Disable comercial removing for some channels
This may now seem obvious but in Germany not all Channels contain Ads, so it would be nice to ONLY remove Commercials for Channels which contain one (to save some CPU power).
You do the have the option to override the server setting for removing commercials when you first set up the recording (under ā€œadvanced settingsā€). Not quite what you want but a usable workaround in the meantime.
Thank you very Much
I aprechad it
