original media file to C:\Users\myusername\AppData\Local\Plex Media Server\Cache\PhotoTranscoder\62\625300c766ef7458ed1d93f2c5f85f0d807bbcef.jpg
Jul 22, 2013 12:59:39:116 [0952] DEBUG - Photo transcoder: Request for url [http://nine.plugins.plexapp.com/system/bundles/3837/original/Revision3.bundle/Contents/Resources/icon-default.png] (is local: 0 upscaled: 0)
Jul 22, 2013 12:59:39:117 [6160] DEBUG - Created thumbnail of size 128x128, has pixels: 1
Jul 22, 2013 12:59:39:118 [4252] DEBUG - Photo transcoder: Request for url [http://nine.plugins.plexapp.com/system/bundles/3884/original/Plex-Podcast.bundle/Contents/Resources/icon-default.png] (is local: 0 upscaled: 0)
Jul 22, 2013 12:59:39:165 [6736] DEBUG - Created thumbnail of size 128x128, has pixels: 1
Jul 22, 2013 12:59:39:171 [5204] DEBUG - Request: GET /photo/:/transcode?url=http%3A%2F%2Fnine.plugins.plexapp.com%2Fsystem%2Fbundles%2F3886%2Foriginal%2FTED-Talks.bundle%2FContents%2FResources%2Ficon-default.png&width=128&height=128 [127.0.0.1:53723] (10 live)
I am running Windows 7, 64 bit and  like globalmomma above, got this error during installation:
I've tried 3x  to paste the log life here but it's just too big. Is there any specific section that I need to focus on?
try click on the "More Reply Options" button at the botton of the "Reply to this topic" pane, and you can attach the log file to the post -- or you can throw it up on DropBox...
Well, Plex seemed to pop up after booting up this morning. I don't know enough about to try it out yet but I suspect all is not well considering my install error yesterday.
here's a link to a Dropbox folder with the log files i can find:  https://www.dropbox.com/home/Plex%20Log%20Files
Would appreciate any assistance. Thanks in advance.
Uploading logs, received following messege right after the installation and the initial startup. New user, running Windows 7 64 bit
Cibei
Jast as a note, Plex seems tp be running ok on new Roku box now (other than spme of the other issies noted in other threads about empty folders, etc), so maybe the installation was OK after all and the error message (that everyone seems to be getting) is a red herring?
