Direct Play: Color Space Is Not Supported
Server Version#: Version 1.27.0.5849
Player Version#: tvOS 8.3 (2621)
When trying to play some DV video files, directly, I get the issue of:
"Could not direct play because: App cannot direct play this item. No direct play video profile exists for protocol http, with container mkv, and video codec hevc.
Could not transcode because: File is unplayable. Color space is not supported."
I am not sure why it is triggering this I have direct play on, and I am using the new video player which should support HEVC. I see this log:
Streaming Resource: Reached Decision id=102492 codes=(General=2000,Neither direct play nor conversion is available. Direct Play=3000,App cannot direct play this item. No direct play video profile exists for protocol http, with container mkv, and video codec hevc. Transcode=2003,File is unplayable. Color space is not supported.) media=(id=244863 part=(id=1704706 decision=none container=mpegts protocol=hls streams=(Video=(id=3661932 decision=transcode bitrate=2147483647 encoder=h264_nvenc width=3840 height=2160) Audio=(id=3661933 decision=copy channels=6 rate=48000) Subtitle=(id=3661934 decision=transcode bitrate=2147483647 encoder=webvtt languageCode=eng location=segmented))))
Plex Media Server-49-54 2.zip (4.5 MB)
Sample file sample.zip (19.4 MB)
There are a few threads discussing this.
Color space is not supported error after updating to 1.25.5
Plex displays wrong colours with Dolby Vision on AppleTV 4k
TLDR:
Plex does not support transcoding of Dolby Vision Profile 5 video.
On supported Apple devices, Plex can Direct Play a file using the Apple decoder + player.
Compatible files must be MP4 and match Apple’s expectations (dvh1).
It is possible to remux and convert files.
Do I need to manually turn off the enhanced player or is Plex smart enough to know what it can’t handle? I theoretically could remux or convert but it’s a constant battle with these files.
Nope! Happens automatically.
