Hello!
I have successfully installed rasplex on the SD card.
Keyboard- Is there no way to finish the config without an actual wired keyboard? After having used and tossed many over the years its not like I have any more just lying around!
Remotes- I don't understand how or which device or which app to use. iphone, ipad, Remote Pi, RasPiConnect, via plex.app, plexmediaserver.app, plex for ios
Streaming- via wifi? via ethernet?
SSH- connection refused, but I can ping it
Thank you
Just try to use a remote app (Plex or XBMC)
I use a mini wireless keyboard for RasPlex. It works like a remote, but with the benefit of a keyboard and doesn't require any config either. There are plenty available, but the one I bought (and would thoroughly recommend) is this one (link to Amazon UK, price there is £19.99):
http://www.amazon.co.uk/Wireless-Touchpad-Multimedia-XBOX360-Android/dp/B009TF0HSM/ref=sr_1_6?ie=UTF8&qid=1370080003&sr=8-6&keywords=justop+mini+wireless+keyboard
SSH - There are various combinations of user+pwd around the forums. The one that works for me is root+rasplex.
Thank you for answering.
- PLEX IOS app does not see the Pi. FAIL!
"connection refused" with ssh root@theipaddress
rasplex.home b8:27:eb:d:6a:62 UHLWIi 0 65582 en1 1195
traceroute to 192.168.1.8 (192.168.1.8), 64 hops max, 72 byte packets
1 rasplex (192.168.1.8) 3.400 ms 1.455 ms 1.371 ms
Port Scanning host: 192.168.1.8
Open TCP Port: 3005 geniuslm
Open TCP Port: 36666
Open TCP Port: 36667
Port Scan has completed…
3005 deslogin encryted symmetric telnet/login
PC Name:
rasplex
Connection Type:
<img height="16" src="http://192.168.1.1/images/actiontec_sm_eth.gif" width="16" alt="actiontec_sm_eth.gif">
Ethernet
IP Address:
192.168.1.8
Status:
Active
Do I need to add port forwarding for this device? The only entry I have is for PMS (on my Mac) tcp/udp to 32400
Also I don't understand if the config is to be done via wifi or ethernet. My router doesn't see it with the wifi dongle connected.
No idea what to do other than get a keyboard.
What about writing the config directly to the SD card or is that crazy?
This might be fun http://www.dailymotion.com/video/xl3l8s_hack-your-macbook-keyboard-to-usb-fix-your-dead-mac_tech#.Uapqruvud-N hahaaha
For ssh, it seems to be bugged where you have to toggle ssh enabled off then on in the options to be able to ssh into it.
which one? There are about 12
thanks
