DNS issue has not been resolved, still cannot connect
Nothing changed on our end two days ago. what there was a couple days ago was a global outage of DNS services throughout the planet effecting multiple companies. I also use OpenDNS as do others without issue. Like mentioned above I would try what this user did.
@BigWheel, did you have chance to look at the logs I sent you?
I tried all suggested fixes, still have no access, dns flush, restarted everything, changed pi-hole settings, switched to cloudflare, google, quad9, disabled pi-hole and connect to google DNS directly, nothing worked.
PMS Version 1.23.5.4862 (repository:plexinc/pms-docker)
@L3gion Apologies. i did, was just very hectic the last few days and forgot to get back to you. I don’t see anything wrong with your server network-wise but you do seem to have database corruption causing things not to load.
Jul 22, 2021 23:05:18.699 [0x1544792f9b38] ERROR - SQLITE3:0x80000001, 11, database corruption at line 81887 of [1b256d97b5]
Jul 22, 2021 23:05:18.699 [0x1544792f9b38] ERROR - SQLITE3:0x80000001, 11, statement aborts at 16: [select metadata_items.id from metadata_item_settings join metadata_items on metadata_items.guid=metadata_item_settings.guid and metadata_item_settings.account_id=? where  view_offset>0
Jul 22, 2021 23:05:18.699 [0x1544792f9b38] ERROR - Soci Exception handled: sqlite3_statement_backend::loadRS: database disk image is malformed
You can either restore a back up or try to repair it .
Yep did a DNS flip from OpenDNS to another, then changed it back. seems to work for now.
Hey, back with good news @BigWheel.
Followed your recommendation of rolling back the database (app restore from a week ago via unraid) and that finally fixed my issues.
Would be great if we got some type to warning in Plex about this type database corruption.
Something like: database was unable to load ā€œdatabase disk image is malformedā€
This would help a lot and save users and devs some time going over logs.
Thanks for the help.
it is a mobile app notification option. https://support.plex.tv/articles/push-notifications/ But I will ask about it being added to web browser app
