Deleteing dirctory
How do I delete media and delete the directory where the media is located and delete other files with the same path as the media file, for example: a / b / xxx.mp4 a / b / xxx.jpg Delete b when deleting the media in the plex
  1. Delete the folder
  2. Scan Library Files for the linked library in Plex (e.g. from the ... context menu of that library or Settings > Server > Manage > Libraries)
Edit:
If you have configured Plex not to automatically empty its Trash after every update, you might need to manually trigger Empty Trash (library context menu: ... > Manage Library > Empty Trash)
