Deleting Media from Client
This has the potential to be a useful feature since it’s easy to delete a movie once watched using the client, but if your movies are organised together with an accompanying poster in a folder as below…
Movies/
…Avatar (2009)/
…Avatar (2009).mkv
…then it only deletes the video file itself. Since you then have to delete the jpg and containing folder anyway (in Finder/Windows Explorer), isn’t it counter-productive as you actually end up deleting it twice (once using the client and another in using your computer).
Is it possible to introduce an option such that you can either just delete the file, if that’s all you have, or instead the top level folder for that particular movie if that’s how your structure works? Seems redundant otherwise for anyone that uses custom artwork or even just keeps their movies in separate folders.
http://forums.plexapp.com/index.php/topic/46319-remove-empty-directories/page__p__311845__fromsearch__1
