Disable Sonic scanner analysis?
Hi guys.
I dont use my plex server for music. Every day i see its running and scanning 0 albums for ages.
Is there an option to totally disable it?
Edit your Music library and under Advanced untick Sonic Analysis ?
@e10kstarfire
Thanks for the reply.
I dont have a music library :wink:
Still its scanning for albums…
Located the option in settings now :slight_smile:
Disabled :slight_smile:
Can you advise where in settings you discovered it please? Ta!
General server setting:
Settings > [Server Name] > Library > Analyze audio tracks for sonic features
Set to Never to not perform sonic analysis
On the library level:
⋮ > Manage Library > Edit... → Advanced > Sonic Analysis
Uncheck to exclude that library from sonic analysis
Thank you much mate :vulcan_salute:t4:
