Disable Reviews in Plexamp
Loving the ever improving Plexamp as always, but would love to be able to turn off album reviews. I am pretty careful to avoid reviews for music I enjoy, as I find it can really color the experience of listening to an album.
This can happen with either positive or negative reviews, but is especially frustrating with negative reviews. Would be nice to turn off the bios as well, as they also contextualize the music in a way not intended by the artist, but I have not been as bothered by those.
Thanks for the great app!
This request belongs to the server. As Plexamp simply loads the review from the server when it’s present.
Not sure if this is what you actually want but you can fully disable bios & reviews within the advanced settings of your music library. This turn off the two options.
Screenshot from 2022-10-11 09-41-58
This will disable it everywhere and not just plexamp but might be an option for you.
BTW… Refresh of the metadata would be needed after changing this setting.
Perfect! Took me a while to find those settings even with your help, but there they are! Thank you so much.
