Hello, everybody,
I use a Sony Z5 Compact (Android 7) and the Plex App. Lately, when I connect to a Chromecast audio in the Plex app, the connection is disconnected after a few seconds. The Chromecast starts playing and continues, but I can’t control it anymore.
But I only got this behavior from the Plex App. If I connect Plex via the browser, then it works.
But it doesn’t seem to be directly on the Android, because if I activate the transmission to Chromecast in Android then I can listen to online radio, Youtube etc. everything is possible, only not from the Plex app.
Can someone help me with that?
Thank you
Best wishes Eddie
nobody any ideas?
I don’t have an answer for you, but I have the same issue, and it’s extremely frustrating. As much as I love Plex, I can’t rely on it for Chromecast, particularly music (since movies don’t usually require as much user input - often I just hit play and that’s it).
Hi, i used plex about one year and i liked it so much. I used plex not to watch movies. I used it for listening music and uploading photos from smartphone. At the bgeninning it worked fine but after some time it beguns to stock.
i looked a long time for a soloution, but didnt found anything. I have reinstalled my plex server, without success. It must be the android app, because on the webgui its working fine.
I have tested emby and kodi. All of them has own pros and contras.
Greets eddie
Hi at all after last update from plex app, castng to chromcast workng fine again.
Thanks at plex team for soloution.
Greets eddie
