Documentary - National Geographic - 100 Years - Vol 001 - Egypt The Quest for Eternity
Thanx in advance,
where and how do i get 100 of these to be correctly metadata.
I’m assuming that is this disc set you have. http://www.itisdvd.com/index.php?main_page=product_info&products_id=969
unfortunately Plex is not really designed for cataloging DVD sets because of where metadata comes from
The TVDB catalogues things as they actually aired on TV not a DVD set That particular episode is on the TVDB and would be named like for a tv library in the show “National Geographic Documentaries”
TV/National Geographic Documentaries/National Geographic Documentaries S1982E02 Egypt: Quest for Eternity.fileextension
http://thetvdb.com/?tab=episode&seriesid=80995&seasonid=449711&id=702581&lid=7
on IMDB and themovieDB is a movie
Movies/Egypt Quest for Eternity (1982)/Egypt Quest for Eternity (1982).fileextension
So you have three choices
  1. find every one the proper episode numbers for each on TVDB and rename according to that and put them in your TVlibrary as the show “National Geographic Documentaries”
  2. Name each whatever the episodes name it treat it like the movie name then put them in a movie library. since those are likely the movie titles if they all are in IMDB or themoviedb
  3. Make your own show and name it whatever you feel it should be with episodes S01E001 through S01E100 but then if metadata not embedded in file already you would have to manually enter it for each file in Plex
Thanx Sooo much
