Do most Freesat tuners actually work with Plex?
I see the “compatibility” list on the site, but there isn’t any Freesat ones.
Could something like this work?
If it has TV tuner drivers, plex should be ok right?
Your tuner might show up in the DVR and Live TV setup wizard, but satellite still isn’t supported yet (really wish it was). If you are limited to using satellite (like me) then the best you can do right now is set up something like tvheadend, stream over kodi, and when you record, have a post-processing script that puts the recordings into a folder plex can see.
