What i mean is with the supported devices i had seen E.g. --> WinTV-quadHD
This DVR has the feature “The WinTV-quadHD is seen as 4 tuners so you can watch one TV program or record up to 4 TV programs at the same time.” so would you be able to run multiple streams off of the card?
Edit:
**Which DVR tuners are supported?
Plex currently works with many TV tuner devices that are compatible with many areas of the world. We’ll continue investigating the possibility of supporting additional tuner devices as we move forward.
Would you have to configure each tuner in it or would it be detected automatically?
@Localgamerz said:
What i mean is with the supported devices i had seen E.g. → WinTV-quadHD
Yes ( where exactly are you reading that? the sentence is a bit weirdly stated )
Edit:
info here https://support.plex.tv/hc/en-us/sections/205778607-DVR-Live-TV
you configure the card once when you setup the DVR. and it will know it has X number of tuners.
It was read on the site for the product --> WinTV-quadHD and thank you it clarifies a lot
