DNS requesting issue
I know that Debian is not officially a supported OS to run PlexConnect on, but I thought someone might be able to help anyway. Someone must be running this on a Linux distro.
  • Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software):
5.2.1
  • The DNS server set on the ATV (found under the ATV settings > general > network > DNS):
192.168.2.188
  • The device and operating system (including version number) that PlexConnect is installed on:
Debian 7.0
  • The local IP address of the device that PlexConnect is installed on:
192.168.2.191
  • The device and operating system (including version number) that the Plex media server (PMS) is installed on:
Debian 7.0
  • The local IP address of the device that the Plex media server (PMS) is installed on:
192.168.2.191
  • Where your media is stored (e.g. internal drive):
Internal drive
  • The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one.
June 10th - 4.41 CEST
  • The content of your 'Settings.cfg' file (if you do not have this file you are running an old version, please update)
[PlexConnect]
port_pms = 32400
enable_plexgdm = True
ip_pms = 192.168.2.191
ip_dnsmaster = 208.122.23.22
enable_dnsserver = True
  • Detail on the media file if it is an issue related to playing a media file (in order to get the necessary information on a particular media file go into the Plex web interface, select the video file, when it brings up the page for the media file click on the "i" information button on the left hand side, it will then bring up a "media info" box, click on the "View XML" button, it will then open a browser window with the relevant information, copy this to http://www.pastebin.com and use the pastebin link to post the details; posting the information directly in the forum may mess up the formatting and generally takes up a lot of space):
Not a media issue.
  • detailed description of the issue (the clearer you can make this the better):
I am running on Unblock-Us' DNS server (208.122.23.22).
DNSServer keeps forwarding request. I let it run over night, eventually the server timed out.
  • A log file (currently this is the output in your terminal/cmd window):
http://pastebin.com/9b4VkbNn
Your ATV DNS should be pointed at 192.168.2.191.
