Does remote access require a Plex pass?
Just wanting to know if watching content via remote access outside my local network requires a Plex pass subscription?
Cheers.
In short: no.
If remote access is not working for you, don’t expect this to change after buying a Plex Pass.
lol, That’s a great answer! To the point and no lie.
So @Strayan_Hades, you having remote access issues?
Yes. The issue I’m encountering is I’m only able to play the first 10-15secs of a film at any resolution/bitrate before freezing/stuttering…
Most of the time the reason is that your server is not directly reachable. That’s why your client is using the ‘last resort’ of “Relay Access”
https://support.plex.tv/articles/216766168-accessing-a-server-through-relay/
This connection is restricted in its bitrate.
And your data will sometimes take a great detour.
Both is not conducive to a great media experience.
You need to determine why your server is not reachable directly.
Often this has to do with your router.
Sometimes with your ISP’s network.
As a first step I recommend you to read this:
https://support.plex.tv/articles/200931138-troubleshooting-remote-access/
