Default credentials to connect to an Ubuntu Plex appliance via ssh
I have been following the instructions at https://ubuntu.com/appliance/plex/raspberry-pi#macos to install plex onto a RPI.
Since I want to mount a NAS drive locally, I need to be able to ssh to the appliance.
Unfortunately, the instructions on how to connect via ssh do not work:
ssh <Ubuntu SSO user name>@<device IP address>
I have been looking on the web on how to ssh to plex. I found that I should use an ssh tunnel:
ssh <device IP address> -L 8888:localhost:32400
Now, the only missing parts are the credentials. What are the default credentials to ssh to the appliance?
Thanks in advance,
Emmanuel
I suppose this article should provide some better instructions (at least I hope so)
https://www.raspberrypi.org/documentation/remote-access/ssh/
Unfortunately not… the appliance comes with SSH already pre-configured and the default raspberry credentials are not working…
Did you follow the full guide, especially points 3 to 6?
It seems as you cannot simply SSH into the applicance without following the steps.
Yes. I tried both ways to connect with SSH:
$ ssh <Ubuntu One Username>@<IP>
<Ubuntu One Username>@<IP>'s password:
Permission denied, please try again.
<Ubuntu One Username>@<IP>: Permission denied (publickey).
and with the tunnel:
ssh <Ubuntu One Username>@<IP> -L 8888:localhost:32400
I also checked that my public ssh key was correctly setup at Ubuntu One.
If you would have set your keys correctly then you wouldn’t be asked for a password. I would suggest to repeat steps 3-6.
This was my absolute mistake. I did not follow the steps completely.
I assumed that I could plug and access the appliance via ssh with once the image was put on the SD card. I disregarded the step where you need to plugin a keyboard and a screen to the RPI.
Once the appliance boots up, it asks for your Ubuntu One email address. With that, it creates your local account and copies over your SSH key…
Great, good to hear that it was resolved. I didn’t get 100 % how this works either, just thought that something wasn’t right :wink:
