Server Version#: 4.135.2
My plex server is running on my nas. I do have a vpn configurated as well.
I have bougth an amazon fire stick and installed openvpn on it. However I struggle to find out how I can tell the client that he needs to connect to ip address 10.8.0.1 which is the server address after vpn connection has been established.
I did read that i can setup additional ip addresses in the server which can be used by the client. However the only option I have seen in plex server ui is “List of IP addresses and networks that are allowed without auth” in the category “Network”.
Is that the only option I have? Because no auth seems very risky.
