hi i had a question
my question is the same way we have multi CC for different languages is there a way to plugin audio as well.
I know that some of my movies don’t have but is there a website or a plugin which plex can get it?
hi i had a question
my question in the movie is there a way to plugin multi language.
just like the same way we have multi CC for different languages is there a way to plugin audio as well.
Plex can work with multiple audio tracks easily, but those tracks need to be present in the media. Plex can’t go get audio tracks. That would be a hell of a feature tho…
hi i had a question
it like when you have a dvd player and you pick a different language is there a figure in which plex does the same?
i know most of my movies a in english but was wondering is there a website in which plex can plugin to have those additional figures
Yes. If the audio track is present you can select it very easy before or during playback on many devices:
The ‘Yellow’ Audio Info indicates another audio track is present. Clicking the Yellow Audio Link produces a box in which you can select different Audio Tracks. In my example above the other track is a Commentary track, but in your case - if you create other language tracks they will appear there.
Hello, There are two ways to have multiple audio tracks on a movie file. The first option to use a program like DVDFab to convert your movie in any format you want. What I like about this program is that it’s super easy to use and you can add all the audio and subtitles that are on the movie CD. Option two is if you downloaded your movie and it has only one audio track you can use MKV Tool Nix to add the audio track or subtitles into the movie.
