Direct streaming limitations?
I was wondering if theres a bitrate limitation for direct play. Im able to play all my videos without transcoding except for a couple mp4 remuxes straight from the original bluray and they are h264 1080p with ac3 core audio.
The limitations you will encounter are   1)  bit rate limit of the device you are streaming to  and 2) network bandwidth limits.
I guess it would be 1) since I'm able to play those same videos to other plex dlna device being a sharp tv without transcoding.
did some testing, ran a sample through handbrake, one above 20mb bitrate and one below 20mb sure enough the one below played without transcoding and the one above transcoded. Seems like its an issue with the plex app I think. when xbox releases there October update ill try playing that file through plex via dlna through the media player app and see if theres any transcoding.
After they publicly release the october update, Plex will also have to update the profile for XB1 (so PMS knows the new capabilities).
Hello everyone,
I have been changing settings endlessly with Handbrake to avoid transcoding, however, no success there. Below are the setting of a typical video I am trying to play using Plex without transcoding, what am I doing wrong? Thank you for your suggestions.
Media
  • Duration 0:22
  • Width 1920
  • Video Resolution 1080p
  • Video Frame Rate 24p
  • Web Optimized Yes
  • Height 1088
  • Has 64bit Offsets 1
  • Container MP4
  • Bitrate 18304 kbps
  • Aspect Ratio 1.78
Part
  • Size 49.76 MB
  • Duration 0:22
  • Web Optimized Yes
  • Container MP4
  • File swimmingtest.m4v
Video
  • Duration 0:22
  • Width 1920
  • Height 1088
  • Bitrate 18000 kbps
  • Scan Type progressive
  • Ref Frames 4
  • Profile high
  • Level 4.1
  • Has Scaling Matrix 0
  • Frame Rate Mode vfr
  • Frame Rate 23.976 fps
  • Color Space yuv
  • Codec H264
  • Chroma Subsampling 4:2:0
  • CABAC 1
  • Bit Depth 8
Audio
  • Language English
  • Duration 0:22
  • Bitrate 128 kbps
  • Profile lc
  • Codec AAC
  • Sampling Rate 48000 Hz
  • Channels Stereo
  • Bitrate Mode VBR
Audio
  • Language English
  • Duration 0:22
  • Bitrate 224 kbps
  • Codec AC3
  • Bit Depth 16
  • Channels Stereo
  • Bitrate Mode CBR
  • Dialog Norm -31 dB
Maybe your resolution of 1088 instead of 1080
Ryan,
    Are you referring to transcoding when playing on an XB1 ?
  The source bit rate (18304) and target bitrate (18000) are probably too high unless you are referring to the XB1.   VFR (Variable Frame Rate) is also a problem with Plex at times.  Switching to CFR (Constant Frame Rate) avoids this problem in the FFMPEG libraries Plex uses to read media files.
