Docker WebUI on Unraid "The connection was reset"
Server Version#: “up-to-date”
Player Version#: Not installed yet
I recently installed PLEX Media Server docker on my Unraid system, it worked fine when I first installed it, however, I am trying to access the web UI again to configure it from the Dashboard (and also Docker page) but I’m now getting the error:
The connection to the server was reset while the page was loading.
The site could be temporarily unavailable or too busy. Try again in a few moments.
If you are unable to load any pages, check your computer’s network connection.
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the web."
I tried reinstalling it and searching for this topic with no luck.
Any idea why I am now getting this?
Thanks!
Hello,
I also have a similar problem.
This page isn't working
(ip) didn't send any data.
ERR_EMPTY_RESPONSE
@progrocktv_hotmail_com, your title is Docker WebUI… are you talking about the Docker-WebUI application? or just the Plex container with its GUI?
It’s the Docker Container I think
[SOLVED] Actually when accessing the Web UI it seems it has to be https for Plex to work. http://[IP]:[PORT:32400]/web is what it should be in the container settings. You can edit this to be https:// if you like. In settings Tick the Advanced View box under WebUI.
