Disable biographical summary
Please create a simple way to turn this stuff off. I have to scroll all the way through it every time switch artist. I find i don’t use the app because of this issue. i get pissed and shut it off.
Phobos09
  1. Navigate to the Library configuration (library context menu: ... > Manage Library > Edit)
  2. Go to the Advanced tab
  3. Disable what you don’t want to be available in your library (e.g. Artist Bios, Album Reviews and Critic Ratings, Popular Tracks, Concerts)
Thanks I did that and it still shows up.
Usually Plex does not apply those settings retrospectively. So you’ll need to refresh the metadata for the change to take effect.
That worked Thank you so much.
