Hi there, I was wondering if there is an option to not fit pictures to the screen, and more specifically to display them at 100% (or fit them to the width of the screen) and then be able to scroll up and down? The pictures I’m trying to parse from an RSS feed are vertically elongated and contain quite a bit of text so for it to be readable I would need to see the pictures at a 100% “zoom”.
Thanks!
When looking at pictures you can zoom by using the 1-9 keys on the keyboard and 0 will fit it to screen again. When zoomed in you can use the cursor keys to move around the photo.
Nice, thanks! Is there a way to force a given zoom level or does it have to be manually done?
