Disabling multicolored subtitles (OpenSubtitles)
Is there any way to get rid of these multi-colored subtitles? It only seems to happen with Clone Wars.
I have the subtitles setting set to yellow, It’s really a pain in the ass.
The colors are embedded in the subtitle file.
Do you use external subtitles, or embedded ones?
Did they come with the video file or did you acquire them by other means?
They’re from the OpenSubtitles search
Search for some here - and get the ones that aren’t created by a whack-job:
https://subscene.com/
I just looked and there were quite a few for the show in my language - and that happens to be English… you may have good luck.
I do appreciate it, and I use SubScene for all my own videos, but Clone Wars is on a shared server so I can’t upload subtitles. I have to use the “more” button and use whatever OpenSubtitles gives me
Welp… ur done then.
Get some of these - the cheaper the better…
Cheap SGs
:sunglasses:
