Could we get a update for the Windows Player to make the title bar on the top of the app dark instead of white? I don’t usually like having my player in full screen mode because I don’t see app alerts, but seeing how the player itself is dark mode, it would be nice if the top bar wasn’t a bright white color and matched the rest of the program. I’ve tried playing around with all the windows customization and colors but nothing seems to be able to affect it.
I’m thinking that’s a Windows settings adjustment. That would affect all open windows. Look in your Windows settings under Personalization. I hope that helps!
Change it here:
Settings>Personalization>Colors>Accent color.
Set to manual.
Select color
Turn on “Show accent color on title bars and windows borders”
Hope this helps…
Side note: The app could be programmed to do this on it’s own…
As mentioned, this is not a windows customization option setting. If you are able to get it to change via this method, please provide a screen shot and your method.
As mentioned, this is not a windows customization option setting. I am going to assume it’s hard coded into the program. This was why I posted this as a request for the dev’s to hopefully see.
