EPG empty and won‘t update
Hi everyone. Yesterday I found a completely empty EPG. Everything was working fine before. I went to the DVR menu to update the data manually. It went to “initialize” and then went through 0% to complete within a few seconds without updating any airings.
There wasn’t any update to the system while I was loosing the data.
Anyone who knows this issue or has the same problem?
I’m using the latest version of Plex on a Synology DS1815+ with HD Homerun Extend.
EPG source is Telekom from Germany.
ohh… i have still the same problem…
Also Telekom Premium EPG Guide and HDHomeRun Expand + WinTV Dual (DVB-C)
… all gone, no records were made :frowning:
I got the same problems but obviously I opened a question in the wrong category, so I will copy it over.
Hello everyone,
since a few days a EPG refresh leads to Plex saying me that it “downloaded 0 airings”. Now my Program Guide is empty and all my recordings won’t start.
What I’m using:
  • Linuxserver Plex Docker Container with tvhproy
What I tried:
  • restarting Docker Container -> nothing
  • restarting Docker Service -> nothing
  • rebooting system -> nothing
  • deleting all tv.plex.providers.epg.onconnect-* databases while container is off -> databases get rewritten but -> nothing
  • deleting DVR Setup in WebUI -> nothing
Logs:
Oct 19, 2017 10:17:13.275 [0x7f9c43fff700] DEBUG - Activity: updated activity d52a0c49-337c-4ac3-96c8-ecae5a37fa63 - completed 98% - Processing subscriptions
Oct 19, 2017 10:17:13.276 [0x7f9c43fff700] DEBUG - DVR:Subscription: Resolved subscription to library item 'The Mentalist' (909)
Oct 19, 2017 10:17:13.276 [0x7f9c43fff700] DEBUG - DVR:Subscription: Checking in provider Program Guide
Oct 19, 2017 10:17:13.276 [0x7f9c43fff700] DEBUG - DVR:Subscription: MATCH for GUID scheme, directly checking.
Oct 19, 2017 10:17:13.276 [0x7f9c43fff700] DEBUG - Downloading document http://127.0.0.1:32400/tv.plex.providers.epg.onconnect:19/metadata/com%2Egracenote%2Eonconnect%3A%2F%2Fshow%2F186597
Oct 19, 2017 10:17:13.277 [0x7f9c43fff700] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Oct 19, 2017 10:17:13.277 [0x7f9c43fff700] DEBUG - Auth: Came in with the master token, authorization succeeded.
Oct 19, 2017 10:17:13.278 [0x7f9c43fff700] ERROR - downloadContainer: expected MediaContainer element, found html
Oct 19, 2017 10:17:13.278 [0x7f9c43fff700] WARN - DVR:Subscription: No container available for /tv.plex.providers.epg.onconnect:19/metadata/com%2Egracenote%2Eonconnect%3A%2F%2Fshow%2F186597
Oct 19, 2017 10:17:13.278 [0x7f9c43fff700] DEBUG - Activity: updated activity d52a0c49-337c-4ac3-96c8-ecae5a37fa63 - completed 100% - Processing subscriptions
Oct 19, 2017 10:17:13.279 [0x7f9c43fff700] DEBUG - Activity: registered new activity 0d3a4d67-2890-4273-9835-a594f124afcd - Processing subscriptions
Oct 19, 2017 10:17:13.279 [0x7f9c43fff700] DEBUG - DVR:Subscription: Scheduling subscriptions.
Oct 19, 2017 10:17:13.311 [0x7f9c43fff700] DEBUG - DVR:Subscription: Initialized 1 schedulers.
Oct 19, 2017 10:17:13.311 [0x7f9c43fff700] DEBUG - DVR:Subscription: Starting with 0 grabs, scheduled 0 active ones preemptively.
Oct 19, 2017 10:17:13.311 [0x7f9c43fff700] DEBUG - DVR:Subscription: Scheduled all subscriptions in 32 ms.
Oct 19, 2017 10:17:13.311 [0x7f9c43fff700] DEBUG - Activity: Ended activity 0d3a4d67-2890-4273-9835-a594f124afcd.
Oct 19, 2017 10:17:13.312 [0x7f9c43fff700] DEBUG - DVR:Subscription: There are 0 grabs at the end.
Oct 19, 2017 10:17:13.312 [0x7f9c43fff700] DEBUG - Activity: Ended activity d52a0c49-337c-4ac3-96c8-ecae5a37fa63.
Oct 19, 2017 10:21:14.797 [0x7f9c237ff700] DEBUG - Sync: uploadStatus
Oct 19, 2017 10:21:19.385 [0x7f9c39fff700] DEBUG - EPG[onconnect]: Purging 0 airings which completed in the past.
Hopefully someone can help me.
Greets
Das_Pflanze
Same problem. No EPG data anymore
Everything German here? Then I might have a solution.
Same problem for me - Telekom Service not working
Yes German
I’m german too, also with Telekom…
Lange Rede kurzer Sinn, ich denke es liegt daran, das sich bei Telekom Digital Senderabkürzungen geändert haben. So zum Beispiel Eurosport Deutschland 2, wenn ihr den z.B. drin habt, findet er keinen einzigen Airings. Ich bin alles im einzelnen immer wieder durchgegangen, aber es scheint an einigen zu langen Senderabkürzungen zu liegen. Einfach mal durchschauen und einzelne verdächtige deaktivieren und schauen ob er sammelt.
Long story short, I think it is because of the change in Telekom Digital Sender abbreviations. Thus, for example, Eurosport Deutschland 2, he does not find any single airings. I have gone through everything in detail again and again, but it seems to lie at some too long transmitter shortenings. Just look through and disable individual suspicious and see if it collects.
Er hat recht! Ich habe testweise mal alle Sender bis auf ZDF deaktiviert und jetzt lädt er ohne Probleme!
Danke!
He is right! I just tried it with only one channel active (ZDF) and everything works fine now.
Thank you!
Edit:
Apparently “ZDF Info HD” was the toublemaker. Now it’s disabled and everything works fine.
So I guess the problem are the blanks in the Guide Channel Name . I’ve got muliple channels with more then one blank, but they always were bracketed.
“ZDF Info HD” was the only one having multiple blanks outside the brackets.
Excellent catch -thanks!!!
Thanks for the tip!
Perfect… it works !!
but how get i the ZDF Info Channel? Any solution?
Worked also fine for me. Thank you very much!
To me this sounds like a bugfix for upcoming Plex releases. How can we get it to the queue?
the ZDF Info Channel trick worked for me yesterday. This morning - EPG was empty again though (Germany with Telekom (Telco - Premium))
got it working again by disabling channels named “PhoenixHD”, “rbb Berlin”, “3satHD” - seems that it’s not only problematic with blanks but with lower case letters? weird…
It turns out it has nothing to do with the channel name. The buggy behaviour is triggered by Gracenote delivering no data for certain channels.
Affected stations in Germany are for instance:
zdf info HD
Info TV Leipzig
Dresden TV
Sky Atlantic +1 HD Germany
A bug fix has been produced which will be merged and land in one of the next releases, hopefully.
hopefully very fast :slight_smile:
At the moment, i have only 9 Stations in my DVR …
Are that many stations affected for you?
It has nothing to do with the length of the station name or the number of spaces in it.
