We need a way to close/dismiss/delete reported issues once addressed.
See the following
Heck yes. Not only does the info on which menu item it was on persist forever (listing an item from my server held onto by Plex?), but someone can put all kinds of horrible swears into a report and that will also persist forever.
Agreed, this was raised here as well:
And it is supposedly coming at some point in the future, but how long we will have to wait, no idea.
Quite why they thought it was good idea to roll it out with no deleted or clear option is beyond me.
Adding my hat to the pile. I send myself messages on incorrect matches or skipping episodes so I can check them later, and I was flabberghast I couldn’t resolve or delete the comment. Hopefully we get a solution before I forget which of the dozens issues I’ve resolved or not.
Is there any update on this issue? All we need is an “X” button to be able to delete the reported issue and remove it from the list. If you have people sending you reports, it just continues to build and the list can get very long. There must be a way to either dismiss it or remove it completely.
2025, same question, is there any ETA for this?
There is no ETA on this it seems Plex doesn’t care about anything or adding the most simple of functions. But don’t worry they will increase the price easily.
Please, please, please add the option for me to delete Reported Issues in my server. This seems like something that has been overlooked, as I see no reason why the option to delete isn’t there. Maybe i’m a bit of neat freak because it really bothers me to know that there are reported issues on my list that I cannot delete.
Please can someone fix this?
Thank you in advance. ![]()
I would also like a way to remove old “Reported Issues” from my server.
Hopefully this feature is added soon…
