developing crew of plex
Hi
i have a simple sugestion that may or may not be posible to perform. maybe il just get hateresponses or that this has already been taken to the correct people.
anyway
im recuseting that in the "fix incorrect match" you are able to change the serch from movie search to tv search.
right now if something is wrongly under movies you are not able to switch to tv search even if you change to the correct searchword for said t show
i have read the F.A.C. anf know i should put tv and movies in different mapps, but seeing im using Transmission on my nas im not able to do that.
i would love to see this feature in a future update.
regards
John
Hi
anyway
regards
John
Why would the fact that you are using Transmission on your NAS limit yourself to put your videos in the correct folder?
correct folder?
Or forum  ;)
