Unraid Plex docker won't connect to Web UI
I have run the official Plex docker via Unraid for years with no problems. Recently I started using a VPN (Mullvad) and now can no longer connect to the WebUI. Files are accessible locally, but not outside the network. I have tried deleting and reinstalling the docker to no avail and have updated to an RC version of Unraid (I can revert if need be). I tried deleting the preferences.xml file after reading a suggestion to do so, but that did not fix the problem either. I have tried accessing Plex without my VPN running, but I still can’t access it. I have also tried downloading different versions of Plex dockers, but they run into the same problem.
I am in a bit over my head at this point, but can provide any logs that might be helpful. Any help would be greatly appreciated.
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] 40-plex-first-run: executing…
[cont-init.d] 40-plex-first-run: exited 0.
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: executing…
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: exited 0.
[cont-init.d] 50-plex-update: executing…
/config/Library/Application Support/Plex Media Server/Preferences.xml:1.1: Document is empty
[cont-init.d] 50-plex-update: exited 0.
[cont-init.d] done.
[services.d] starting services
Starting Plex Media Server.
[services.d] done.
Failed to load preferences at /config/Library/Application Support/Plex Media Server/Preferences.xml
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
