Different PCs Using Same Machine ID
It would appear that my device ID is not always being changed across PCs.
The below image shows two different PCs (red and blue) that are at 2 different locations and used the same machine ID. This even persisted across a separate browser type on the same red PC. This causes things like a stream on these two different PCs to show as one on Plex and it keeps flopping back and forth.
Is this a known issue? Is there anything else I can provide for better troubleshooting? Is there a better place to ask this?
~~Did you [“clone”](https://support.plex.tv/hc/en-us/articles/201370363-Move-an-Install-to-Another-System ““clone””) your server from the first to the second machine? Or copied it from a backup?
If so, it is normal that they share the machine ID. And of course this is a situation which should be avoided.
Disable remote access,
Sign Out your server from plex.tv
then erase the following key-value pairs from the advanced server configuration
AnonymousMachineIdentifier
MachineIdentifier
ProcessedMachineIdentifier
PlexOnlineToken
Caution: the above actions will delete all shares (and probably all managed users), so think twice which of your 2 machines you are ‘treating’ this way.~~
edit disregard
@OttoKerner These are device/player machineIdentifier not the server’s machineIdentifier
well spotted. 8-}
http://i.imgur.com/m4dvqsQ.png
Where do these numbers/informations come from?
PlexPy database (logged from the /status/sessions endpoint when streaming something). I’m trying to work with OP on a new feature for PlexPy but ran into this problem where the machineIdentifier is not unique for each device. The devices on my own server each have a unique ID.
Sorry, no idea about client IDs.
What about DrZoidberg? He should be at the source for proper information.
Tagging. @drzoidberg33
@drzoidberg33
Any light you can shed on this situation?
This issue still needs a solution. Multiple android boxes are reporting the same machine identifier. How is this identifier generated / how can we resolve this?
Which manufacturer(s)?
The ball is in the manufacturer’s court to create a unique ID for each device. Some don’t do that, so their devices all have the same ID.
