DENMARK: Lots of missing channels
Did a report of missing channels today. Using Stofa full pack over fiber in Silkeborg.
Btw, if you’re using Stofa - what channel-IDs does your channels list as? Mine starts at 5000 :flushed:
I’m using a HDHomeRun HDHR5-4DT, Firmware 20200907
In the HDHomeRun Setup I only put in Modulation “qam 64” and Symbolrate “6900”. From this I get 111 channel incl radio channels.
Using You See and also miss a lot og Chanels, and it also indicates that what for me is free channels are marked af scrambled.
Any updates to this problem??
Any news, still missing lots of You See programs
I am missing the local channels, TV2 Østjylland and Kanal Østjylland in my case. Not to be found on EPG, but show up in the channel list (now mapped as RAI and something else, with no meaningful EPG)
I still miss a lot of Danish channels, any other with the same problem?
Yes! I also miss a lot of danish channels. No Word from the Plex team
any update
My Plex has suddenly startet loosing all the EPG guides
I can set it to update, takes for ever, counting the % up and downloading, but then again it stays empty?
Any ideas.
Hi, i lost most of mine since yesterday
Same issue here as dvidebaek has reported - My provider is Stofa.
I have been using TVMosaic before Pelx and they took the guide from the DVBC signal. That worked 100% and completely automatic.
Any update from someone?
No information from Plex regarding our issues
Have the same issue, I can rescan and then get my guide back, then next morning the guide is gone, sometimes a new scan works sometimes a reboot and the a new scan is the solution. But very unstable,
Any one having all channels back?
@sa2000 would be great if Plex took a look at the problems we are facing in Denmark. Many channels have swedish descriptions not danish. Also many channels don’t have any info at all
I found your feedback form which relates to provider WAOO
You mentioned lineup: WAOO Stor Pakke (62 channels) - Østjylland
At the moment for your post code, I can see the following WAOO related lineups:
Aura Energi (Waoo) - Bradrand (ØE) (24 channels)
Aura Energi (Waoo) - Bradrand (ØE) (52 channels)
Aura Energi (Waoo) - Bradrand (ØE) - Forening (61 channels)
Aura Energi (Waoo) - Bradrand (ØE) - Forening (23 channels)
ENiiG Fiber (Waoo) (21 channels)
ENiiG Fiber (Waoo) (51 channels)
ENiiG Fiber (Waoo) - Forening (22 channels)
ENiiG Fiber (Waoo) - Forening (60 channels)
FIBIA Vest - Jylland (Waoo) (51 channels)
FIBIA Vest - Jylland (Waoo) (24 channels)
FIBIA Vest - Jylland (Waoo) - Forening (61 channels)
FIBIA Vest - Jylland (Waoo) - Forening (23 channels)
Any of these relevant to the WAOO product you have ?
Please check this and let me know if there are any errors and if there is PDF or url link to a PDF where the channels / products are defined
My provider is FIBIA Vest - Jylland (Waoo) (51 channels)
The following channels is either missing data or in a wrong language - swedish not danish
Thanks for looking at it. There have been problems since plex switched back to Gracenote
Here is a URL to my TV package Stor TV-pakke → Få 62 populære Viasat kanaler | Waoo
My package now contains 62 channels not 51
